What did you get done this weekend?
Discussion in 'The Hokey Ass Message Board' started by MP&C, Feb 1, 2010.
  1. MP&C
    MP&C
    With all the snow we had, couldn't do much else but work in the shop this weekend. Time to quit dragging my feet and get this quarter tacked on. Where the factory welded the top pieces together before installing the roof skin, we'll have to tackle it this time from the bottom side. Here's how the upper structure goes together with the roof.
    The window frame/top of quarter is what we removed up top, and with all this roof in the way, it will need welding from the bottom side. Here is where we're going to find access:
    The "slots" were measured from the front edge of our cut to locate some plug weld holes on the top flange of the quarter. A Roper Whitney hand punch will make short work of the holes.
    Now before tacking the quarter in place, one of the modifications I had planned was to eliminate the pinch welded flanges in the back end, to try and eliminate some of those moisture/dirt traps. The flanges on the old were trimmed to the corners, and the new quarter was trimmed with 1/8" extra. This was flattened out to fill the gap you normally see when the leaded seam is removed, and should fit up nicely for a **** welded seam.
    Quarter fitted:
    Plug weld holes shown aligned inside our access holes. I used my flattened plug weld hole drill bit to clean out the little bit of surface rust inside the holes.
    1/8" clecos were used to pull the inner quarter up tight:
    And that will be all the fun for today........what did everyone else get done?
  2. onlychevrolets
    onlychevrolets
  3. cretin
    cretin
    Lookin good man, I didn't get a god damn thing done. Luckily, I don't work on Monday which is why I'm still up with a drink at 4:15 AM, but hopefully I'll get some new motor mounts made for the '54 tomorrow.
  4. Derwood
    Derwood
    MMMMMMMM,Budweiser!
  5. jason65
    jason65
    That looks great.
  6. HOTRODPRIMER
    HOTRODPRIMER
    The hard work shows..beautiful work.
    I just fought with trying to install fender apron rubber on the wagon,,HRP
  7. Well I didn't get nearly as much done as you did and what I did do doesn't compare that what you did.
    Maybe next week I'll have some progress to report. Still won't be as much fun as what you got done.
    Nice work
  8. rustyhood
    rustyhood
    That is looking schweet! Good job, I started my 47 ford panel build a week ago. By last Friday I was tripping over **** and pant leg getting caught on dam near anything around the panel. So Saturday and Sunday was cleaning up the garage and putting things out of my way. Now back to the fun!
  9. swade41
    swade41
    from Buffalo,NY
    It was to cold in the garage so I brought the old M/T's into the house for a polish job. It wasn't cold enough to keep me from putting them on though !
  10. R Frederick
    R Frederick
    from illinois
    Made the tough decision to break my roadster down to nothing this weekend. From a running roller to a bare frame by Sunday. Ended up welding up the underneath's last night. Notching for lines, gusseting, and paint prep to follow all week.
  11. NICE job!!!!!!!!!!!
  12. SanDiegoJoe
    SanDiegoJoe
    I installed new window channels on my '59... Now I can hear the engine!
    - Joe
  13. Ruiner
    Ruiner
    All I did this weekend was my girlfriend...and did some parts shopping for the '57 Pontiac I'm dragging home this spring...not much else I can do at the new house until I find a job and get my shop/garage built...
  14. voxnut
    voxnut
    from sacramento
    Drove from Sacramento to Burbank to pick up the new dragster ch***is, and then vegged out yesterday, because I'm not 22 anymore and somewhere along the lines 18 hours in the truck now takes it out of me! Did goof around with the dragster a little though- reindexing the steering and looking for any excuse to climb in and out of it! ;-)
    http://rocinanteridesagain.wordpress.com/
  15. Gas Giant
    Gas Giant
    Wow.....awesome work.
    I managed to get my hood fixed (I can't weld to save my freakin life, so I had a body guy take care of it). Also got my wipers working. Took longer than it should have.
    Exhaust next weekend!
  16. djust
    djust
    from Oklahoma
    Beat on my A sedan fenders all weekend which turned out to be 4 days long because of the weather.
    I thought I was going to have to throw them away but with some time and patience it looks like I can save them after all.
  17. ShastaStyle
    ShastaStyle
    from Nor-Cal
    Nice work, they tured out great. I actually got so tired of polishing my m/t's that I just bead blasted them and now they have a raw aluminum look like my intake. Not sure if that is sacrilegious, but I'm digging the way they look for now!
  18. SanDiegoJoe
    SanDiegoJoe
    Progress pix?
  19. Ruiner
    Ruiner
    Hahaha, I don't think so bubba :p...
  20. spoons
    spoons
    from ohio
    Put a stereo in the wifes truck and ordered 700 bucks worth of tires from Coker
  21. scrape
    scrape
    mp&c,,, do you just work on tri5 wagons???? nice work btw....
  22. olds vroom
    olds vroom
    I test fitted the new rear end in my olds .marked where to put the lower shock mounts on saturday. On sundayi pulled it back out started weling my shock mounts then my welder died ,everything went down hill from there
  23. oldsman71
    oldsman71
    nothing !! snow up to my ****!!!!!!!!!!
  24. fredb
    fredb
    I had good intentions, honest! needed to start by cleaning out shop and putting s*&t away. 'bout the only thing that got "put away" were adult beverages, 12 oz at a time
  25. oldchevy
    oldchevy
    I got the last 3 foot of my 46 chevy truck frame boxed in. bad weather hit here today.
  26. nail-head
    nail-head
    I pulled the heads off my freshly rebuilt nailhead.
    I had a valve train problem. Discovered that the keepers were banging on the tops of the seals and that caused the spring bands around the seals to pop off and get tangled in the spring, keeper, etc...one of them bent my exhaust side pushrod on #3 cylinder.
    Apparently the machine shop cut down the outside diameter of the guides to 0.500 so the seals would fit, but didn't check the keeper to seal clearance. They need to be cut down (height) also. Heads are back at the machine shop, spent the rest of the weekend working on my trunk...new insulation, carpet, and a liner kit from Cars, Inc. I'm on my way out to the garage to work on it some more tonight. I should finish the trunk in tomorrow night. I should have the heads back this week and installed this weekend.
    Oh, I ordered a finned lifter valley cover also. I should have it Wednesday, I'll paint it (between the fins) Thursday night and it'll go on with the heads and intake on Saturday.
  27. Dirtroad
    Dirtroad
    We finely got the doors fenders and hood lined up on my 64 F100. I'm waiting on the Rad I ordered. I hope it will be in this week. A freind of mine is working on the wireing for me, and when he's done, we can fire the *****. It's coming. I'm not posting pictures until she done. I'm not sure I like it yet. I think once it's together, it will appeal to me.:eek::eek::cool:
  28. sko_ford
    sko_ford
  29. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    I finished my Nash hotrod for the second time, and put about 50 miles on it this weekend.
    I also did this!
  30. mj40's
    mj40's
    I worked on the interior of my 40 coupe. I had the rear area panel done and now working on the door panels and built a set of arm rests out of wood. The wood panel is my pattern and will do the finish in ABS plastic.
