Technical What do you guys think of this plug?
Discussion in 'The Hokey Ass Message Board' started by HardcoreZ28, Aug 13, 2022.
  1. sunbeam
    sunbeam
    Get some vacuum readings next thing to an AFR gauge when tuning.
    saltflats likes this.
  2. saltflats
    saltflats
    from Missouri
    Have you put a vacuum gauge on it?
    Maybe the power piston needs a different spring on it.
  3. Flat Roy
    Flat Roy
    The back fire is caused by raw fuel being pulled into the exhaust system, (what saltflats said, vacuum below throttle plates is ****ing fuel) and mixing with the right amount of air and then boom. . There's a freash air leak in there some where. Good luck, could be anywhere.
  4. sunbeam
    sunbeam
    Or the stem is stuck in the up position not opening the power valve or power valve concert is blocked. A lean can kill milage the best milage comes with the least amount of throttle opening a lean mixture will require more throttle for the same power.
