My 39 Tudor sedan standard came converted from the wide 5 bolt pattern to 5.5" on both the front and rear. It does have round back spindles on the front and still has a banjo on the rear. What do I need to look at/for in order to identify what was used to do this conversion?
I did the same conversion on my 39 years ago. all that is required is a set of 40-48 drums front and rear
If the hub is inside the drum the assembly is prewar, if the hub is outside the drum it's postwar. Generally.
