Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. blacknwhitedog
    blacknwhitedog
    from Sonoma, CA
    made a makeshift axle puller. Piece of angle iron and drilled two holes..bolted to axle and hammer away. Came out with 4 blows. Chain and brake drum trick weren't getting it. IMG_1361.JPG
    lothiandon1940, LAROKE and saltflats like this.
  2. ct1932ford
    ct1932ford
    Finished a sign I am doing for a town fund raiser. Tomorrow, it sounds like I will be dealing with snow. :mad:
    Tomorrow
  3. swade41
    swade41
    from Buffalo,NY
    Did you change the governor that the vacuum line ran to ?
    lothiandon1940 likes this.
  4. Hamtown Al
    Hamtown Al
    ^^Yep. I changed the modulator first.;)
    Thanks for the help... I need all I can get!!;):D
  5. swade41
    swade41
    from Buffalo,NY
    ^^^ mine (th350) was doing the same thing with the higher rpm shifts, my vaccum hose had a pinhole in it causing it and did the same thing from the 1-2 and the 2-3 shift.
  6. saltflats
    saltflats
    from Missouri
    Going to try and pull off an Old Wolf overhaul. :)
  7. RICH B
    RICH B
    Added some gizmos to Mike's doors; maybe he will lose his fear of falling out. We also mounted a Mighty Wiper. Arm is not on in pic; but anyone know why these park several degrees from full travel? IMG_20191216_142513.jpeg IMG_20191216_142534.jpeg
    Sent from my Nexus 5X using The H.A.M.B. mobile app
    JOYFLEA, LAROKE, osage orange and 2 others like this.
  8. Sold the seat and adjusting hardware from a AD chevy truck to a guy fixing a 54 model. A couple of our sheep have been escaping. So the grandsons & I spent some considerable time trying to find their escape hole and patching those likely places. I think we might have it fixed?
    Truckdoctor Andy likes this.
  9. and its a small journal block so its a 283 or 327!
    Algoma56 and Truckdoctor Andy like this.
  10. RICH B
    RICH B
    Had that happen a couple times; found the plastic gear on the governor stripped. Easy fix.
    Hamtown Al and Old wolf like this.
  11. saltflats
    saltflats
    from Missouri
    327, buddy has had this for over 30 years. He is hoping for a rering, personally I would have it bored with new pistons.
    Got one of the pistons soaking now, when I get it cleaned up we'll see if it will fly.
  12. trollst
    trollst
    mad mikey, JOYFLEA, Lil32 and 2 others like this.
  13. Put it in a coffee can of water add a tiny bit of dish liquid and put it on the stove bring it to a boil and then let it simmer a bit. the rings will loosen up and the piston pin free up in the piston. Works for me
  14. saltflats
    saltflats
    from Missouri
    I have it soaking in some carburetor cleaner. All the pins are free. The rings came out without much trouble.
  16. Marty Strode
    Marty Strode
    I rolled my "Rusty Trusty" chassis jig in, and leveled it. Getting ready to start on my 29 RPU, B/SR project. IMG_3674.JPG
    mad mikey, bymanr, slim38 and 8 others like this.
  17. jimmy six
    jimmy six
    That’s Awesome, cracked the wife up...my hospital bed had some special air system that intermittently moved to different pockets in the mattress. I could hear the small pump coming on and off. I’m sure it was for bed sore prevention. I wanted to get under the bed and see how did it worked... never did. Just another thing to look up.:p
  18. jimmy six
    jimmy six
    Since I escaped the hospital and made some recovery I slipped out of the house to have breakfast with bunch of buddies and after went to the polisher who had my sons Howard 5-2 manifold for his GMC. I’ve never seen one polished but there is no turning back now. 7E260357-6BCE-42DF-8557-D4F9CAD1BDF8.jpeg
  19. The sun was shining and it got to a wopping 40 degrees. So I went after firewood. Took a antique ( $10 auction buy) XL12 Homelite chain saw and cut down the trees. and then cut off the stump low to the ground. Got the chain pretty dull. Used a little bitty ($5 auction buy) Poulan saw to cut off all the limbs too small to make firewood. I leave the small limbs in the woods they will eventually rot. Then took my JD tractor and drug the trees out of the woods to the edge of the field. Cut them up into firewood length with a Huskvarna (I bought it new 20 years ago) chain saw. Cut down twenty trees and made them into firewood. threw one load on my truck and brought it home. I had drained the coolant from the JD tractor so I refilled it with new antifreeze and distilled water. Its now good for 40 below.
  20. LAROKE
    LAROKE
    After some off-topic work with disk brakes and rally wheels, I'm back to work on the Jimmy 302.
    Organized, put away the wheel painting materials and cleared the deck for the next planned task. Deerslayer's 400 CFM Carter AFB Carburetor has been in pieces for 3-1/2 years. Long past time to get it back together.
    When I took this thing apart, the parts were organized in muffin tins with post-it note labels. Hopefully, this will cut down my confusion during reassembly. Most of the ferrous parts have developed surface rust over the years. They will have to spend some time in the Evapo-Rust basket.
    mad mikey and lothiandon1940 like this.
  21. j hansen
    j hansen
    Today I made my last day as a full time employee.2020 I will only work Monday and Tuesday,,,,,,,more time for my cars and beer! Skärmavbild 2019-12-19 kl. 13.45.15.png Skärmavbild 2019-12-19 kl. 13.44.20.png
  22. Congrats, J, sounds like a dream, two days a week :rolleyes:
    Cheers, Carsten
    mad mikey, j hansen and 61Cruiser like this.
  23. Ron Brown
    Ron Brown
    worked on hood for the roadster...Ive always thought a 1 piece hood stops too short right at beltline and always prefered the 30 A hood for the little skirt below the beltline, so I am building hood attachment rails that will extend the hood down slightly...will be painted to match the hood. 8006517E-F10B-433B-AB54-066227772E1E.jpeg B04BAB8E-08E8-4C0C-978A-D468C95FED53.jpeg
    GordonC, chop job, JOYFLEA and 8 others like this.
  24. ct1932ford
    ct1932ford
    Received my duel hydrostatic gauge back from Tom Wolf & Co. It looks great. Hope to install it back in the roadster
    tomorrow. I also learned a lot from John and his staff about these gauges.
    Before: IMG_4345 (2).JPG After:
    JOYFLEA, mad mikey, alfin32 and 6 others like this.
  25. Pretty much the same as yesterday. Cut down trees. drive tractor and pull them out in the field. Saw trees into firewood. Load wood on pickup. Come home play on puter.
  26. harley jim
    harley jim
    I'm rebuilding a craftsman 3/4 hp grinder. I picked up the parts from powder coat and started reassembling it. [​IMG][​IMG][​IMG]
    Sent from my SM-A102U using Tapatalk
  27. j hansen
    j hansen
    I think it is the 5:2 diet i have heard about.
    Free 5 days ,work 2 days!
    mad mikey and 40two like this.
  28. LAROKE
    LAROKE
    December 20th 2019 It's time to strip down and remove Deerslayer's cab for the next phase of the work while I'm scratching my head over the carburetor. Dropped the front end down on the jack stands to level out the truck. Now I can jockey the door lift into position to take off the doors. Some of the door hinge screws want to stay where they are. Now, I'm trying different methods of extraction, with limited success. Beer of the day is River Horse Brewing Company's Oatmeal Milk Stout.
  29. lothiandon1940
    lothiandon1940
    ..........................Don't forget to put your clothes back on before you go out for coffee.:D:):D:):D..;)
    mad mikey and LAROKE like this.
  30. ERguitar
    ERguitar
    Its not "what I've done today" its what I'm going to do.
    Last day of family vacation, its been great but I'm looking forward to a little garage time tonight. 1215190918.jpg
    JOYFLEA, mad mikey, charleyw and 2 others like this.
