Hot Rods What do I have? Need help
Discussion in 'The Hokey Ass Message Board' started by KarKrazy56, Jun 6, 2021.
  1. KarKrazy56
    KarKrazy56
    from NJ
    I was acquired this vehicle but don't know what it exactly is. Im thinking it may be a 33 Chevy but not sure. The car has no ***le either. What is it worth? Thank you.
  2. hotrodjack33
    hotrodjack33
    the body looks like a 1930-31 Ford Model A Tudor cut down into a Phaeton. Frame could be Chevy?!?. Rear axle looks to be a 9" Ford.
    I probably wouldn't build it...too many mis-matched parts. The body could be saved (neat firewall)...so I'd say about $1000-$1500 in parts...maybe $2000 depending the condition of the engine.
  3. squirrel
    spot on description and recommendation...although
    that's a 55-64 Chevy car type rear, it doesn't have the separate pinion bearing retainer you'd see on a Ford rear.
    I'd ***ume the engine is worth it's weight in s**** iron, judging by the general theme of the car
  4. Add some roadster quarters and you've got the makings of a cool rod :)
    '34 Ratrod likes this.
  5. 1971BB427
    1971BB427
    from Oregon
    Parallel front leaf springs indicate a Chevy frame.
  6. goldmountain
    goldmountain
    The body don't look too bad but you never know what is lurking below the paint.
  7. arkiehotrods
    arkiehotrods
    Food for thought
    AHotRod and kidcampbell71 like this.
  8. squirrel
    there's a long ways between those two cars you've pictured, and the one that we're talking about in this thread!
    X38 and Desoto291Hemi like this.
  9. 51504bat
    51504bat
    The ***le or lack there of is another (very important) issue. Don't know how hard it is to get a ***le in NJ. Especially for one with a miss m*** of parts.
    dana barlow likes this.
  10. Squirrel is right on the money,,,,as always .
    Also,,,,,,it has at least three different wheels ,,,,,can’t see the fourth one .
    It’s cobbled together,,,,,,,to get someone to bite .
    No ***le,,,,,good luck to whoever has it,,,,,,,engine looks like it was just placed in there .
    Tommy
  11. trevorsworth
    trevorsworth
    Snip! I forgot slant window Model As were a thing.
  12. redo32
    redo32
    If you've got a little money to spend and if there's not too much bondo in the body it can make a good looking piece. Buy a repo '32 frame with a certificate of origin, with receipt for the body and running gear you can get an ***embled ***le in most states.
    VANDENPLAS likes this.
  13. hotrodjack33
    hotrodjack33
    Definitely a "homemade" slantwindow. Doors are too long and the hinges are wrong for a '31 Slantwindow sedan body.
  14. Budget36
    Budget36
    If you can ***le or register it, and the price is right, why not? It’s definitely not a 5k starter project, but might have enough there to get you going without a lot of $$ up front.
    I understand those who would say spend more for better, but if you don’t have the budget to start off with a more expensive project, buying cheaply and putting dollars into it over time eases the pain. Sure, you’ll probably wind up spending more, but it’s easier to swallow a few hundred here and there over X-years, rather than coming up and spending Y-dollars now.
  15. redo32
    redo32
  16. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Check on the ***le issue before you spend any money on it. ***le work in NJ could be anywhere between a Breeze and a *****.
    Firewall looks like it was robbed from a (too small to fit your body) fibergl*** body.
    Parallel leaf front axles just don't "work" on a Hiboy. You have your work cut out for you, but it could work into a fun, low buck project if you're doing it right and with your own labor and the ***le issue can be sorted out.
  17. clem
    clem
    Shorten the body and build a bucket out of it.........?
  18. wheeldog57
    wheeldog57
    Parallel front leaf springs does not always mean Chevrolet. All GM cars and light trucks of the era ran these. Chrysler did too. That front crossmember does not look like Chevrolet but I've been wrong before. . .
  19. greybeard360
    greybeard360
    Frame looks like it has been spliced together in a few spots. I don't see any rear springs either. Looks like a round tube was just ahead of the rear crossmember at some point... Coil overs?
  20. dana barlow
    dana barlow
    from Miami Fla.
    With out a ***le,you got nothing. Do not put a lot of work in to a pile of parts,tell you have ***le,or all you'll ever have is just parts.
  21. Squablow
    Squablow
    Definitely looks like an A sedan with the roof cut off, and I'd bet any money this build started out on a different frame. Why else would anyone channel that firewall inward so far when it's not even remotely close to the engine?
    If I had to guess, someone was building this car, it got sold to someone who used the frame under some other body and stuck this frame together as a roller to sell the body.
    As for value, it's still a buildable body if you're into touring cars, at least it's steel and not all rotten. But the frame is pretty worthless, other than maybe the rearend, and I'm guessing the engine and trans are junk unless proven otherwise. If this was on Marketplace for $1500 I'm sure someone would buy it, so that's what I'd value it at, retail.
    SR100 likes this.
