Hot Rods What do you guys think?
Discussion in 'The Hokey Ass Message Board' started by silent rick, Feb 20, 2025.
  1. silent rick
    silent rick
    when we welded on the brackets and spring perches, it was just a 46 banjo rear from a truck.
    The shackles were close to the desired 45 degree angle. Then I went and ruined everything.
    I added a winters quick change center section to the banjo bells. Turns out the new center was a good 3/8 of an inch wider, had to turn a 3/8 spacer to get the proper back lash.
    So now I no longer have the desired 45 degree angle on the shackles. Do you think the suspension will work still?
    ratster likes this.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Easy way out would be longer shackles.
    twenty8 likes this.
  3. silent rick
    silent rick
    but that would effect ride height.
    It's what I did on the front axle as seen in this pic
    ratster likes this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    surely the spring will flatten out some when you put the body on it. Have a couple of people stand on the rear of the frame and see
    Paul, lumpy 63, twenty8 and 8 others like this.
  5. wheeltramp brian
    wheeltramp brian
    Put the Body and finished car on and I'm sure it will be fine.
  6. squirrel
    the shocks are way too far inboard to do much anyways, I wouldn't worry about a slight change in angle.
  7. rusty valley
    rusty valley
    Me n Anthony both would drive it as is
  8. flatheadpete
    flatheadpete
    from Burton, MI
    My thought exactly. I'm sure it'll fine. Killer set-up, btw.
  9. silent rick
    silent rick
    thanks, thanks everyone, even you jim :)
  10. silent rick
    silent rick
    it's a 27 T roadster body with i believe a 12 gallon tank and battery in the trunk
  11. Stu D Baker
    Stu D Baker
    from Illinois
    Don't forget to add driver and couple of fat chick's to the equation.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Hasn’t it been affected already since the shackles are more horizontal now? Think about it.
    twenty8 likes this.
  13. swade41
    swade41
    from Buffalo,NY
    The spring will settle once you put a few miles on it too
    twenty8 and mad mikey like this.
  14. silent rick
    silent rick
    drunk fat chicks dig me
  15. Toms Dogs
    Toms Dogs
    from NJ
  16. The37Kid
    The37Kid
    They won't stay at 45 degrees if you drive it.
  17. twenty8
    twenty8
    Yep, longer shackles will drop it back down to where it was with the narrow rear end. About an inch going by the pic.
    Good idea to load the frame up to somewhere near finished weight before making any changes. It might be ok as it is.
    If it does need longer shackles to get 45 degrees, do it with the frame loaded.
    Johnny Gee likes this.
  18. lostone
    lostone
    from kansas
    You know what they say about fat chick's ?!
    They are like mopeds, fun to ride but you still don't want your friends seeing you on them !!
    ...BTW I agree with the above, wait until you have it together THEN worry about it, I would bet the weight you install ( minus the fat chicks) will probably put you close to where you need to be.....
  19. Kerrynzl
    Kerrynzl
    Leave it alone, the desired 45° angle is a myth.
    As the suspension compresses the spring will arc outward [wider]
    The easy way out is to leave it alone, It works better that way.
    On early speedway cars they ran them that way for lateral stability
  20. Bandit Billy
    Bandit Billy
    I'd finish building it, put 500 miles on it and call me in the morning. Or text. Actually, I don't really need feedback.
    Tow Truck Tom likes this.
  21. Put weight on it
  22. twenty8
    twenty8
    @silent rick
    It would be interesting to see how much weight needs to be placed on the frame above the rear end to get the shackles down to 45 degrees. My bet..... Not as much as you might think.
    Stu D Baker and Moriarity like this.
