What did you get done this weekend ?
Discussion in 'The Hokey Ass Message Board' started by hrm2k, Mar 7, 2010.
  1. Got My front floorboards done...now Im gonna hang the doors
  2. biscuit eater
    biscuit eater
    Got my master cylinder and brake pedal ***embly mocked up and positioned.
  3. swade41
    swade41
    from Buffalo,NY
  4. fab32
    fab32
    Not much, but got the windshield frame for the '32 roadster chopped 3" instead of buying the one on Ebay for $400. It's not just take out 3" and weld it back up as the sides are not parallel so a little fiddling with the lower corners is in order. A little learning exercise and saving $400......................priceless.
    Frank
  5. Frank
    Frank
    If you are looking for your Vice-grips, I think I know where they are. :D
  6. Charlie DeLong
    Charlie DeLong
    I got my transmission ***embled to the engine and the ch***is is almost ready. Next weekend I will marry the two. :rolleyes:
  7. Frank
    Frank
    This...first start up of my first hot rod. Taken way longer than I care to admit just to get to this stage, but its getting there. no cooling, belt, or timing set so I didn't let it run long.
    <embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid34.photobucket.com/albums/d101/frankr87gt/037.flv">
  8. 51hrdtp
    51hrdtp
    Started sanding my sons Fire Engine pedal car till it started to rain. M*** on sunday.
  9. Freeland
    Freeland
    nothing as i had to work, but last weekend... rebuilt the master cylinder and have brakes again...
  10. 29nash
    29nash
    from colorado
    I drove Nash hot rod, then did some wiring in a '31 chivvy pickup I made for a friend out of derelict sedan sheetmetal. We opened the garage door; it was 52 degrees F. Spring is right around the corner!!:D
  11. nwaringa
    nwaringa
    Saturday:
    Painted the rear leafs, step supports, and various parts.
    Sunday:
    The devil is in the details.
  12. SMOKINFLATHEAD
    SMOKINFLATHEAD
    from SOCAL
    Been working on the sub-dash panel, Got it primed about 15 minutes before the rain hit. (sorry for the blur)
  13. Little Wing
    Little Wing
    from Northeast
    Went horseback riding ,,and buried the cat
  14. holliwood
    holliwood
    Had to put helper bags on the back of my 07 Silverado, so I can pull trailers once again.... I did get a little time to finish pulling all the old wiring out of my Shoebox, so I can start the rewire :)
  15. Had a brake line give up the ghost on my Silverado so I got stuck with that all weekend. Was going to do the intake gasket on my Flathead...at least the weather was nice.
  16. haroldd1963
    haroldd1963
    from Peru, IL
    Put new heads on my 68 Galaxie's 390. Finishing up tomorrow on my day off.
  17. R Frederick
    R Frederick
    from illinois
    You like that? Matches the steering wheel. Isn't mock-up fun?
  18. FlamedChevy
    FlamedChevy
    Got the 40 out and went for a drive with some friends. Had lunch at Stratton's and drove somemore. What a great weekend in Tennessee.
  19. Von_Ziggy
    Von_Ziggy
    from Canada
    Pulled some weeds and racked the yard. Thanks for asking.:D
  20. 28 chevy
    28 chevy
    from NE Pa
    Ran the wire wheel on my grinder takin' paint off, about 6 hours worth and BOY are my arms tired!
  21. perk30
    perk30
    Saturday I figured out the overheating problem on the coupe. Had purchased a "premium" thermostat last year which apparently never worked right.Took it out and when heated in water on the stove wasn't budging till hit over 200 degrees. Replaced it with a regular priced thermostat and cooling issues are history. Also made a gear indicator and mounted it on the steering column so I could tell what gear I was in. Saturday night I came down with the same stomach virus my wife and daughter had so Sunday I just layed around like a slug.
  22. hotrod56cars
    hotrod56cars
    I removed the headlights and front shocks from my '32, then I reshaped the front frame horns a little bit. This week I'm making new headlight and front shock mounts. Trying to get rid of that bug eye look...
  23. cadillac daddyo
    cadillac daddyo
    from wichita ks
    lowered the front truck with the help of one of sids drop axles then the exhaust manifold broke right when i got to the local cruise night so went home fixed the manifold while i was at it i re did the exhaust and the vavle cover anpainted it plus re did the paint on the air cleaner -tune up oil change temp sensor an that about it as far as car related stuff went
  24. Didn't get alot done.
    Cleand and capped gutters on the house ready for the spring rains, almost.
    Put a 10 bolt diff back together and Toddster came by and helped me bench race for a bit.
  25. redhawk74
    redhawk74
    i was just in stillwater...you should be safe....
