Technical what donor for a rear for my hudson
Discussion in 'The Hokey Ass Message Board' started by peter schmidt, Dec 8, 2014.
  1. peter schmidt
    peter schmidt
    from maryland
    I need to find a good donor rear for my hudson preferably with a 5x4.74 bolt pattern. It currently has a gbody rear I think and it's around 58 inches from wheel mounting surface to wheel mounting surface. I would like to find one the same width or maybe 2 inches narrower to help getting the rear tires off. I looked online and the measurements all seem to differ as well as how they measured. Can anybody help me out? I work 6 days a week and have a one month old girl and 3 year old boy so finding time to go to the junkyard and measure is limited and it might be cheaper to find a donor off craigslist. Any help appreciated
  2. peter schmidt
    peter schmidt
    from maryland
    Here's a pic of the rear I'm pretty sure it's out of a g body has aluminum finned drums it's also got*****py made/welded leaf spring mounts a warped tube leaking seals and a broken bolt holding the pin in. Don't mind the blue tape my son was helping me in the garage.
  3. Bill Rinaldi
    Bill Rinaldi
    S-10's are 55/56'' wide and reasonably cheap but watch the gear ratio. Many are for O.D. trans and run 373 gears. BILL RINALDI
  4. Canus
    Canus
    Since you have a stepdown why not go with a Dana*****er. They are what came in your car and most parts are available for them.
  5. peter schmidt
    peter schmidt
    from maryland
    My stepdown has been clipped at some point in its life with a g body front clip and it's got a 283 sbc with a 400 turbo currently but I'll go 700r4 eventually so a rear geared for overdrive would be fine. Are you sure the s10 are 55 or 56 if so that could work great but I found 3 different widths for 2wd 4wd and zr2 online and from what I read they wouldn't fit but it also did not say where they were measuring.
    I'd be happy with any rear but since my car is allready set up with a gm front clip I'd like to keep it the same bolt pattern I wouldn't of even changed it if it wasn't so trashed.
  6. peter schmidt
    peter schmidt
    from maryland
    Found a list online that says
    2wd 54.5
    4wd 59
    Zr2 63
    So a 2wd one might work well I may have to run a 1/4 or 3/8 spacer one each side or should I avoid that? I definitely do not want to go wider than the old rear as I had to fight to get the tires out of it being lowered.
  7. Dick Stevens
    Dick Stevens
  8. gimpyshotrods
    gimpyshotrods
    S10 4x4. I have measured several at 58".
    If you went with the 2wd one, you would have to make absolutely sure that the backing plates and drums clear the body/frame/suspension, etc.
  9. RICK R 44
    RICK R 44
    89/91 Ranger pickup is about 56.5 in wide. Lots of gear ratios available
  10. Actually first gen S-10 2 WD is 54.25" they are a pretty rough rear as a metric 10 bolt goes.
  11. oldsman41
    oldsman41
    dick stevens has it carnut.com has the sizes for most of the stuff.
  12. Nova rears are pretty narrow may take a look at one of them. Actually the later Novas could also be had in 12 bolt.
