What do I have here?
Discussion in 'The Hokey Ass Message Board' started by Dan, Aug 30, 2012.
  1. Dan
    Dan
    I know less than zero about tig welding, can anyone tell me what exactly I have here? I am certain this stuff is realitively old, is it feasible to build a tig set up around this? What else is missing??
  2. Gerry Moe
    Gerry Moe
    Everything
  3. Model A John
    Model A John
    from wichita ks
    A picture?
  4. Dan
    Dan
    Thanks for deleting the double post...
    I do have pics, trying to get them to load but something goody is happening, thanks for the patience...
  5. Dan
    Dan
    trying again...
  6. squirrel
    the board is having some technical problems right now, my guess is that picture uploading might not be working for a while.
  7. Dan
    Dan
    see if its working yet - if not I'll give it a day, thanks-
  8. Well IMHO... You still have nothing!
  9. shinysideup
    shinysideup
    from ruskin, fl
    It has potential.
  10. BOWTIE BROWN
    BOWTIE BROWN
    NO PIX .....SEE IT TOMORROW.
    thanxz for the post .
  11. Wow, you're an optimist.
  12. Dan
    Dan
    see if its working today...
  13. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    You have a watercooled tig torch - gas regulator and a foot pedal for amperage control. And yes those are all parts used for a tig welder and they are not all that old.
  14. rustednutz
    rustednutz
    from tulsa, ok
    You've got the accessories you need to tig weld but no welder.
  15. Missing the tip parts on the torch....but that can be bought easy enough...
  16. Get yourself an AC/DC welder and go to town.
  17. Dan
    Dan
    I am ***uming the one on the left is the water cooled torch and the one one the right is not?
    PnB - any old stick welder will allow me to plug in the footcontrol, torch, etc. ??
  18. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    The torch with the 2 large br*** fittings (one for gas, one for water) appears to be w/c.
    No, the power source needs to be configured to use the foot control. But the torch can be used w/o the foot control, on any power source, you just wont have infinate amperage control as with the foot pedal.
  19. Dan
    Dan
    so if I used the torch on the left with an ac/dc stick welder power unit I would have a "scratch" start type set-up, correct? And like you said I wouldn't be able to adjust the amperage...
  20. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Yep.
  21. joel
    joel
    You'll also have to turn the purge gas on/off manually. Sell the stuff you have or keep it for spares and buy a 200 Miller ( Lincoln if you prefer)
  22. MrMike
    MrMike
    Went down the same route, gave up and bought a complete tig setup, best money I spent. YMMV
