what did you get done today
Discussion in 'The Hokey Ass Message Board' started by 4rod, Mar 2, 2013.
  1. tjkas1
    tjkas1
    Drove 2 1/2 hours to look at a "great" 383 stroker, "A real Stump Puller".... Only to find out it was a POS, that was junked together from s**** laying around this guys shop. He couldn't even tell the difference between a 2 bolt and a 4 bolt main. Did he not think I would open her up to check it out??? If I'd known we weren't gonna bring anything home, we could have at least taken the scooter out for a putt. Oh well, nice day for a drive.
  2. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Oh yeah, and I got some metal **** in my eye, so I spent the afternoon in the ER. I must wear my goggles. I must wear my goggles. I must......:eek:
  3. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    relocated the rear mounts for some hairpins=cut/grind/re-weld. did mock up. made margaritas..... 70 today here...... At least I got something done,but instead of posting,I should be out in the shop!:rolleyes:
  4. bulletproof1
    bulletproof1
    from tulsa okla
    moved the henry out so i could do some cleaning...i couldnt take the grinding dust any longer.
  5. mashed
    mashed
    from 4077th
    Studied for my C Well certification test coming up.
  6. 55delray
    55delray
    from Florida
    cut the dash out of my hiboy so I could reinforce **** welding done by previous owner. Doesn't anybody think about the possibility that someone one day might lay on their back and look under the dash?
  7. Bigjake
    Bigjake
    I cut and hauled wood all day for my Grandad.
  8. HotRodHighley
    HotRodHighley
    from cincy, oh
    Finshed making my door hinge on my Model A coupe! Did some body work on 29 grill shell and headlights for a sedan I'm working on.
  9. das858
    das858
    I got pumped up for the swap meet tomorrow in Lincoln, Ne.
  10. Bart78
    Bart78
    Gave my dog a much needed hair cut. He was getting pretty ugly.
  11. straight-shot
    straight-shot
    from Custer, SD
    Stripped a 1960 f100 for parts for my model A build!
  12. Egghead
    Egghead
    Dis***embeled(is that a word?) my three piece hood on the 39 Chevy. Still trying to get ever thing lined up. Pain in the a--!(And showed off my big red eye from welders flash)
  13. it was a good day, I finished installing a my narrowed Crown Victoria front end in my 65 f100 and got it back on its wheels!
  14. Sloooooowly walked my 92 year old buddy Don the length of his condo, got him safely to the bathroom and back a few times, made him some pancakes and bacon, and we watched Wheel of Fortune. Exciting stuff...lol.
    Don might be old, but he's not dead yet. When Vanna comes on, he usually says, "Vanna's got a nice chin...the kind you can rest your balls on." :eek: :D
  15. BrandonB
    BrandonB
    from nor cal
    Worked 10 hours overtime at the Chevron refinery in Richmond, Calif.
  16. dana barlow
    dana barlow
    from Miami Fla.
    I made myself a drive shaft and got new U-joint for it too from NAPA #430,its a mustang GT rear that takes 1.125in. caps and my 57 ford hotrod shaft takes 1.063in. caps[ NAPA #430] works great
  17. matthew mcglothin
    matthew mcglothin
    Drove to the parts house . Picked up a rear brake hose for the old 58. Then went back the 2nd time to get the right one. Had some lunch with the family at a local pizza joint. Worked on the rear suspension on the 58, then noticed an oil leak. So I drank beer the rest of the day
  18. matthew mcglothin
    matthew mcglothin
    That last part is just plain funny! Hilarious !!!
  19. I got to fix my neighbors garage door. My Lab/pit dog got accidentally locked in there and tried to chew her way out. Did a darn good job of it too.....:eek:
  20. slobroy
    slobroy
    Installed kingpin bushings on the '32...
  21. Fedcospeed
    Fedcospeed
    Went to a local indoor show and was har***ed all day for being a co-promotor in an other upcoming indoor show.Other than that I had fun
  22. trollst
    trollst
    Big day for me, both good and not....I welded in the floors and the firewall behind the seat in my coupe, big job, then went to help a neighbour lady move some stuff out of her house, splitsville for her, she moved her quad outside and when it came time to move it back, I offered. I discovered it had no brakes at all after I plowed into the garage door, taking out a panel doing so. So...the next hour was spent fixing the door, overcoming some embar***ment, explaining to her that I have my own quad that I'll race time to time, but mine has brakes.
  23. KenCrete
    KenCrete
    from Milwaukee
    Did oil change and replaced trans gasket & filter (th350) on my Dad's '55 chevy panel truck.
  24. Finished line bore and hone.
    Ready to cut front and rear seals.
    I might just make SpeedWeek.
  25. flyboy89
    flyboy89
    from So. Cal.
    Put new ignition cables on the '47 59A. Cleaned up a few parts and painted them.
  26. pinman 39
    pinman 39
    I worked on my dash wires in my coupe spent most of the day on it just
    to get pissed at it and the end of the day .I'll try again tomorrow .
  27. 283mike
    283mike
    Found an Edelbrock air cleaner in the local junk yard, covered with grease and crud!! gave the man 2 bucks for it, figured it'd be rusty! cleaned it up when I got home. Only a couple of tiny flaws in the chrome top!! Looks purty good on the Chevelle! wish I could get lucky like that more often, especially on high dollar stuff!
  28. 41GASSER
    41GASSER
    Got half of the hood on my 40 Willys block sanded out. Did a minor fill on the center section to improve the fit of the grill.
  29. Spent 13, yes I said 13, hours rebuilding the vent window, cutting weatherstripping, and installing my p***enger door window in my 50 dodge. Not one of my proudest moments. It was a huge ***** and its a shame I don't get paid hourly to work on my own stuff.
  30. yruhot
    yruhot
    Continued doing body work on my 1930 model A tudor. Rt rear quarter pane had nasty grove going through it and I knew it would be the most challenging for me the novice body man. Every time I thought I had it looking good I'd prime it guide coat it and start taking it down and found more and more low spots but after about 5 or 6 tried I believed I nailed it. I'm painting it Centari black acrylic black. I was told to get the body work right or I'll be sorry. That made me more determined to keep after it. Will be after it in the morning.Enclosed are a couple of photos if I can get them posted of what I'm up too. YRUHOT.............Doug. ps I also picked up a new hood top which will save me a ton of hours doing body work on the old pieces I have.
      275.5 KB
      296.1 KB
      329.8 KB
      27.4 KB
