What does coolant in the cylinder burn like?
Discussion in 'The Hokey Ass Message Board' started by olskool34, May 26, 2009.
  1. kenny g
    kenny g
    Not very good for gas mileage
  2. bobscogin
    bobscogin
  3. Why not do a radiator dye test
  4. azrael_ak
    azrael_ak
    Having issues with my 267 small block. White smoke out the drivers side tailpipe... Replaced both head gaskets and its still shooting out white extremely noxious smoke that gives you a splitting headache. You cant really notice the smoke at idle....only during acceleration and highway speeds. After reading some of the forums tonight, someone suggested it could be a faulty transmission modulator and ****** fluid is being ****ed into the intake. Upon head removal i discovered it was #1 that was the offender. It had a weird charcoal looking buildup on the head and spark plug. All other chambers and heads were fine. I'm not seeing any coolant in the oil. The 267's original 2 barrel intake was swapped out for a Weiand Holley intake with a Holley 600dp. It has always run very well after the modifications (3 years) and this is the first problem I've encountered. If anyone has any thoughts or ideas please let me know....Thanks
  5. 40fordtudor
    40fordtudor
    did you true or mill the heads some b4 install--back in the 50s i blew several head gaskets on my way to learning about truing them first---these were offy's but it seemed like everyone had the answer but me. made good time changing out gaskets, tho--
  6. azrael_ak
    azrael_ak
    The head gaskets arent blown....I just changed them out with the same exact results. :confused:
  7. 61bone
    61bone
    If coolant got in the oil, plan on doing a complete teardown. If you try to run it without cleaning it up, you will be seeing stuck rings ,galled bearings, sticky valve lifters and cylinder wall damage. You could run some Buytlseptasol through it and hope for the best, but a hand cleaning is best. All it costs is time and a set of gaskets and plugs for the galleries.
  8. azrael_ak
    azrael_ak
    No coolant in the oil....
  9. bobscogin
    bobscogin
  10. azrael_ak
    azrael_ak
    I dont believe this is vapor. Its a thick white extremely stinky smoke that hangs in the air. It gets worse as you give it more gas...but its hardly noticeable at idle. Im fixing to go remove the vacuum line to the transmission modulator and plug it. Hopefully thats it....If not....ill be shopping for a new motor
  11. Truckedup
    Truckedup
    A little bit of oil getting burned is sort of blue.A lot of oil getting burned may look sorta white,like when a race engine looses a piston a speed.
    One cylinder is coked up? might be broken rings or whatever.I think if it was the ****** modulator the smoke would be more likely be from all cylinders unless the vacuum port is directly into one intake port.But the modulator is an easy test. Got power brakes? Could the brake fluid be getting ****ed into the intake?
  12. azrael_ak
    azrael_ak
    Master cylinder line is bone dry
  13. A 267, isn't that the late 70s econo-motor that came in Monzas and some other cars?
    Worth it's weight in s**** iron, for what you can buy a complete running 305 or 350 for, I wouldn't throw more than a couple hundred bucks at this, tops, because it's just throwing money away.
  14. Hackerbilt
    Hackerbilt
    Azrael...this is why you should post an intro in the intro section and then start your own thread!
    By adding YOUR problem to the post about someone elses problem...half or more of the people answering will be thinking they are answering to the original problem. Just like is happening NOW.
    Just start a NEW post about YOUR problem and end the confusion for everyone...including yourself. :D
  15. azrael_ak
    azrael_ak
    Apologies....it must be all the smoke....caused migraines and confusion
  16. Hackerbilt
    Hackerbilt
    Hahaha....
    NO need to apologize...just want to see you get your answer as easily as possible.
    Welcome aboard!!!! :)
