Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. junkyardjeff
    junkyardjeff
    Took a bare Y block out of the back of my truck and into the garage,its a 272 block bored to standard 292 bore so I can use the less then 500 mile standard 292 pistons I was given to build me a very reasonable priced shortblock that will eventually go in my 55 sunliner.
    Ron Funkhouser likes this.
  2. clunker
    clunker
    from Boston MA
    In the hospital with pneumonia, that's why I am blowing so much of my hot air at all of you.
    slack, pat59 and Ron Funkhouser like this.
  3. Get well soon! The H.A.M.B. is great medicine. Hope you have a cute nurse, and back Hot Rodding soon. Ron...
    clunker and low budget like this.
  4. RICH B
    RICH B
    We dressed the engine in the '40 some.
  5. pat59
    pat59
    Get better ya old Clunker! :)
  6. low budget
    low budget
    from Central Ky
    Yeah,What Ron said;)
    clunker and Ron Funkhouser like this.
  7. Mercman4life
    Mercman4life
    Started up the merc, backed it out of the garage. Used it to jump start my son's off topic turd of a car. Put it back in the garage. But it was good to here it running.
    pat59 likes this.
  8. hudson48
    hudson48
    Today I put the Hudson on the hoist and gave the front end a grease. Not sure how long ago the last one was but now I do***ent all my services on the hot rod and Hudson.
  9. RICH B
    RICH B
    We got a little more done on the '40 this morning, centered the rear and set the pinion angle, welded the spring saddles, and installed the upper and lower shock mounts along with the shocks. Also changed out the 4.10 pumpkin for a 3.25 pumpkin. Then fit the floor board around the shifter, cut a hole for the new master, and installed the inner door handle mounts & links. Plan to cut up some steel for my press project this afternoon.
    olscrounger and JOYFLEA like this.
  10. junkyardjeff
    junkyardjeff
    Got the brake booster and master cylinder that is going in my 55 sunliner painted today.
  11. Los_Control
    Los_Control
    from TX
    I got to practice welding on my brother inlaws 76 duster.
    Not really H.A.M.B. material, but it has been a long long long time since my welding cl***es in school.
    My brother inlaw just bought the tweco 141i mig, tig, stick welder. What a joy to practice and relearn welding skills on his pile, and get ready to do a little rust repair on my molly in my avatar.
  12. Merlin
    Merlin
    from Inman, SC
    Trying to finish unpacking the shop so I can get back on the deuce.
    JOYFLEA likes this.
  13. Still on trial? Obits? Arrests?
  14. Remember There's never a job too small where it can't take you all day!
    David Gersic likes this.
  15. southerncad
    southerncad
    Talked myself into NOT buying another project....I think:confused:
  16. RICH B
    RICH B
    Kinda slow day; set up a modified '40 Ford parking brake handle on Pat's '54 Chev (yeh, I know a Ford part on Chev), even used a '40 equalizer underneath. Now it won't roll away when his kid plays with the shifter. Made a little bracket and mounted the horn on my '35 3W, even works. I found a grille emblem in my stuff from the Little Dearborn auction and stuck it on the grille so he knew for sure what he was (maybe getting confused by the sbc under his hood).
  17. jeffd1988
    jeffd1988
    Im working on a oversized mini bike. I would post a pic. But it off topic. But its custom made.
  18. Verbal Kint
    Verbal Kint
    from Washington
    I rolled this into the barn for storage for a couple months, while I get a few "responsible things" done
    clunker, RICH B and 62hotcat like this.
  19. robracer1
    robracer1
    In april this year I installed a new set of Stewart Warner wings gauges in a new dash panel, well the first speedo stopped working at 67 miles, called Summit and they sent a new one out, well that one the speedo needle jumped around violently and mileage stopped, called Summit and they sent the third speedo, well this one the mielage stopped at 2000 miles. called Summit and told them I wanted to return the Stewart Warner junk for credit and order the V8 Cl***ic instruments series and the great people customer service at Summit said no problem, So today I install the new gauges and do a litttle wiring, DSC02129.JPG so wish me luck!
    slack and clunker like this.
  20. junkyardjeff
    junkyardjeff
    Got the brake booster ***embled that will be going in my 55 sunliner,I hope to start installing it tonight.
  21. falcongeorge
    falcongeorge
    from BC
    I hate to admit it, but theres some sick, twisted little part of me that LIKES this!!:D
  22. jeffd1988
    jeffd1988
    A cadilac truck with a porter potty in the middle? Lol.
    thunderplex and falcongeorge like this.
  23. tfeverfred
    tfeverfred
    I taped my brake tabs onto my T's frame rail. I don't have the lines yet and it may be a little while. I was just bored.
  24. falcongeorge
    falcongeorge
    from BC
    I think I might be heading in that direction, I have had some kind of respiratory flu since I came back from Monroe 3 weeks ago, been housebound for the last two weeks. My wife wanted me to go to emergency a couple nights ago.
  25. tfeverfred
    tfeverfred
    Get well soon, man.
  26. falcongeorge
    falcongeorge
    from BC
    Its really kicking my ***. :( Been pretty much couch bound with a blanket for almost two weeks, just starting to get on my feet a little yesterday and today.
  27. K13
    K13
    Best to go to the doctor before it turns into an emergency room situation. There have been some nasty colds floating around this year.
  28. HOTRODPRIMER
    HOTRODPRIMER
    Spent all morning adjusting the 4 coil overs on the Jag rear axle,test drive proved the rear was raised up enough the annoying tire rub is no longer a problem.
    I even loaded up Earl (the mechanic) in the back seat and his 250 lbs never caused any issues. HRP
    jeffd1988 likes this.
  29. HiHelix
    HiHelix
    roughed in my F/C steering!/// yeeeeeeeeeeeee hah
  30. falcongeorge
    falcongeorge
    from BC
    you and my wife might be right. Its been going on long enough without much improvement, I will call my gp this afternoon.
    pat59 likes this.
