Projects What did YOU get done this Weekend?
Discussion in 'The Hokey Ass Message Board' started by 53sled, Jan 11, 2009.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Busy weekend in the shop,,,
    This is the 33 chevy we are bringing back from the dead,,,:rolleyes:
    The top was so poorly filled and warped we removed the sheet steel and cut the hacked up tack strip out,,,
    We then fabed up some 20 gauge angles and used the shrinker/strecher to get the right shape
    Then just a matter of eyeballing and double checking and spot weldinging each piece ,,,,4 angle pieces around the opening,,, and 6 different angle pieces for the top,,,then we made a u channel to cap the inside,,for strength and a place to attach the interior headliner,,
    That's about it. HRP
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    busted my *** shoveling snow..snow and more snow.
    layed out my A's dash, and where the old tank will get cut.
    tried to get my upper cowel straight (musta got hit by a tree or something in its life, or maybe when they changed the 28 engine for the 31, maybe they hit the top of the cowel with the engine or something,, its ****ed up)
    straightened out the hood, cut out the firewall..P.S. love that fire wall Skirv!
    cleaned up the shop
  3. ajeepnut
    ajeepnut
    Saturday picked up my last two projects. Unloaded outside on cinder blocks and pallets. Cleaned up all the other projects. Too make room. Sunday wife not talking to me due to more projects, hybernated in the shop with my son. Fella came over to look at parts for sale. Almost ready to put my sedans frame under my coupe.
  4. mcload
    mcload
    Damn! A brave man! Most folks would say "this is my last project", but yours come in two's! (Bet you said "last" project two or three cars back! ;-) Yeah, I know, it's a sickness.
  5. Holy **** Skirv!
    I ordered up a HST marathon from Netflix and watched it Friday night/Saturday AM, while I photoshopped some pics for Poor Boy brother Rooster, then headed over to the barn to get my transmission squared away in my Tudor... new pan, gasket, filter, make some spaces for the split wishbone/trans mount to help the caster a bit, hooked up a return spring for the brake pedal, made a oil pump primer, and a couple other little PITA things... dropped the engine back in last thing Sunday and I'll hook it all back up this week.
  6. jdj9410
    jdj9410
    from Paris TX
    Pull rearend out and refab shackle brackets and ladder bars to move rearend back 1 inch after it was all done, I thought. At least didn't have to move crossmember too and it will make a big difference in the aestetics.
  7. LAROKE
    LAROKE
    Not much but I had fun
  8. Milgan
    Milgan
    I tried to build some doors for my 27-T. spent all weekend on one and still cant get it right. looks like i better save my money and try and buy a set if i can find them.
  9. Muttley
    Muttley
    Watched football.
  10. scootermcrad
    scootermcrad
    Hell yes! Nice job man!
  11. Dirk35
    Dirk35
    I hopped my happy *** onto a C130 and relocated from one location to another in this dump the silly Sunni and Shia's are fighting over. My *** was numb in no time flat.
    On a good note, I few days before that, the MWR brought up a few camels from a local and we got to ride them by the PX. I also got to see ice cicles hanging down off the shower trailers in the middle of the desert, but didnt get a pic of that. Brrrrrrrrr! :)
  12. Fatbob309
    Fatbob309
    Spent the weekend working on a frame for the new rock rig. Its to new to post up here but I cleaned up the frame and cut off some old mounts.
    Next weekend I am going to paint it.
  13. Thanks
  14. Squablow
    Squablow
    I finished all but one of my door panels (ran out of board) and I re-bent some vent shades to fit my '55 Dodge.
    I keep telling myself I need to do a little each week and it'll be done by spring. Keeps me sane when it's 9 degrees outside.
  15. 60srailjob
    60srailjob
    from nowhere
    NOT anything I planned but I took my son to Grand Torino, it was a good movie...so the weekend coming up GO TO THE SHOP....
  16. chop&drop
    chop&drop
    I installed Dynamat to all of the inner surfaces of my tudor (except the floor), got the "chicken wire" and canvas over the hole in the roof and started rewiring the whole rig (I stripped it clean before I sent it to the paint shop). Pretty good weekend, all things considered. Don't have pics today. I took some but left the camera in she garage
  17. Jarred Hodges
    Jarred Hodges
    Friday night I went to see monster trucks. I didn't do anything over the weekend except sleep and watch TV
  18. carcrazyjohn
    carcrazyjohn
    from trevose pa
    burned out on my 29 ford roadster doing the body work i switched projects working on the 32 ford pick up put the rear part of the cab in very big patch panel tacked together ill weld it up during the week along with cab corners only took me two years
  19. Big Blue Car
    Big Blue Car
    from Orlando FL
    The wife made me stop working on cars this weekend and made me build a deck. Aparently whe was tired of walking out the door into a plant bed...
  20. BCCHOPIT
    BCCHOPIT
    Not mush cant stop playing around!!!!![​IMG]
  21. patzfab
    patzfab
    from Canada
    I fitted most of a front floor into the Cabriolet. Modified 2 Top hinges to fit as middle and lower hinges for the Driver side door, hung the door, finished off most of the metalising of the wood frame, fitted the adjustable seat frame, fitted the gas pedal, and a hand brake lever.
  22. lrs30
    lrs30
    from Kentucky
    [​IMG]nothing but this this weekend....
  23. 53sled
    53sled
    from KCMO
    I decided to go with a white motor and accent it with the same color as the engine bay, and eventually, the rest of the car.
    I used 10 gauge to make a new cover that bolts in, rather than fill all of the holes in it.
    This picture came out bluury, and the camera ran out of batteries, but in case anyone is going to run a SBC in their 49-54, and use Ch***is engineering mounts, this shows how little must be removed from the rib. Starting even with the top of the fresh air vent, cut or contour an inch out and go down 8 inches. I cut too much and ended up welding in 10 gauge to build it back up. The drivers side you could get away with leaving alone.
  24. EnglishBob
    EnglishBob
    Started mocking up the frame over the rear kick up
    Bob
  25. aldixie
    aldixie
    Finished the 4 bar rear in my 50 Chevy and tested all of the air ride by hooking it up to the garage compressor.
  26. KIRK!
    KIRK!
    Matt Seret and I got further on the Legion Special...
  27. HOTRODPRIMER
    HOTRODPRIMER
    Last weekend,,,
    This weekend,,,tried to learn how to use a English Wheel to shape some 20 gauge to cover up the hole in the roof!:D HRP
  28. oilslinger53
    oilslinger53
    from covina CA
    Cleaned grease off of, and painted a bunch of suspension parts.
  29. mrdodge
    mrdodge
    Jumped in the car, drove 5 hours to Auckland, jumped in my mates ute, drove around Auckland at 7 at night looking for inlet manifold gasket (oval port) for simonsez bbc 32 tudor to get it running so he could go to Kumeu Swap meet (12 year build). Managed to get it running by 1.00am. Then up at 5am to be at Kumeu by 6, Gates opened at 7, Sold a bit of stuff. Left at 5pm, had a few brews, fell asleep. Got up the next morning and drove back to Hastings, Great weekend!!!:)
  30. chuckw2
    chuckw2
    from So Cal
    took delivery of my "new" 64 Riviera
