Projects What direction to go??
Discussion in 'Traditional Hot Rods' started by RM528, Feb 28, 2019.
  1. RM528
    RM528
    Just bought a 32 Tudor and I need some guidance on which way to go. Any suggestions would be appreciated!! Ch***is or body?? [​IMG]
    dwollam, chryslerfan55 and Hombre like this.
  2. To have bought that nice of a body and have a built Frame you must have already have had a pretty good idea as to what you wanted. Why do you want people you don't even know to try to change your directions?
  3. RM528
    RM528
    No ones changing my direction. I just want to know if it makes more sense to get it rolling before the body work is started or the other way around? Thanks
    Hombre likes this.
  4. That's good to know. Generally speaking a Body should be bolted down, shimmed properly so all things fit as well as you can get it. Door Gap done the best it can be, then start bringing around the rest of things. Rolling is nice but not as important as having the Body mounted to what it plans to live on.
  5. alchemy
    alchemy
    It looks like the ch***is is all welded together, so you should be safe getting the body squared up on it and making it solid. After bodywork is closer to done you could set it to the side to do your suspension work. Sometimes it's easier to do the body resto and fab without axles to trip over.
    alanp561, classiccarjack, OFT and 4 others like this.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Being a admitted Deuce nut I always get the car rolling and have the engine & transmission in place, basically build the car then dissemble it to do the finish work.
    Looks like a great start. HRP
  7. HOTRODPRIMER
    HOTRODPRIMER
    BTW, I see some kind of book about hot rods on the spool under the thermostat instructions,resist the urge to use independent front & rear suspension.
    Stick to traditional engines and no huge rime with rubber band tires. HRP
  8. RM528
    RM528
    Ya that’s just for reference and maybe some info for maybe something I’m missing.
    This style I’m gonna shoot for—[​IMG]
  9. ^^^^^^^^^^^^^^Now you have my Full attention!!!
    chryslerfan55 and RM528 like this.
  10. F&J
    F&J
    I have seen so many far too many never finished hot rods at estates in 50 years.
    I would get the body restored first, before building any of the ch***is. If you put tons of money & hours in the ch***is first, you may end up stalled when finally realizing just how much more time & very difficult work is involved in getting the body ready for final primer, and then tons more time in woodwork, roof, and fitted & working windows, etc.
    My point is that if all that tedious hard stuff is done first, ....then you won't give up.
    Ch***is stuff will seem easy and very fast after that.
  11. RM528
    RM528
    I like the suggestion and can see how this plays a huge mental part of a project stalling or not getting finished.. thanks!
  12. The37Kid
    The37Kid
    The body looks like is has a two inch or so channel, if so, do you like that look? I'd be sure the ch***is was square and set level then start on the bodywork. Finished body in primer ready for final paint should be goal #1. Time well spent and if you do decide to bail a few years down the road you have a salable item. Engine & tires last is how I look at things. Bob
    alanp561, classiccarjack and RM528 like this.
  13. 56don
    56don
    Our tastes vary, but if it were mine, I would do something like this because I like fenders, I sedans look goofy without them.
  14. RM528
    RM528
    Very nice! What’s the top made out of?
  15. 40FORDPU
    40FORDPU
    Full fenders gets my vote.
    As far as body work, or ch***is work first for me is determined by the time of year-winter (cold shop), ch***is work, body work warmer seasons..but you may be fortunate and either have a heated shop, or live in a warm climate.
    A good idea to fill in your location on your profile..people in your area, may offer to give some needed ***istance.
    Maicobreako, The37Kid and RM528 like this.
  16. RM528
    RM528
    Will do thanks for the advice!
  17. Jalopy Joker
    Jalopy Joker
    even if you focus on metal first, keep your eyes & ears open for other parts - deals on stuff that you need may pop up and need to buy when you see 'em
    classiccarjack, RM528 and F&J like this.
  18. F&J
    F&J
    Appears to be the kit from Juliano's in Vernon, Ct. Same as the 32 Chevy next to that Ford. It is padding & covering held down by a bendable aluminum perimeter strip that gets a vinyl strip snapped in place. Bob came out with it 40? years ago.
    https://www.julianos.com/Top-Insert-Kit-s/182.htm
    ^^^^ This really paid off on my budget build. The vintage ch***is parts all showed up local while I was doing the rest.
    Ok, you already have people trying to change you goal of the fenderless one you posted. Never let others crush your visions. I had to put up with that ******** during my waaay toooo long build. It's hard enough to build a car from scratch, and I got really pissed off at some so-called friends. I was constantly told "just get it on the ****ing road"...when I was struggling with adding what I wanted. Mine was a totally junk roofless 5w shell, and I wanted a car with properly working windows, heat & defrost, twin wipers, old school drive train.
    Now, I drive it as my only daily, ...........and they still don't have anything at all, that THEY built. I've had other rods over 45 years, but that just made me know exactly what I wanted..... on what turned out to be my last build.
    dwollam, classiccarjack and RM528 like this.
  19. DDDenny
    Make every attemp to not run out of money!
    The good news is you are already half way there.
  20. HOTRODPRIMER
    HOTRODPRIMER
    I have had both hiboy and full fendered Deuces, and like Don I prefer full fendered. HRP
  21. WB69
    WB69
    from Kansas
    Liking the door paint, would work for me. My name.....
    RM528 likes this.
  22. RM528
    RM528
    Spot on! Everyone has a preference and that’s good but I have a vision and no ones changing that!! [​IMG]
    Already got in mind what I want for the front end when the time comes!
  23. RM528
    RM528
    Right on! Thanks!
  24. HOTRODPRIMER
    HOTRODPRIMER
    Doug, you still need to send the suburban down the road and and get the roadster running. HRP
  25. alchemy
    alchemy
    When you are looking at front axles, spindles, perches and such, make sure to only buy forged parts. Cast parts are not as strong for our uses.
    F&J and RM528 like this.
  26. tfeverfred
    tfeverfred
    Ch***is, then body.
    missysdad1 and Hollywood-East like this.
  27. Rusty O'Toole
    Rusty O'Toole
    Nobody ever successfully picked out a wife for another guy. What matters is what kind of car do you want? If it turns out the answer is "not a 32 Ford" then sell it and buy something that suits you better. I say this because if you were a real gone 32 Ford fan you would not need to ask what to do. Maybe how to do it but not what to do.
  28. Rusty O'Toole
    Rusty O'Toole
    Here is the Orange Crate, coolest 32 Ford sedan ever
    alanp561, williebill, dwollam and 4 others like this.
  29. Hombre
    Hombre
    I agree with getting the body work done first. from the looks of that picture it seems you have a sound body to start on, and it isn't going to need a ton of body work. The chop for me is a fun deal so I would get that out of the way first. I also like the car you pictured as being the look you are going for. I don't personally like fenders on the type car you are planning, and I NEVER ever feel that a open wheeled car looks GOOFY without fenders. We all should feel like we have a choice without others opinion's clouding that. Open wheeled cars are cool wither they are coupes or sedans, notice I didn't put down cars with fenders as I also think they can be cool.
    Also be careful with Speedway. On some stuff they have damn good price's but they also sell "SOME" junk. There front axle's for instance as has been mentioned be sure you get a Forged front axle. Speedway sells them but they also sell several cast axle's, trust me on this you DO NOT want a cast axle.
    Start a build thread and keep us up on your progress. Very cool car and good luck...
    dwollam and RM528 like this.
  30. 56don
    56don
    Don't know, its a HAMBER's car, maybe he will read the thread and chime in.
