What do I need between my '39 tranny and F1 crossmember?
Discussion in 'The Hokey Ass Message Board' started by Congested, Apr 6, 2011.
  1. Congested
    Congested
    I have a '39 3 speed tranny bolting to a F1 crossmember transmission mount.
    What should I use between bolting the tranny on to the mount?
    I would think that there would be a rubber biscuit that I could use. The gap is only about 3/4".
    What are you guys using?
    Thanks!
    1930 Ford Coupe Body
    1932 Frame
    F1 transmission crossmember and mount
    1939 Ford 3 speed tranny
  2. Kevin Lee
    Kevin Lee
    Super Moderator
    No rubber. The trans bolts solid to the mount and the rubber is between the mount and the crossmember.
  3. Congested
    Congested
    Perfect!
    I just ordered another Transmission Mount from Mac's. The original one was in bad shape.
    We'll just need to modify the new one a little bit where it bolts together. There is that 3/4" gap and the bolt holes dont line up too well.
    So the tranny bolts right on to the mount and the rubber under the mount is the cushion..got it.
    Thanks for your help!
  4. Congested
    Congested
    Hey Skidmarks, I bought this crossmember from you.
    Think that might be hard to find.....
  5. Junk Hunter
    Junk Hunter
    from The Ozarks
    I've got a couple of the 41-48 rear mounts. Shoot me a PM if you are interested in one. -JH
  6. Congested
    Congested
    Hello Junk Hunter,
    Ok help me out here.
    If I take off the section of the '39 tranny that has the ears that bolt to the transmission mount and use yours. I can then bolt right to the mount?
    That would be good, then I wouldnt have to modify the mount.
    The tranny is over at my friends shop, so, I dont have it in front of me to take a look at it.
  7. Congested
    Congested
    Sounds easy enough. Thanks for the help.
    You probably remember me. First time builder.....
  8. Junk Hunter
    Junk Hunter
    from The Ozarks
    ^^^what he said..
    I can get you pics of mine tonight if you want. They are still on the trannys..
  9. Congested
    Congested
    Yes, Please send a pic. I need to make sure I'm buying the right thing. I have a history of buying two of everything. I told my wife I was building an ark.
    My regular email address is:
    scott-irwin@sbcglobal.net
    Thanks!!!
