Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. swade41
    swade41
    from Buffalo,NY
    Parked my little Willys next to a big Willys at the nostalgia drags 20180805_144854.jpg 20180805_153338.jpg
  2. UNSHINED 2
    UNSHINED 2
    20180806_130706.jpg 20180806_114321.jpg Put tires on the wheels today.....
  3. The37Kid
    The37Kid
    ^^^^^ Nice, I've never seen a unibody Ford truck. Bob
    chevy57dude likes this.
  4. chevy57dude
    chevy57dude
    Ford did it right with the unibody. Nice shape to them.
  5. UNSHINED 2
    UNSHINED 2
    They are a serious challenge when you have to do rust repair.... 3 sometimes 4 layers of panels stacked together make it sturdy when theres no rust, but very weak once the rust sets in. And tying everything together makes a person wanna give up....
    But they are SO DAMN ***Y....
    LAROKE likes this.
  6. haileyp1014
    haileyp1014
    from so cal
    Got a wisdom tooth removed and bought a camaro wc trans for my coupe 20180728_190511.jpg
    UNSHINED 2 likes this.
  7. Sky Six
    Sky Six
    from Arizona
    114 degrees here today. Stayed inside and finished the arm rests for the 57. will install them tomorrow or the next day.
  8. UNSHINED 2
    UNSHINED 2
    The37Kid and Max Gearhead like this.
  9. Max Gearhead
    Max Gearhead
    from Wisconsin
  10. atch
    atch
  11. UNSHINED 2
    UNSHINED 2
    I see you noticed the cool parts in the background.....
    Max Gearhead likes this.
  12. Boneyard51
    Boneyard51
    D10069F8-C8C0-4E05-91FE-10D92E04C98A.jpeg Bought this while shopping with the wife... for $8. The real deal, old school American made K-D stuff.
    Bones
  13. I had bought some plunder at the Hub Cap Jct Auction Sat. Yesterday I loaded my trailer with about 40 tires and wheels. Then stacked a quan***y of tin on top of the tires. And loaded my truck bed to the gills also. I had neglected to check the air in my trailer tires before leaving home. After I loaded it I seen the tires where very low. So I left the trailer and came home and unloaded my Pk. This morning I went back and took a little 110 volt air compressor and inflated all the trailer tires to 60 PSI. Loaded the 66 GMC and brought the load home no problem . The little 250 pulled the load ok I did hsve to shift downon a few places. GMC & trailer load 001.JPG GMC & trailer load 002.JPG GMC & trailer load 003.JPG hub cap 2 014.JPG But today the s****pers where actively dragging stuff from the overgrowth. And I spotted the remains of a 55 or 56 Pontiac on a s****pers trailer. Still has the V8 engine and stick trans. I managed to buy it from them. So tomorrow I will attempt to haul it home.
    34 GAZ, chevy57dude and UNSHINED 2 like this.
  14. Last week, I was going like gang busters. To help organize the yard, I had stripped a bunch of tires from some wire wheels, and tossed the hulks away, and replaced the governor on the Bobcat loader. Then I became severely ill.
    I have been down ill for 5 days, and I am totally pissed off at having lost the time. The doctor suspects thyroid, or some other hormonal problem. I get so cold, temp mid 90s, that I shake, then an excruciating pain begins in the front of the neck, and spreads out to the jaw and shoulders. I can't work, and can't sleep. I am getting a referral to an endocrinologist. More doctors, more fun.
    Couldn't pick up a tool.
    Bob
  15. UNSHINED 2
    UNSHINED 2
    Hope the doc figures everything out for you so you can get back at it like you want
  16. Thanks, it is scary as well as being very painful. I am already on prednisone, and it can be causing the problem. It is a drug that saves your life, then spends the rest of the time slowly killing you.
    Bob
    swade41 likes this.
  17. LM14
    LM14
    from Iowa
    Drug my project out of the shop so I could see it from more than 12' away. Looked for lines, shape and problems. Found a few small problems. Time to blow it apart and get the bare metal in epoxy primer, stick it all back together and put some miles on it before winter!
    alanp561, swade41, leon bee and 5 others like this.
  18. clem
    clem
    ^^^^^Looks good !
  19. UNSHINED 2
    UNSHINED 2
  20. lonejacklarry
    lonejacklarry
    All I did was watch the gl*** man finish up installing the windows on my '37 Chevy coupe project.
    One step closer.
  21. Went and loaded and hauled home another pickup load of my auction plunder. Looked the remains of the Pontiac over really good. From the Vin and hood ornament I determined its a 56. poured a quart of ATF down the carb.
  22. It will be great if the engine will turnover and start.
    Bob
  23. Ive awakened quite a few zombie engines over the decades. I will pull the spark plugs and fill the cyls with ATF and diesel. Pull the oil pan to be certain its clean and pull the valve covers to be certisn all the valves go up and down. besides the oil fill cap is missing I will be surprised if there isn't mud wasp nest or mouse nest under there. The dist and wires are there. But later HEI will fit. And the fixture that bolts to the block for the cannister oil filter can be swapped for a later one that uses a spin on filter.
  24. alwaysamopar
    alwaysamopar
    Plumbed air outside my shop and made me a little hose stand 20180805_135931.jpeg
    Sent from my SM-G900V using The H.A.M.B. mobile app
    LAROKE and UNSHINED 2 like this.
  25. UNSHINED 2
    UNSHINED 2
    Outside air will definitely be handy!! Especially for the neighbors;);)
  26. leon bee
    leon bee
    I made this little rig to pressure test Ford flathead blocks. Got three or four to check, it'll take me a little while. Sometimes if you root thru your stuff long enough you don't have to buy anything:
  27. UNSHINED 2
    UNSHINED 2
    20180808_235812.jpg Got a good start on the cab mount replacement.
    Max Gearhead and j-jock like this.
  28. choptop40
    choptop40
    leon bee likes this.
  29. Went and hauled my last truck load of plunder from the Hub Cap Jct Auction. I got the 56 Pontiac remains loaded with some boards and a come along. Its barely on the bed mostly on the tailgate but I had it securely fastened with a log chain and ratchet binder at the rear. and a ratchet strap in the front. Made it home with no trouble.
    UNSHINED 2 and 34 GAZ like this.
  30. Boneyard51
    Boneyard51
    Just got home from the Meltdown Drags... gr*** was about 18 inch high.. me and the Hustler went to work today!
    Bones
