I have a 1956 ford Y block 292, with the automoatic 2 speed behind it. I have a T5 tranny here and i want to put that tranny on. What do i need for the swap? And can the swap be done? If not what manual tranny will bolt up to a Y block? Thanks, -Andrew
I'll PM you some info about the T-5 swap from another site... I'm using a toploader 3 speed from a 67 Ranchero. You just need to get a tranny that has both bolt patterns, to accept both patterns of flywheel. Then you'll need all the other goodies. You should see what you can find for a flywheel first, then get the other stuff to match up with it. Just make sure you verify that the splines will match up from the clutch to the input shaft. Deyo
