Hot Rods What does a rear end sound like when its going to go bad?
Discussion in 'The Hokey Ass Message Board' started by Bruce Fischer, May 3, 2020.
  1. Sounds like a dry bearing. Any ideas? Changed both wheel, bearing aready. Thanks Bruce.
  2. 283john
    283john
    You check the rear u joint?
  3. ol-nobull
    ol-nobull
    Hi. Did you check the ring & pinion gears and their inner bearings?
    Bruce Fischer likes this.
  4. '34 Terraplane
    '34 Terraplane
    from Western PA
  5. Jalopy Joker
    Jalopy Joker
    ***le of Thread answer: it is when a rearend goes from sweet and silent to nasty and loud
  6. seb fontana
    seb fontana
    from ct
  7. chevy57dude
    chevy57dude
    Best of luck with it, mine sound like this:
    BANG! Clunk clunk clunk thump thump.
  8. HOTRODPRIMER
    HOTRODPRIMER
    Bruce, do you have a leak, check the simple things first. HRP
  9. sliceddeuce
    sliceddeuce
    Agree....You hear it?? It has at least one issue.
    Nicholas Coe and Bruce Fischer like this.
  10. sunbeam
    sunbeam
    Does the sound change from under power to coast?
  11. wheeldog57
    wheeldog57
  12. ClayMart
    ClayMart
    Sometimes they sound like you're running a load of rocks and Coke bottles thru a washing machine. Occasionally followed by a loud "ker-CHUNK-eta" sound. :(
  13. squirrel
    The sound depends on what's going bad in it. Bearings can make noise, or they can get loose and let the ring and pinion make noise, or gear teeth can break off, or side gear splines can strip, or spider gears can get loose, or the cross pin can fall out, or the pinion nut can back off, or a bearing race can eat into the housing, or....
    there is no single answer to your question. If you want to know what's going on, you have to get in there and look at stuff.
  14. 41rodderz
    41rodderz
    from Oregon
    You only want to hear the sound of the exhaust, tunes or a blower whining.
  15. chevy57dude
    chevy57dude
    The chrome worm on the cover was from a bolt taking a ride in a (now) 9 bolt posi. Ring gear spacers ****.
    Bruce, sorry for the hijack
  16. winduptoy
    winduptoy
    Check to see if there is metal in the lube.
    If its a slow failure, it will appear pearlescent cause the gears have been grinding it fine.
  17. sliceddeuce
    sliceddeuce
    Check to see if Tammy Wynette has been keeping company with it.
  18. Lone Star Mopar
    Lone Star Mopar
    Wwwwwhhhhhhwwwwwwhhhhhhhwwwwwwwwwwwwwwhhhhhhwwhhhwwwwwwiiiiiineeeee. Something like that
    Sent from my LM-Q720 using The H.A.M.B. mobile app
  19. brokedownbiker
    brokedownbiker
    somebody has to say it...... It starts making noises and smalls bad, like old chili and cheap beer.
  20. Dangerous Dan
    Dangerous Dan
    What do they sound like? They sound like ****,lol
  21. ct1932ford
    ct1932ford
    Is it the same at all speeds?
  22. mickeyc
    mickeyc
    No one mentioned pinion bearing?
    ted kovacs and Bruce Fischer like this.
  23. Truck64
    Truck64
    from Ioway
    Sounds like the (bad) Voice of Experience! lol
  24. I did John and the rear u joint had a grease fitting and I grease it till grease showed at all 4 corners. Thanks Bruce.
  25. OL no bull no I didn't but my bosses husband whos a crack mechanic, said that what it sounded like .I just wanted more opitipns.Thanks Bruce.
  26. chevy57 dude, mine is more like a roar, I have changed the rear end oil too, when I did the rear wheel bearings.Thanks Bruce.
    chevy57dude likes this.
  27. No leaks Danny .I have checked it several times.Thanks Bruce.
  28. Sunbeam, kinda hard to say.I don't hear it when I 1st take off in the morning but as soon as I hit the high way I hear it start roaring.Thanks Bruce.
  29. manyolcars
    manyolcars
    The axle in my 59 is grinding and popping. Theres no mistaking the sound
  30. No problem chevy 57 dude.Bruce.
