Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    mad mikey, 61Cruiser, hrm2k and 5 others like this.
  2. lostn51
    lostn51
    from Tennessee
    Mark I love the Christmas card pic and as I’m typing this we are watching Svengoolie:D
    I didn’t take any photos of my progress but I tinkered in the garage getting the electric fuel pump ready to put in my 51. Went to AutoZone and got the toggle switch, wire, inline fuse block, and corrugated wire loom to install the thing and it was just over $90 for that little bit of stuff.o_O I have all of that in the garage somewhere but it’s easier to buy it than look for hours on end trying to find it. Tomorrow if it’s not raining still I’ll put it in and hopefully get to Sam’s to fill it up.
  3. blue 49
    blue 49
    from Iowa
    I killed a few bugs with my windshield today.
  4. Clydesdale
    Clydesdale
    Bought a ‘56 rear bumper, straightened the LH end up and cleaned all the flakey chrome off. Offered it up, didn’t like it.
    So cut the centre out of the stock bumper to scratch an itch lmao!
  5. 57 Fargo
    57 Fargo
    Fired up Wifeys T-Bird and moved it a whole two feet, encouraging that the cruise-o-matic makes it go forward and backwards. Hopefully get the brakes working before the weather shuts me down for the winter.
  6. RockyMtnWay
    RockyMtnWay
    Cut and shaped dash inserts for the roadster project.
    Intended to do the mother-of-pearl on the roadster, but liked the grey so much on the Tudor dash that I had to cut one in the grey for the roadster too. :cool:
    Looks a little blue, but it is grey. :p
  7. Jimmy
    Jimmy
    Is that drum wrap? What are you using to cut/shape it. I'm concerned about chipping. Thanks,
  8. Dick Stevens
    Dick Stevens
    I believe that is guitar pickguard material
    Black_Sheep likes this.
  9. hrm2k
    hrm2k
    after a very long time, I finally got my rear suspension together along with my new 4:10 posi in my V8 Corvair
    Driver side axle
    the p***enger side axle
    The crown Jewel, 4:10 posi
    mad mikey and osage orange like this.
  10. swade41
    swade41
    from Buffalo,NY
  11. hrm2k
    hrm2k
    Watched that last night…sounds great except that header hitting the body which I’m sure you have already taken care of
    swade41 likes this.
  12. swade41
    swade41
    from Buffalo,NY
    I thought I had it, I've taken the headers off and tried to beat the firewall in but the roll bar plate is right on the other side so it doesn't budget. Where it hits on the header is right where the 4 tubes merge into the collector, so again extra strong double walled in that area.
    When I put the exhaust back on after racing it seems to have landed in the chirping spot. You would think an engine sitting on solid mounts wouldn't move around to much but it does at idle, under load it doesn't hit.
    Really does kinda agitate me, maybe I'll revisit it before winter sets in, but I do have other stuff on the 57 that needs done before winter too.
  13. RockyMtnWay
    RockyMtnWay
    It is from a sheet of “pick guard”.
    Easy to cut (jigsaw with a scroll blade) and shape (belt sander and/or files).
    Just go slow and can use painters tape (green stuff) to ensure jigsaw base doesn’t scratch surface.
    Also, do main shape first and then gauge holes. Gives ya some wiggle room.
    If ya get impatient like I do. Ya can speed up the gauge holes by using an air tool with a carbide tip, but don’t really advise it. :p:p:p
    Edit: added a pic of pickguard stuff I use.
  14. 210superair
    210superair
    from Michigan
    I need to retorque the flatty heads, but I can't find my dang torque wrench! I've got three of um, somewhere..... Lol. I have tools in my house garage and multiple spots in my barn. Haven't used a torque wrench in years and I'll be DAMNED if I can find one anywhere! Dug thru almost all my barn ****....
    Anyone got a cheap torque wrench they wanna sell?!?! Lol...
  15. Jimmy
    Jimmy
    Thanks for the info. I want to something similar for my SW Ensign panel. Cheers!
  16. Bandit Billy
    Bandit Billy
    When I built my roadster the 6 gauge alt cable got routed from the powergen to the inner fender and then through the cowl and back to the trunk. I covered it in a shrink tube that had a black cloth cover and red tracers, it looked okay, but I never liked seeing it. Plus, the sun had faded the cloth cover, so it was time for a change and since I was in there changing the temp sensors (my SW gauges don't read very accurate and SW recommended different senders to correct the issue) I figured now was as good a time as any to fix this eye sore.
    I also never put a rubber boot over the alt connector, so I got one on Amazon delivered today. When I started cutting away the cloth cover, I found there was an inner black layer that was made of nylon or something similar. It took a bit with a razor blade, but the old cover came off in bits and pieces and left the black cover un****hed. I also had left enough cable in the cowl to make the new run to the alternator without making a splice (lucky).
    It is basically invisible, but you can make out the black boot on the back of the power gen, the cable routes to the top of the head where it is held with leather straps and a bolt down retainer (where the oil filter housing holes are), down the back and into the cowl along with the oil sending unit wire.
    The rest of the wires (lights, horn, signals) remain in the inner fender held by loops I welded in during construction and leather straps my daughter made for me. $8 spent on the boot cover (it came with one black and red, I'll save the red one for another project. Cheap project, major improvement. Getting my winter projects under way.
  17. mgtstumpy
    mgtstumpy
    I finally got around to ***embling the column shifter, adding an additional shift position for modern 700R. Shifter casting was machined for new 3D printed ****ons that seat in recesses. Additional hole won't allow for OEM style rolled edge. C'est la vie FR8rxhYq.jpeg 20251024_135652.jpg 20251024_135515.jpg Shift gate1.jpg
  18. Greg Rogers
    Greg Rogers
    that looks great!!
    osage orange and mgtstumpy like this.
  19. Dick Stevens
    Dick Stevens
    Made a 200 mile roadtrip to pick up my 50 Olds 88, happy to get it home.
  20. mad mikey
    mad mikey
    Took my beast out yesterday for what may be the final outing for the season. Runs and drives great, throttle response is frightening, tire fryer with the street tires on. WIN_20240517_17_39_59_Pro.jpg
    rod1, loudbang, 26 T Ford RPU and 6 others like this.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    Jammed them in tight for winter
    rod1, mad mikey, Jeff34 and 5 others like this.
  22. Moriarity likes this.
  23. Greg Rogers
    Greg Rogers
    Yes, I hate to say it, but I have damaged my old cars more than once trying to get them in or out of winter storage....
  24. Adriatic Machine
    Adriatic Machine
    Another hundred miles last weekend. Swap meet, flea market and visiting old friends.
    rod1 likes this.
  25. swade41
    swade41
    from Buffalo,NY
    Pulled the batteries, dusted them off then slipped on car condoms for their winter naps
    https://a.co/d/dbZ7Vfj
    20251107_162355.jpg 20251107_163020.jpg 20251107_163042.jpg 20251107_171202.jpg 20251107_171811.jpg 20251107_171837.jpg
  26. 1940Willys
    1940Willys
    osage orange, loudbang and swade41 like this.
  27. swade41
    swade41
    from Buffalo,NY
    I'm just going to use some old folded socks on the corners of that bed, like I use on jack stands
  28. Cooon
    Cooon
    IMG_6698.jpeg Checked out the apricot crop
    rod1 and Stock Racer like this.
