Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. nobby
    nobby
    i am glad i only tacked it in badly
    miles off
    so the questions are
    can i get the column, double joint and the steering box in a straight line - and in the stock position regards brake and clutch pedals = check
    can i get the steering wheel plane in the correctish location = check
    can i get the pitman arm to land in the correct for and aft = check
    can i get it at the correct height - well no as the thing isn't finished and you have no idea, so get that far and bend the pitman arm if you have to - you have a 7 degree reamer, if it gets so bad come in from the top.
    at least it clears the starter - groovy, might even be able to run the stock cast headers.....
    oh and you are making a sump / oil pan for sure
    edit
    move it over to the left 5mm
    move the column over 5mm
    bend the pedals 5mm
    the pitman will clear the bone
    bring it all forwards 5mm
    Okie Pete, Chucky and j hansen like this.
  2. X-cpe
    X-cpe
    Adding a timing cover, water pump and fan, along with a balancer w/pulley(s), should answer your question.
  3. Pontmerc
    Pontmerc
    from Finland
    Okie Pete, mario711, Chucky and 4 others like this.
  4. alanp561
    alanp561
    Got the mounting holes drilled in the new floorboard. Alyn and I test fitted the seat :). Seat has to come down at least 6 inches. Lots of leg room.
    Okie Pete, mad mikey, Chucky and 8 others like this.
  5. swade41
    swade41
    from Buffalo,NY
    Made some whatchumacallits
    Okie Pete, Chucky, X-cpe and 2 others like this.
  6. brading
    brading
    Don't hear much of whatchumacallits these days.
    loudbang and swade41 like this.
  7. lake_harley
    lake_harley
    Mine are flat black.
    Lynn
  8. El Caballo
    El Caballo
    from Houston TX
    I broke the handle on mine.
    swade41 likes this.
  9. High test 63
    High test 63
    Hey Alan! The car looks cool! I like how you stretched the doors. The seat does look tall.
    I sure wish my head was down behind tha windshield on my T. Is main reason i am building a whole nother car. Are those windshield posts from john lee williamson?
  10. flynbrian48
    flynbrian48
    Loaded it in the enclosed trailer to take it to Florida for the winter. B4300896-073A-4FB8-9A91-035D35E9BD91.jpeg 2D0031D2-5B7C-4366-A3B0-7438ECA760C3.jpeg
  11. swade41
    swade41
    from Buffalo,NY
    Tested out my whatchumacallits
    Okie Pete, rod1, mad mikey and 7 others like this.
  12. flynbrian48
    flynbrian48
    Unloaded the roadster in Sarasota, then drove to dinner in 80 degree weather. Sure beats shoveling snow. 8E1700E2-977D-432A-BF8C-3F4FA40CFDAB.jpeg 507BCC97-0B46-4EB4-9DA4-4AC928B77F6D.jpeg
  13. swade41
    swade41
    from Buffalo,NY
    Cut this part loose and straightened it out
    Welded an inch to the bottom for a different plan, missed a pin hole with the weld
    One step forward and two steps back, the ratio was too much at 3-1, got to get the arms more even
  14. TigerFan
    TigerFan
    from Athens, GA
    IMG_9488.jpeg I continued to work on the floorboard, and almost finished the largest part of the transmission tunnel.
    I made it more complex than it needed to be to immerse myself in the process. I just really enjoy working with steel, and I got to use some of my favorite tools.
    Jeff34, Okie Pete, rod1 and 13 others like this.
  15. TA DAD
    TA DAD
    from NC
    I got the distributor installed and the tach hooked up. For now I installed one set of points, I had to turn the cap about 180 degrees for easy access to the window for point adjustment. IMG_1078.JPG IMG_1079.JPG IMG_1077.JPG
  16. BJR
    BJR
  17. swade41
    swade41
    from Buffalo,NY
    Now ya tell me, I did switch to a doohicky since the pedal ratio was way off, now to see if this will work or I'll go to the thingamajig
    Okie Pete, mad mikey, BJR and 3 others like this.
  18. fourspd2quad
    fourspd2quad
    I got the roadster out of storage and back home with it's big bro. :)
    Jeff34, Okie Pete, X-cpe and 10 others like this.
  19. Pontmerc
    Pontmerc
    from Finland
    Changing starter.somebody swapped c6 and put wrong powermaster.it worked but sounded like you try to stick trail track in a saw mill.
    Now its gear reduction starter but correct older style flexplate tooth count.
  20. flynbrian48
    flynbrian48
    We drove it to the Lido Beach. CBDE4E58-0DA3-467F-BBB4-8CFCFEEC52DB.jpeg 4345F026-75B9-4CCF-99E7-EEFA7D75F643.jpeg
    Jeff34, 40two, Okie Pete and 9 others like this.
  21. High test 63
    High test 63
    YOU SOB!!!
    LOL!
    that's awesome Brian! That's a dream,taking your sweet roadster to Fl. For the winter! Enjoy!
    mad mikey likes this.
  22. nobby
    nobby
    done the one side,
    I have found it most difficult.
    if i may bore you....
    started with the swap meet bushings £5
    they were 84mm long
    so I thought I wouyld get some 90mm box tube with a 5mm wall
    tickle the 4mm off the inner spreader and grind and file down the outer tube 2mm each end
    drill through the box section where the bush then sat flat,
    cut the shape out with a 1mm cutting disc in a grinder
    needed to get the front to back of the bushing in line with chassis centreline
    and get the side elevation to match the crank - line of the motor
    getting the engine in the correct for and aft
    and at the correct height
    and perfectly in the middle
    balanced on a couple of concrete blocks
    with some shims as the sump it at a slight angle as its from a front wheel drive car
    with two front tyres with uneven wear
    the bit welded to the chassis became shorter and shorter attempting to get it corerect
    ha bloody har
    anyone want a three legged table........
    Okie Pete and j hansen like this.
  23. RockyMtnWay
    RockyMtnWay
    Still putting the roadster project together and of course changing things as I go.
    Test fit the new 3” chop windshield parts before getting the new glass cut. Anyone know someone looking for a 2” chopped one? :p:p:p
    40two, Okie Pete, TigerFan and 3 others like this.
  24. topher5150
    topher5150
    Fiddle farting with the fuel lines from the pump to the carb. This got me thinking about how to run the line from the frame to the pump. I found a piece of bent flared tubing to a rubber hose IMG_20230801_190822467.jpg
  25. flynbrian48
    flynbrian48
    It's much nicer here this time of year. ;) I drove to a local shop yesterday, for their car club's work day, so it was great to meet some people and hang out. I drove right past the big "Sarasota Cars and Coffee" at a shopping center, where by report there were over 800 cars. Mostly exotics, I'd have been one of just a handful of hot rods amongst the Lambos, Ferraris and Aston Martins. Next month I'll class that act up a bit and go there. :cool:
  26. El Caballo
    El Caballo
    from Houston TX
    I had torn an antenna hole in my new car cover.
    I decided that today was make and mend day. I’ve never tried to sew anything before other than a button. Let me tell you that the fabric for this car cover is thick and pushing through a needle I got more pricks than Christy Canyon. My stitches started out looking pretty random but after I got going I got better at it. I initially put a French seam on the tear facing the paint, anchored it at each end but I really felt like it would not survive without an anchor patch, hence the needle marks on my fingers.
    Okie Pete, j hansen and '28phonebooth like this.
  27. topher5150
    topher5150
    Sheesh that's a lot of cars for a meet up. Apart from the K'zoo nats I don't think there's anything near that big in west Mi.
  28. TigerFan
    TigerFan
    from Athens, GA
    I got more done on the front floor.
    It was another day reveling in metal.
  29. choptop40
    choptop40
    ford flames.png Had an idea to reproduce these flames / tribal look on my 3 window coupe.......
  30. Baumi
    Baumi
    The Suburban is working hard at this moment... we are refurbishing our shop, a new roof and better insulation was overdue...
    F15E2BFF-5E12-4EE1-9D19-92DDF27E1B53.jpeg 84D947C3-86F8-43C8-A336-2BFEE1515BB0.jpeg A3ACDEE9-834B-4CEE-A4E2-DFF77EBA0356.jpeg 6290FD49-0B99-4B93-9F3F-D2E239E26972.jpeg 3A7C5AAE-7F73-41BB-80E5-6835BE2980A3.jpeg 8B81052D-66E4-4F4E-9E1D-12AB398B9910.jpeg
