Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. Mr48chev
    Built the battery box for my car trailer's winch. Hopefully I have used the come along to winch a car on the trailer for the last time.
    Tomorrow it is go get a load of lumber for my shop.
  2. RICH B
    RICH B
    Spent part of Monday up at the shop stringing wires under the dash; went up there today and stuck some gauges in the holes temporarily and added the sender wires to the harness. A few more wires and I get rid of twistys. Had the door open and a pigeon flew in and perched on the edge and of course **** on the roof of John's car before Mike connected with a radiator hose.
    Lil32 likes this.
  3. Lloyd's paint & glass
    Got my intake from @41rodderz, got a camshaft from @olscrounger, getting about time to pull this little motor apart and get it to the machine shop! Screenshot_20200807-144534_Gallery.jpg Screenshot_20200807-144537_Gallery.jpg
  4. blowby
    blowby
    from Nicasio Ca
    Had a small pair of vice grips snap open in my back pocket and wedge themselves in there. Any attempt to pull them out just wedged the in tighter. Had to take my damn pants off to get the *******s out. Moral: always put vice grips in your pocket tail end first.
  5. alanp561
    alanp561
    Been working on getting my clutch and brake pedals where they oughta go. Model A frame is boxed and I modified the F1 crossmember which lowered the rear mount an inch and a half. Shortened the crossover shaft 2 1/2". 20200724_123742.jpg
    Pulled the pin out of the pedal shaft mount, reversed the shaft and moved the pedals to the right. Clutch pedal had an 1/8thgap so I made a spacer. Brake pedal is now on the outside of the bracket and the shaft is recessed inside the pedal so I made a shoulder washer that bolts down to the end of the shaft. Center drilled the bolt and added a grease zerk. Drilled a new pin hole through the shaft for the locking pin. 20200807_102719.jpg
    Located the ball fitting for the crossover shaft
    and it all lines up and works! :) 20200726_085747.jpg
  6. 55Belairman
    55Belairman
    New coil springs, shocks and both upper and lower control arms. Didn't do it all today, but finished today. Now I need to get a front end alignment. The new shock hadn't been installed in this photo. thumbnail (5).jpg
  7. patrick20
    patrick20
    I went picking, and searching for parts for my 60 C10 Shop Truck Build.
  8. Mike Miller
    Mike Miller
    finished up welding in the rear section of the floor tunnel.
    Lil32 and Lloyd's paint & glass like this.
  9. Crocodile
    Crocodile
    A friend hooked me up with a very nice 35 dash. He spent over my limit, but I am still happy..
    lothiandon1940, Lil32, RICH B and 3 others like this.
  10. rob-redm
    rob-redm
    weiand vc.jpg hopefully fixed my leaking valve covers on my 36 3w
    High test 63, Lil32, j hansen and 3 others like this.
  11. Mr48chev
    Nothing productive. Listened to the land speed racing at Bonneville (sound could be louder) hung out with the cat. drank Tennessee Whiskey and smoked a cigar.
    I did figure out that the cat and I have a big garage clean out project on tap for tomorrow as I couldn't find my hole saw set that I need to use. He considers the garage to be his territory so I hope he is up to the task. IMG_9488.JPG
  12. 65pacecar
    65pacecar
    from KY, AZ
    Cool Kitty. Most aren’t hard workers so he’ll probably sleep while you work on the garage clean up.
  13. Mike Miller
    Mike Miller
    Careful fellas,
    RICH B likes this.
  14. Mike Miller
    Mike Miller
    Tacked in the front floor hump and fired up my CAD (cardboard aided design) program to build the cover for where the aux. transmission sticks through the floor.
    X-cpe, bobss396 and LAROKE like this.
  15. Jalopy Joker
    Jalopy Joker
    - no pics, didn't happen - Ha!
    High test 63 and Lil32 like this.
  16. blowby
    blowby
    from Nicasio Ca
  17. junkyardjeff
    junkyardjeff
    Started on the rear brakes on the Merc,got one drum off and the other is stuck to the axle so i soaked a bunch of bolts and that drum with PB Blaster and will try again tomorrow.
    Lil32 likes this.
  18. 4speed411
    4speed411
    IMG_20200811_132402.jpg Cleaned a pile of porcelain up IMG_20200810_151358.jpg VID_20200811_135134_LS_exported_266_1597168667144.jpg [A
  19. Almostdone
    Almostdone
    Remarried the body and ch***is after about a year separation. It’s all downhill now (right).
  20. Max Gearhead
    Max Gearhead
    from Wisconsin
  21. lumpy 63
    lumpy 63
    Came home after work and sorted through Vette parts. The core support in the car is hacked with a torch to fit a Chevelle radiator...I have two extra core supports that came with the car, one was totally rotten at the bottom but had a good X brace. The other was solid but X brace cut out. Combined the two and now have a cherry core support.:cool: BTW Lloyd I was lusting after the TR1X but really wanted a dual quad top:D
    Lil32 likes this.
  22. Lloyd's paint & glass
    Well Mr. Lumpy i can check with one of my buddy's, i think he has a dual carb TR1X in his stash ;) i had been looking for a single carb intake but they all seem to be gone around my part of the country! Then i tripped over that one in the cl***ifieds here. Had planned on 3 deuces but this way is cheaper :D
    Lil32 likes this.
  23. bobss396
    bobss396
    Where we built stock cars, there were always shop cats around and they would sleep anywhere even during the noise that went on. One was too close to where I was welding and a spark jumped onto him... he was smoldering. He did wake up as I hit him with a handful of water out of the cooling-off bucket.
    Truckdoctor Andy likes this.
  24. bobss396
    bobss396
    I figured it was time to check and change the sacrificial anode in my radiator, of course I buy a 5-pack from a marine supply place. Get the old one out, the zinc part still looked like new. Put in a fresh one anyway.
    blowby likes this.
  25. mark latham
    mark latham
    Installed some Moon gages and a tach. The gages didn't come with the light bulb condoms but I used LED's, the tach I believe is lit with LED's and doesn't look like it comes apart easily. I can live with the white light. IMG_2354.JPG IMG_2357.JPG
  26. jimmy six
    jimmy six
    A mouser? Garage cats must be a mouser.
    Truckdoctor Andy, 65pacecar and X-cpe like this.
  27. jimmy six
    jimmy six
    I’ve been reluctant to put a clamp around the wire tube on my 56... looks like it’s ok
  28. jimmy six
    jimmy six
    Had a noise on the right front brake. Found a loose attaching cap screw.. cleaned and used a little machine screw purple thread locker.
    While I was there I decided to change the gray on the repo American Torque Thrusts to Graphite wheel paint from dupli-color... finished today with the last one. Probably not be that clean again... 7744EBC9-58BF-45E5-A0F1-43D9C5D878EF.jpeg
    Yes for all you y-block haters .... that’s a washing machine pan under the engine.
  29. Chappy444
    Chappy444
    Watched Poteet go 481mph out the big end at Bonneville....(477 at the 5mile)
    Chappy
  30. AndysComet
    AndysComet
    from SOMD
    Discovered all kinds of worm holes while opening the wheel wells since the wheel arches were mostly bondo anyway.
    lothiandon1940 likes this.
