Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. Chucky
    Chucky
    The jalopy drag ‘41 Champion made some forward progress. I haven’t built a car in 6 years.
    bchctybob, swade41, rod1 and 8 others like this.
  2. TigerFan
    TigerFan
    from Athens, GA
    I’ve always had to build up my tool collection around having a one-car shop—so I have a small reciprocating hammer, a small drill press, a small ‘31 roadster, a small block Ford… you get the idea. So the smallest functional press I could find was designed around a Mittler Brothers press, and I love it. It works well. I’ll just TIG weld in any panels I create if I need a piece bigger that 24” wide.
    https://www.mittlerbros.com/starter-kit-4-dome-louver-bench-press.html
    Some day I dream of having a two-car garage.
  3. swade41
    swade41
    from Buffalo,NY
    I took the bucket to a free car wash ... ugh I mean show
  4. alanp561
    alanp561
    About as small as they come :)
    TigerFan likes this.
  5. RICH B
    RICH B
    Buddy returned the 27 on 32 rails I mentioned my previous post. Turned out my kid had a (sorta street-roddy) frame on his deuce frame stack; so that came to the shop to check over while waiting for the A coupe to turn up for it's tune-up.
    bchctybob, 2Blue2, alanp561 and 4 others like this.
  6. Came up with a way to get rid of the mufflers and keep my tailpipes.
    Pulled the seat, Ripped the 20 year old carpet and insulation out, started laying down a layer of sound deadening material / insulation. I should have the new carpet in by Friday.
  7. T. Turtle
    T. Turtle
    Neither... More like the one on the left but it's used one handed (one jaw is spring loaded, when you use it, that jaw applies more pressure on the bolt). I'll try to take a pic next time I'm at the workshop. Swearing and cursing is a part of our masochism (currently trying to order two front drums for something as common as a 64 Mercury - two minutes at O'Reily, 2 weeks here in Austria)...
  8. 1971BB427
    1971BB427
    from Oregon
    Recently decided to retire my 55 yr. old timing light, and broke down and bought a new fangled one. Wasn't sure if I'd like a new hi tech timing light, but gave it a try. It's actually a pretty cool tool, and I've been playing with dialing in advance on all three of my old cars, and watching the timing light zero the settings as it tells me rpm's.
    I'm usually a dinosaur, and avoid modern technology, but I think I like this new timing light!
    bchctybob, X-cpe, 61Cruiser and 5 others like this.
  9. Jkmar73
    Jkmar73
    from Tulare, CA
    Got the gauges and gauge panel installed and wired. Didn’t have time to get the tach done. It will go in a tach cup on the steering column. IMG_1132.jpeg
    bchctybob, alanp561, LAROKE and 7 others like this.
  10. Went to the Sally B’s Cafe car show Saturday, took the Nova, won Best G***er!
    9FDE53D2-A8CB-499E-A734-348D197CF89D.jpeg C3DB13F9-AE99-4CBD-A32E-76D1B3ED0365.jpeg
    Really fun to win, except we had the only “G***er”, so we actually won 1st and Last Place! Lol!
  11. 51504bat
    51504bat
    @SilverJimmy Any progress on the 37/38 Chevy that Tony (RIP) hooked you up with? Maybe a Best G***er contender next year?:cool:
    bchctybob likes this.
  12. Went to pick up some race fuel
    swade41, RICH B and j hansen like this.
  13. RICH B
    RICH B
    After avoiding and pushing them around the garage for a year or so; I actually worked on the fenders for our '47 a bit and gave them a coat of Slick Sand. Best of all it didn't start to rain until just after I pushed the last one back into the garage.
    bchctybob, alanp561, charleyw and 6 others like this.
  14. Hank37
    Hank37
  15. RICH B
    RICH B
    My friend picked up the old A coupe that we are going to redo for his son. Wasn't able to get up to the shop to start planning as I ended up in the VA hospital for a few days; but think I will get up to the shop tomorrow I think.
  16. Almostdone
    Almostdone
    Drove 2 1/2 hours each way to look at a ‘30 A pickup as a possible next project. Didn’t buy the pickup, but the wife and I did have lunch at a still-functioning A&W Drive In. Not a bad day.
    John
  17. alanp561
    alanp561
    I carefully measured twice, then cut and threaded the stainless rod that I was going to use for carb linkage. Put it all together, went to install it on the carbs, and it was only 3/4" too short :oops: :mad:. Closed the garage and opened a beer :(.
  18. Measure once and cut (and thread) twice, I always say. The number of beers opened should correspond with the number of objects you had to make over again. When it's a bad day, it only seems worth it to just keep on cutting short and opening the corresponding beers.
  19. alanp561
    alanp561
    A new day dawned and after my second cup of coffee, I marched out to the garage determined to get it right this time. Measured once, cut once, threaded to the right lengths, added parts and installed. Damn, I'm good ;). Carb linkage.jpg
    Zax, charleyw, Almostdone and 4 others like this.
  20. brokedownbiker
    brokedownbiker
    Put in some more wood in the '31 Chevy and test fit the rumble seat door. No pics, sorry.
    j hansen and bchctybob like this.
  21. jimmy six
    jimmy six
    Replaced the lower A-frame bump stops. I had left the stock ones in after installing AeroStar front springs. The right one was split. Cut off 1” this time. I hear I’ll get a better ride, we shall see Saturday.
  22. Put my p***enger door panel back on after figuring that the sill plates i cut wont fit if they are sitting on top of the carpet... now going to figure out if i "shave" the carpet down if the sill plate will sit low enough to not interfere with the door.
    osage orange and j hansen like this.
  23. bchctybob
    bchctybob
    Busy day. Changed the jets in the center carb on the Stude pickup - from 55s to 61s. The plugs looked very lean.
    I had a dream about the 392 in my old boat. I should have pulled it out and put it in the shop a looong time ago but instead I sprayed it with Sta-bil fogging spray and covered it with tons of tarps. I woke up sweating, afraid it has seized up. So I uncovered it and tried to turn it. It turns fine. WHEW! I pulled the plugs, turns nice with no rough spots. I sprayed it again and put the plugs back in. It has no miles since being freshened years ago. I’ve just got to set aside the time to fire it up. It’s just too nice of an engine to just sit around.
    Moriarity, swade41, 40two and 12 others like this.
  24. Almostdone
    Almostdone
    Ha! I have a whole pile of stuff like that in the corner of my shop. And a fridge with beer of course.
    John
  25. alanp561
    alanp561
    You're one up on me. I have to walk across the driveway to the house to get a beer. There's no room in the garage for a refrigerator ;).
    j hansen likes this.
  26. Finished installing the door panel trim, wiped the dust off (micro fiber cloth and quick Detailer) and now ready for the weekend... well almost, still need to check the fluids.
    bchctybob, j hansen and alanp561 like this.
  27. junkyardjeff
    junkyardjeff
    Nothing to the car but had to add some rocks to the driveway at the garage so I can get the 55 in and out,the rocks had washed away and the frame was hitting the apron every time it went in and out.
    bchctybob and alanp561 like this.
  28. RockyMtnWay
    RockyMtnWay
    Decided I wanted a little more info on the operating conditions of the overdrive trans in my Tudor, so added some gauges. Making this car a better “long haul” type hot rod has been a royal pain, but as the wife keeps reminding me; “it’s your hobby, you’re having fun”. :mad::p
    RICH B, bchctybob, alanp561 and 3 others like this.
  29. Cooon
    Cooon
    Pulled my F100 apart to sort the rust in the front out. Never done rust repairs before and dare I say am enjoying it (see how long that lasts) have the old fender to practise on
    543ACFFA-EFC0-4D87-9E5A-2353B2DD7BAE.jpeg 991B2781-DA33-4994-91DF-BC3AF82E2764.jpeg
  30. patsurf
    patsurf
    not trying to bust you-but round(ed) corners will be better ...
    alanp561 and Cooon like this.
