Hot Rods What Does This Adjust On My Powerglide ?
Discussion in 'The Hokey Ass Message Board' started by davvet2, Aug 25, 2023.
  1. davvet2
    davvet2
    There's a 9/16 nut with an allen head bolt next to the shift lever on my Powerglide, what is this for? IMG_8863 PG adj.jpg
    Tow Truck Tom likes this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
  3. saltflats
    saltflats
    from Missouri
    Low gear band.
  4. davvet2
    davvet2
    OK, Thanks. I took the trans to the shop to have it checked out, they pulled the pump, pan etc. and it checked out good but after getting it back home I noticed that the 9/16 nut was backed off, which didn't look right.
    I tightened the nut up without touching the allen bolt, how do I make sure it's adjusted correctly? Or do I need to take it back to the shop and let them fix it?
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    I posted a link above on how to adjust it. but you better let them do it
    tractorguy and Tow Truck Tom like this.
  6. davvet2
    davvet2
    Didn't see the link, but I just read online how to do it, and I even have an inch pound beam torque wrench.
    But, I paid them to check it out, and I'll bet the guy just left the nut loose, so
    they need to take care of it. The shop had already closed when I found this,
    and I posted here to see what was going on.
    • Tighten the band adjustment screw to 72 inch lbs
    • Unscrew the band adjuster three and a half turns (3.5)
    • Tighten the band adjustment screw's locking nut
    Thanks, Jim
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    the link was in my first post.... the first reply here. probably best to take it back to you trans guy and ask them why it was left loose...
