Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. vtwhead
    vtwhead
    What grit and in how many steps did it take to get them this far? Do you finish with a buffer?
  2. Jeff34
    Jeff34
    I figured out the location of the tie rod, and bent the steering arm on the p*** side to clear the drop axle and locate the tie rod above the wishbone... Steering arm 1.jpg Steering arm 2.jpg
  3. 31Apickup
    31Apickup
    Not quite today but 2 weeks ago, the last of the warm weather for painting. Filled, epoxy primer and then feather fill for my coupe. 257C5A93-7193-4690-A011-80E8CD634102.jpeg 4430AB3E-E2F1-418D-8A0B-920F34F72C8F.jpeg 68A178D9-056D-4A74-B38E-EC12FF7B25F8.jpeg
  4. swade41
    swade41
    from Buffalo,NY
    220, 320, 400, (out of 600), 800, 1000 and yes buffed after sanding.
    Here is what they look like after the 1,000 and before buffing
  5. 1971BB427
    1971BB427
    from Oregon
    Took a couple leafs out of my front springs on my Austin g***er to slightly lower the front, but also to soften the ride. That worked great, and accomplished what I wanted. But after a few weeks of driving I hit some decent bumps the other day and the front shocks bottomed out. When I got home I took a look to make sure the shocks weren't hurt, and noticed I only had about 2.5" of shock travel.
    So I got in the shop and fabricated new upper shock brackets. My old brackets were welded on the frame at the top edge of the frame, so I had to make the new brackets about 5" tall with gusseted sides so the mounting point could extend above the frame. Got them fabbed up, and rolled the Austin into the shop to cut off the old mounts, and install the new mounts. Of course it couldn't ever be as easy as that. I quickly noticed my frame mounted fuel pressure regulator and hard line to the dual carbs was routed just above the p***enger side shock mount. So had to relocate the regulator, line, and make new mounting points for it too.
    Finally got things out of the way, cut off the old brackets, and installed and painted the new brackets. Have about 4.5" of travel now, so it wont ever bottom out unless I start jumping curbs with it.
  6. Pontmerc
    Pontmerc
    from Finland
    Not much, just sit and watch it.little cleaning at engine bay and just planning what to do it in next winter.probably focusing more to colony park. 16639633531117177966950785521173.jpg 16639635243887908558903477605839.jpg
  7. 65type1
    65type1
    Just like 31APICKUP running out of painting weather... bedsides are done and it's down to the wire on the last item...both rear fenders
    C0685B4F-1D95-481C-9B3E-02DF605FF18D.jpeg 7E2756D2-1985-495E-85EC-124960256BBD.jpeg
    rod1, 31Apickup, 210superair and 11 others like this.
  8. swade41
    swade41
    from Buffalo,NY
    Put the valve covers on my uh hmm "427" in the Henry J
  9. natrlgas49
    natrlgas49
    Drove my Delivery farther that it has gone under it its own power in 50 Years. Around the block, needs some works on the brakes. Before and After 39originalpic1resize.jpg Firstdrive.JPG
  10. Callmaker
    Callmaker
    Put my winter wheels on, made up some V8 stickers for the moons...painted the Merc valve covers, still needs wet sanding...
  11. 65type1
    65type1
    Finished my rear exhaust routing and test fit the bed wood
  12. lake_harley
    lake_harley
    I got the 5 point cage tacked in place on my dragster. Lots of angles and dangles to deal with! I know it's not perfect but after I add the helmet tubes, a bit over 1/2 way up, I think it's all built to specs. I'll probably never try to get it certified since it will likely only be raced at a non-sanctioned track.
    Lynn
    IMG_20220926_165342489.jpg IMG_20220926_165406399.jpg IMG_20220926_165448798.jpg IMG_20220926_165532046.jpg
    Stock Racer, rod1, TA DAD and 6 others like this.
  13. fastcar1953
    fastcar1953
    Looks like it will be a fun ride.
  14. fastcar1953
    fastcar1953
    Got some paint on the car. Long ways to go yet. IMG_20220926_163343.jpg IMG_20220926_163424.jpg IMG_20220926_163447.jpg IMG_20220926_163507.jpg IMG_20220926_163514.jpg IMG_20220926_163521.jpg IMG_20220926_163538.jpg
  15. lake_harley
    lake_harley
    ^^^^^Too bad we can only give one "like". Looks great and it appears it has some pretty significant metallic in it! It should sparkle in the sun. :cool:
    Looking forward to seeing it all together.
    Lynn
  16. fastcar1953
    fastcar1953
    Thanks Lynn. You will still finish the dragster before I get her car done.
    TA DAD, lake_harley and impala4speed like this.
  17. Pontmerc
    Pontmerc
    from Finland
    Exhaust was smelling little fat.
    So i did a quick idle mixture adjustment, and it sounds much smoother and dont smell anymore.
    Offcourse great reason to take test drive...
  18. impala4speed
    impala4speed
    I'm really digging the looks of this one. Hope you start a thread on it when you get back to it.
  19. fastcar1953
    fastcar1953
  20. 4speed411
    4speed411
    Narrowed the '50 Studebaker bench seat to fit in PXL_20220927_194330053.jpg the '34 Chevy 3 window coupe...took 5" out of the base and 2 1/2" out each back.
  21. Dave G in Gansevoort
    from Upstate NY
    Looking thru this thread always makes me feel like a slacker. Only got the nose opening cut to my liking today... DSCN1590.JPG The opening matches the wire hoop now! BFD, right?
  22. 65type1
    65type1
    Paint day for the rear fenders and started in on the floor.
    A9F95223-A96D-48F4-9333-653EDB6DB767.jpeg FCD5D8BD-F47A-4D9F-BC81-778165EBFC23.jpeg F81AC58C-E421-4216-AA32-5E7020D8CB1F.jpeg
  23. Mike Miller
    Mike Miller
    pulled the body off the frame DSCF5579.JPG for clean up and rust repair..
  24. guthriesmith
    guthriesmith
    Nothing today, but led about 150 cars on a 120 mile reliability run with it this past Saturday.
  25. Pass The Torch
    Pass The Torch
    I accepted a challenge from my wife; the last three years of a particular event, I took the coupe. She "suggested" I bring something different next year.... Truth be told, I probably needed the nudge to get busy on it anyway. That's the kind of Honey Do list I can live with!!
  26. High test 63
    High test 63
    IMG_20220926_194947393.jpg IMG_20220926_194938007.jpg starting on a new project. 29 rpu is the plan... Currently getting a roller mocked up. Probably end up changing rear crossmember to an A model.
  27. 210superair
    210superair
    from Michigan
    Hell yeah. Can you have her call and talk to my wife please? Lol.
  28. TA DAD
    TA DAD
    from NC
    Had a childhood friend visit for a couple days that I haven't seen in 15 years and we spent one day making the rounds in the Studebaker and one evening in the shop letting him cut a Lexan window as I can't hardly see anymore. When we finished we had a roughed in window that goes up and via the Military surplus belt. Still a lot of details to work out with the window , but so much closer to p***ing tech. I have a goal of Dec. 3rd to be ready for a race/swap meet at Farmington dragway. DSCN2625.JPG DSCN2626.JPG
    Stock Racer, swade41 and j hansen like this.
  29. 57 Fargo
    57 Fargo
    Not today but a couple days ago, unloaded the next project. F4129A3D-6AF5-4034-BCDB-83A45876B3B2.jpeg
    tr_rodder, das858, TA DAD and 4 others like this.
  30. Pontmerc
    Pontmerc
    from Finland
    Solid looking esoxs lucius.
