Projects What do you think?
Discussion in 'The Hokey Ass Message Board' started by Bigstar, Nov 8, 2013.
  1. Hdonlybob
    Hdonlybob
    Great project start...and talk about a right price !!
    You are a lucky guy...
    And at the risk of being to corny...from the looks of this picture, the engine must be fairly hot, as it appears to have a "Funnel Ram" ! :eek::(:eek:
  2. Bigstar
    Bigstar
    from Austin
    SO I finally got out to my shop today and started working on my '57 project and I removed the funnel ram! ha.. The previous owner dropped a Pontiac 301 into it and I am debating on whether or not to keep that motor in there. I do have a question. Can anyone identify this carburetor and would you just rebuild this one or buy a new one and if so what would you put in there?? There are some loose connectors and it probably needs a rebuild but I will try it out first. Thanks for the help.
    Oh... and what is this silver canister with the gauge on top of it ha?
  3. Bigstar
    Bigstar
    from Austin
    Hey all. I haven't been on in awhile. The last time I was on here I had just picked up this '57 bigwindow truck. The previous owner had covered the entire truck with primer...including the emblems and part of the windows! O_0 Anyway.. I made room for it in my shop and decided to wet sand the primer off of every inch of this truck by hand. After hours and hours of work I am getting down to ( what I think ) some pretty awesome layers of original paint. I can go deeper once I get it on the road and get the look I want to keep. I don't think there is a subs***ute for hand sanding. There are a few areas of aftermarket paint and red oxide primer on top of the original blue paint but I will come back later and fine tune the look I want. I love the look of some of the oxide and aftermarket paint still there. You can't fake or reproduce this look. There is very little filler on the truck. In fact I am grinding out any filler I find and I will take any dents out and weld in the little bit of steel needed for rust areas when I get to that point. I have a few other projects going so I am just going to get this one running, put some bias plys on it and drive the **** out of it. I am currently figuring out what tires to put on it. I really like the look of straight black bias plys but I want a tall thick tire on the back and a medium tire on the front with enough meat on it so it doesn't look silly dropped in front too much. The wheel sizes are15 x 5 1/2 s on front and 15 x 7 out back. There is a truck with Firestone 6.70-15's wide whites on front and Firestone 8.90-15's wide whites on back. Any thoughts? I wish I could get these in all black but can't find them so I am thinking about going with super wide whites in back and wide whites in front. I will probably lower the truck some but not planning on slamming it with a crossmember or anything. What do you guys think?? Some pics of my truck and some I like..
  4. Bigstar
    Bigstar
    from Austin
    although if I could find the right all black bias plys that gave me the EXACT look I want I would go with them but these super wide whites look bad *** in my opinion too..
  5. dan31
    dan31
    Either "buffed" black walls (all writing removed) or wide whites would work.check out diamond back tires for either one.
  6. mike bowling
    mike bowling
    I'll give you $200. more than you paid for it right now!( I need to find some new friends!)
  7. Bigstar
    Bigstar
    from Austin
    Thanks for the advice and suggestions. I appreciate it!
  8. big duece
    big duece
    from kansas
  9. jimcolwell
    jimcolwell
    from Amarillo
    You need a 700r transmission and put it together. Just remember it ain't nothing but horsepower and weight. That truck will run with a lot of cars on the street. Have fun.
  10. Bigstar
    Bigstar
    from Austin
    Thanks man. The truck actually has a Turbo 400 in it
