Projects What did they start with ?
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Apr 15, 2015.
  1. 56don
    56don
  2. metlmunchr
    metlmunchr
    Austin Bantam?
  3. It's not too late, your coupe could look like that.....:D
    31Vicky with a hemi and kiwijeff like this.
  4. timwhit
    timwhit
    First impression was a bantam coupe but an A coupe with no visor would look similar.
  5. xpletiv
    xpletiv
    from chiburbs
    Money?
    Time?
    Crazy idea?
  6. Purple people eater fashion, its a cut down A Coupe. Just a guess.
  7. hotroddon
    hotroddon
  8. Model T1
    Model T1
    They started with a dream and ended up with a nitemare!:rolleyes:
  9. At a first quick glance:
    Looks like an A coupe with the trunk bobbed, and body slid back.
    However that's a lot of work.
    I'm thinking its a 4dr
    There's no way I'd bob the trunk now.
    But man oh man there's Soooooo much work back there for a hole just big enough for her purse. Next one :)
  10. Rocky
    Rocky
    Classified Editor
  11. The37Kid
    The37Kid
    Used to build stuff like that with AMT kits back in the 1960's. Looks like a Model A belt line, Tudor, Fordor, or Coupe, lots of welding and Bondo slinging. Bob
  12. blowby
    blowby
    from Nicasio Ca
    LOL, and a sawsall.
  13. What are you gonna do with that?
    I'm going to build a drag car, an altered.
    The Window's curves are really different
  14. mcmopar
    mcmopar
    from Strum, wi
    Not sure what the car is, but what about the angle of the motor. I thought that the motor had to sit level.
  15. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    More dollars than sense...
  16. JB_roadrage
    JB_roadrage
    I wondered that same thing when I saw that picture in the Altered Thread...
  17. Mr48chev
    If it runs carbs and you want reasonable driving on the street yes but a fi engine or one set up for a quarter mile at a time the angle might not be so critical as long as the float bowls feed the fuel to the engine right on full acceleration or it has FI.
  18. Rocky
    Rocky
    Classified Editor
    31dodgeoriginal.jpg 31 dodge ex-fordoor
    gwhite likes this.
  19. stimpy
    stimpy
    more like a case of beers and some good BBQ
  20. stimpy
    stimpy
    Late model O/T pro stock cars the motors are angled forward due to the low drivelines
  21. 4thhorseman
    4thhorseman
    from SW Desert
    I dig the 114 altered.
  22. oldolds
    oldolds
    Take the front doors off, slide the cowl back. Easy peasy. When you come back from the commercial it will be done. Just like on TV.
  23. If you look with builders eyes and x-ray vision you'll see the crank CL pointed directly at the pinion with a really short DShaft or coupling.
    Compared to the front tires, I'd say the balancer is around the 24" rule.
    Sure would like to see some more pics of it.
  24. thirtytwo
    thirtytwo
    I'm thinking that is a coupe made to fit on a dragster ch***is like a drag master for the old comp coupe cl*** , that qtr window is defiantly coupe...
    In cold country it was common to see poor model a coupes lose their tail and become tractor cabs it may have started out that and sliced more ?
    I think it looks pretty bad *** ... i wanna drive!
  25. 54vicky
    54vicky
    it is an altered literally and liberally.same guy that worked on ones Rocky posted
  26. mcmopar
    mcmopar
    from Strum, wi
    What is the 24" rule? Does the crank have to be within a certain distance from the ground?
  27. theHIGHLANDER
    theHIGHLANDER
    The roof and belt line says A coupe, the lower body seems to be something else. The visor was mercilessly bobbed off to near nothing, I can't seem to get my head around the weird belt lines above the fender. Also, an A coupe has a continuous line down the 1/4 panel which is missing. Did they seriously take the time to surgically remove part of it? While it looks cobbled by today's ability it might have been really something in it's day. Very snotty looking and I'd bet it was just as snotty to handle at WFO.
