What do you recomend for speedo cable lube?
Discussion in 'The Hokey Ass Message Board' started by Bugman, Jan 10, 2004.
  1. Bugman
    Bugman
    Everyone seems to have their own favorite. Mine is wheel bearing grease. What's yours?
    -Bugman Jeff
  2. Phil1934
    Phil1934
    Powdered graphite won't freeze.
  3. Fastsporty
    Fastsporty
    powdered graphite is good, but I also like Harley chain lube that **** stays on.
  4. Bugman
    Bugman
    I work summers at a Harley dealership. We used to use graphite on our cables, but don't anymore. We found that after repeated applications, the graphite built up and started caking causing more drag on the cable. Everyone at the shop uses something different. Harley chain lube is good stuff. It's my favorite general purpose lubricant.
    -Bugman Jeff
  5. Fastsporty
    Fastsporty
    Bugman It wasn't Docs H-D was it? Those guys are the greatest. They helped out alot once at a race.
  6. Rocky
    Rocky
    Classified Editor
    White grease.
  7. DrJ
    DrJ
    Go to the last remaining parts store that has holes worn in the formica counter tops and Bardahl signs on the walls and get a tube of actual made for the purpose speedo cable lube. It's close to the consistency and slipperyness of the "wire snot" electricians use to pull wire through conduit. (but the wore snot won't work)
  8. Bugman
    Bugman
    Fastsporty, it's Kutter Harley Davidson in Janesville, WI
  9. BELLM
    BELLM
    Vaseline. Seriously. Always worked good for me.
