1952-59 Ford what did a EAB flathead come out of ???
Discussion in 'Off Topic Hot Rods & Customs' started by 67chevyholmes, Jan 16, 2012.
  1. 67chevyholmes
    67chevyholmes
    what did a EAB flathead come out of ford cars or mercs????
  2. Paul Selfe
    Paul Selfe
    52 and 53 Fords. Paul Selfe.
  3. 67chevyholmes
    67chevyholmes
    ok cause i have a chance to buy one and im looking for one tht i can put back in my 1952 ford customline sedan i was told a 8ba i need but if you say a eab is the same then ill go for that its a better motor i found
  4. skoh73
    skoh73
    I'm not sure what eab is, but I have an 8ba in my '53.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    :confused:This may explain it:http://www.vanpeltsales.com/FH_web/flathead_specs-90to125late.htm Notice the last sentence" regarding the hardened valve seats,this means the 8BA has them and the EAB does not.Now that being the case we would ***ume the 8BA would be the choice for unleaded fuel? (which was not around in the early 50's) Usually a flathead cracked block will always start in the valve area so why is it the EAB was the "improved" version :confused::confused:
  6. Paul2748
    Paul2748
    The EAB was am 'improved" version because it had higher compression and the best heads and highest HP of the later flatheads.
    8BA's were 49-51 engines. All parts were interchangable with the EAB's
