Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. junkyardjeff
    junkyardjeff
    Replaced the missing trans mount bolt on the sunliner along with greasing the U joints which require the drive shaft to be removed,seen seat padding coming out of a hole in the frame and it only took about a hour to blow that **** out a few holes about the size of a dime.
    BigO and CudaChick1968 like this.
  2. patzfab
    patzfab
    from Canada
    16C02645-32E1-4A5F-A0C7-1B61D1728558.jpeg Removed the old flooring from a 57 Chevy PU, made and fitted a new one on the RH side.
  3. olscrounger
    olscrounger
    Painted the lettering etc on several sets of hubcaps-thats it for today.
    lothiandon1940 and CudaChick1968 like this.
  4. swade41
    swade41
    from Buffalo,NY
    It was my turn to buy lunch at our weekly Tuesday lunch gathering at the ch***is shop, I chose calzones that barely fit in the 41 cab. Also shot some primer on the firewall of the Henry J the other day and worked on the garage itself today to get ready to knock down a support wall.
    20181016_125356.jpg 20181016_151939.jpg 20181013_201959.jpg 20181015_154815.jpg
  5. Pinstriper40
    Pinstriper40
    I picked up a better short bed for my '57 F100 over the weekend, and built this box cart for doing bodywork on the box today. IMG_20181013_172121_061.jpg 20181016_214020.jpg
  6. David Gersic
    David Gersic
    from DeKalb, IL
    Hub nut: 2
    Breaker bars: 0
    The first one I’ve had for 20 years or so. It’s had many a cheater pipe on it. Finally gave up the ghost tonight.
    8:30pm all I could get was a cheap bar. That’s the second one. No cheater, just one hard pull and it’s dead.
    Tomorrow I’ll have to get something better.
    BigO, chryslerfan55 and JOYFLEA like this.
  7. saltflats
    saltflats
    from Missouri
    ^^^^ You need a impact. ;)
  8. Boneyard51
    Boneyard51
    Break out the 3/4 or 1 inch set!
    Bones
  9. David Gersic
    David Gersic
    from DeKalb, IL
    Got two. Neither one budging it. Soaking in PB Blaster now. Will get a better breaker tomorrow and try again.
    chryslerfan55 and CudaChick1968 like this.
  10. UNSHINED 2
    UNSHINED 2
    Roped off the area for diggers hotline boys to lay down the map of where the utilities are under the area the 22' x 80' shop addition is gonna be.
    Then stood back and dreamed about the layout and where the equipment will be....
  11. Mr48chev
    Bought a wood stove (Blaze King) for the shop and ordered the poles to build the shop. Smallish in comparison to the one Unshined 2 is dong as mine is 28x30. It's going to be a pretty simple pole building.
  12. UNSHINED 2
    UNSHINED 2
    Pole building lean-to here.....gonna start digging holes Sunday
    classiccarjack and CudaChick1968 like this.
  13. Mr48chev
    Lean to here too. With the idea it could be added on to on the front in the future.
    I've got to tear down the old shed and then start digging.
  14. UNSHINED 2
    UNSHINED 2
    Here's to hoping that lean-to's arent too hard to put up! Cheers!
    CudaChick1968 likes this.
  15. southcross2631
    southcross2631
  16. I hit an old car with a hammer
  17. squirrel
    Sent from my Trimline
  18. 62rebel
    62rebel
    I took out one of my failed radius arm bushings last night; seemed like it was taking forever and I was scared of cutting into the retainer ring. Got the center cut out of the other one and it was already so dark I was using my cell phone flashlight to see where I was cutting. Once I get the radius arms finished, I hope to start working on the rear of the ch***is extension. Not going back too far, maybe a foot total, enough to safely hold a ten-inch diameter tank and add a spare tire mount.
  19. Los_Control
    Los_Control
    from TX
    Same here, my hammer was probably not as big as your hammer though. Using a ballpeen to straighten SS trim
  20. helped a student get a job at a shop today
  21. Jalopy Joker
    Jalopy Joker
    hit a couple local estate sales - 1st one got set of ratchet/open end wrenches, etc worth over $50 for $10 - 2nd stop not much for me but, they have a Comet V8 Comet taking bids on, needs total redo - down the road a place with about 20 trucks setting in field - the shop/garage was big with 3 roll up doors & one big enough for RV Bus 20181018_104207.jpg 20181018_112700.jpg 20181018_112706.jpg 20181018_112722.jpg 20181018_112728.jpg 20181018_112815.jpg
  22. junkyardjeff
    junkyardjeff
    Replaced the temp sending unit in the sunliner,sometimes the gauge would work and it was a newer part so I was able to find a original in my parts stash.
  23. CudaChick1968
    CudaChick1968
    Typical pre-Really Busy Season activities today while trying to get the real work done. Several quote requests by email overnight and lots of phone calls, and even a ride-in Veteran with some smalls for his Harley ... I didn't get too far on the current projects though. Hopefully I'll have some Powder **** to add here in a day or two. A prior customer showed off his Hemi (I did his intake); he owns the company who makes these EFI setups.
  24. UNSHINED 2
    UNSHINED 2
  25. Max Gearhead
    Max Gearhead
    from Wisconsin
    chryslerfan55 and UNSHINED 2 like this.
  26. jimmy six
    jimmy six
  27. jimmy six
    jimmy six
    image.jpeg image.jpeg Loaded up for the trip to El Mirage for the SCTA October meet... Winds over Cajon p*** may be an inconvenience as will a Sunday cross/headwind but it's my only meet this year.
  28. jazz1
    jazz1
    Drove truck up on to ramps in garage. Yes, that’s it! Winters are long and cold
  29. Deuces
    Deuces
    Bought some tickets.... That billion is mine! ;)
  30. saltflats
    saltflats
    from Missouri
    Did a front brake job on this old heap. :D
