What did you accomplish this weekend?
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Jan 17, 2004.
  1. Paul
    Paul
    Editor
    Had ALL the bodily fluids in the daily driver changed yesterday,
    and spent most of today spreading and sanding filler on the Coupe.
  2. AnimalAin
    AnimalAin
    Got my coupe running after procrastinating on it for months. A new Edelbrock carb, a good looking fabricated fuel line (if I do say so myself), a new air cleaner, and (after it wouldn't start) a new coil. After only about ten trips to my three favorite parts houses, the old girl finally kicked off. Bucked and spit and backfired a bit, then settled in. After filling the tank with fresh premium, it runs like Jack the Bear. By the way, those Edelbrock carbs are amazing. Didn't require so much as setting the idle or choke. And no power valve to blow out....
  3. Alfster
    Alfster
    <font color="red">The modified finally got driven to an event. [​IMG]
    I stayed sober all weekend. [​IMG] </font>
  4. Hot Rod To Hell
    Hot Rod To Hell
    from Flint MI
    I found out how big of a mess you make when you hone an engine block with a flex hone, using 10w30 as a lube!!! [​IMG]
    But hey, I got my block honed and cleaned! [​IMG]
    Also got all the bolt holes chased, got all the hardware cleaned, got the old rings off the pistons, got the piston/rod ***emblies cleaned, and got REALLY high from Brake Kleen!!! [​IMG]
  5. Talbot90
    Talbot90
    Alfster,
    Very cool modified, I was well impressed.!
    How'd you get on getting the flat tyre fixed? Got home Ok?
  6. Dreamweaver
    Dreamweaver
    Finished cutting and tacking each frame side rail for the front kickup and where it narrows under the cab.
    Cut the front of each rail to accept the Model A crossmember.
    Hopefully will tack the rear and front crossmembers in this week.
    We shall see....
  7. james
    james
    Tman-- did you keep the "jet fighter" hand grips on the Brat seats? [​IMG]
  8. quickrod
    quickrod
    hey lowsquire,nice work,but the damn pedals on the wrong side [​IMG][you had to know some ***hole would say it,just figured i'd raise my hand [​IMG]]...quickrod
  9. born2late
    born2late
    I found that if you cut and weld on a set of pedals out of a 5.0 mustang, they will fit under the dash of a '39 Ford! Mounted the master cylinder, made a mock up of the column and wheel from cardboard and a broom stick. Sat on a milk crate and make engine noises as I speedshifted the new pedals!!! Kinda looks like I got something done for a change.
  10. AV8 Dave
    AV8 Dave
    Got lots done all around but in the vehicle dept. I put a power steering pump and gas filter in the wife's Miata, washed my truck and checked it's vital fluids, fired up my daughter's '56 Plymouth for it's weekly running and checkout session (she's in the States), and [​IMG] worked on fabbing the AV8's E-brake linkage and rear bumper support. [​IMG] Regards, Dave.
