What do I need to put my 200-r in my car in place of the turbo 350
Discussion in 'The Hokey Ass Message Board' started by atomickustom, Jun 27, 2012.
  1. WZ JUNK
    WZ JUNK
    from Neosho, MO
    There is a local transmission shop that I have used for many years. He is a streetrodder and I have never had a problem with his work. Richard's Transmissions 417 451 0211, located on 59 highway east of Neosho, about a half mile north of highway 86 intersecion.
    John
  2. squirrel
    Something about that does not compute....the 200-4R is the same length as a short tail TH350, the 700R4 is the same length as a long tail TH350.
    Or else I've been hallucinating. As long as you measured it and it fits, you should be fine.
  3. What car is it going in? You maybe able to switch to a taller tire and get everything you want simple as that.
    Jumping up to a 70 or 75 series from a 50 or 60 series in a 15" wheel makes a huge difference.
    If all your trying to do is cruise at 65 or 70 that may just do the trick.
  4. Rpmrex
    Rpmrex
    from Indiana
    A taller tire was my first thought also.
    That makes a big difference!!
  5. atomickustom
    atomickustom
    Can't go much taller: 205x75x15 on a '53 Chevy. (And these tires are the same height as the 215x75s I just pulled off.)
  6. atomickustom
    atomickustom
    I may be wrong and I'd have to measure to double-check. I thought the 200r was the same length but with the mount further back. If it's shorter then I'm getting into a new drive shaft and possible clearance issues. Looks like I'm gonna be on my back under my car again soon with a tape measure. Thanks for the heads up!
  7. atomickustom
    atomickustom
    Oh, I can see going to him for older stuff like that, but when he rebuilt my '85 350 truck trans they gave it back to me filthy and treated me like ****.
  8. falcongeorge
    falcongeorge
    from BC
    Just look around, no-one on here builds hot rods anymore.:rolleyes::rolleyes: And almost all G-body rears are 7.5, same as your S-10 rear, and most of them had gears in the range you are looking for. Just pull the ring & pinion out of just about any G-body you can find, have it installed in your rear, (the one in the car, that is)and you will be set.
  9. 1971BB427
    1971BB427
    from Oregon
    Don't want to sidetrack the thread, but is there any way around using the TV cable? I'm also looking at a winter project this fall to get overdrive in my car, but with sideways mounted Holleys on my tunnelram I'm not sure how I'll be able to use a TV cable and bracket.
  10. WZ JUNK
    WZ JUNK
    from Neosho, MO
  11. WZ JUNK
    WZ JUNK
    from Neosho, MO
    To my knowledge you must use the cable. It must be at the exact position on the carburetor as it was originally designed and it must adjusted correctly. This information is for a 700r, but the 200r is a similiar process. http://purplesagetradingpost.com/sumner/techinfo/700R4p1.html
    John
  12. squirrel
    You can get away without a cable if you run a 4L60E and put on a computer instead! so look for a long cable off a TPI engine or something.
  13. chubbie
    chubbie
    there is a fail safe valve body available. you may have to use the TV cable but you can't burn your trans up!
  14. 1971BB427
    1971BB427
    from Oregon
    Thanks. Guess I'll see how long a TV cable I can find, before I proceed any further.
  15. squirrel
    Also you can connect the TV cable at the pedal, it doesn't need to be at the carb. Just make sure the action is as it should be.
  16. lowelife
    lowelife
    I just did this swap over the winter in my model A. I love the 200-4r. As previosly stated I had to move the cross member back a little over 6" and changed my shifter. Hooked up my lock-up to a toggle switch and now I can cruise at 2500 @ 78 mph. It was the best money spent so far.
  17. chubbie
    chubbie
    never thought of that!! good one squirrel! i think .. the cable has to be tight at idle, and only move 1 1/8" at WOT
  18. I just checked both my 200s and they are both universal so Chevy, BOP, Cadillac. Bowtie Overdrives have ha great site and alot of killer parts. They know their 200s and 700s.
  19. atomickustom
    atomickustom
    That is some useful information. Thanks!
    If I ever build a hot rod, I'll be sure to put a 4.11 in it, but this is a kustom and it's built for comfort, not speed.
  20. mgtstumpy
    mgtstumpy
    Here goes
