Technical What dual M/cylinder to replace 39-48 Ford item.
Discussion in 'The Hokey Ass Message Board' started by 26 T Ford RPU, Jul 8, 2016.
  1. 26 T Ford RPU
    26 T Ford RPU
    I need to upgrade my single acting master cylinder with a dual circuit item, so what one would suit my 48 Ford brakes. This is for my RPU.
    Cheers, JW
  2. Dan Hay
    Dan Hay
    You'll need an adapter, but ch***is engineering makes one. I used a late 60's mustang drum-drum manual master cylinder. A manual MC should have residual valves built into it. The only issue is that the fittings exit on the frame side, which is tight, but I believe an AMC mc of the same years has the fittings on the opposite side. I didn't know that until after I finished the brakes.
    EDIT: I guess I ***umed you are using Ford pedals? That's what the adapter is for, to adapt a modern 2 bolt MC to the old Ford pedals with 3 bolts.
    Hnstray and 26 T Ford RPU like this.
  3. 26 T Ford RPU
    26 T Ford RPU
    Thanks, there is some room for the lines and i can make any adapter needed.:) JW
  4. tub1
    tub1
    from tasmania
    mate since your in NZ get one of a hq holden with drum brakes the type that has the big nut on the end ,take the nut of drill for 1/8 gas and your early ford brake switch screws back in looks all stock and works ,simple little adapter to mount it to the pedal ***y ,believe me it works well
    26 T Ford RPU likes this.
  5. 26 T Ford RPU
    26 T Ford RPU
    Will look into that, but HQ's have disc brake front brakes.
    If I went with the Mustang cylinder what exact year or part number should I be looking for as im sure they are not in many parts houses in NZ. JW
  6. Tim
    Tim
    from KCMO
    Most of the mustang masters I see used are labeled first gen so 64-66 ish?
  7. 26 T Ford RPU
    26 T Ford RPU
    Thanks for that.:) JW
  8. Tim
    Tim
    from KCMO
    Take a look at the adapters online. Most the ones I see look extremely simple if I was looking at overseas shipping time I'd be leaning towards making one if it were an option.
  9. V8 Bob
    V8 Bob
    The first Mustangs to use dual masters were '67, when they were US mandated.
  10. denis4x4
    denis4x4
    from Colorado
    I had a '64 Mustang MC in the roadster and replaced it with a '67 dual MC. CJ Pony makes a slick kit with the fittings and it takes about an hour to make the switch.
  11. 26 T Ford RPU
    26 T Ford RPU
    Thanks for the help guys, did the 67 have drums all round, just thinking of the residual line valves.
    On our NZ auction site there is a new 67-73 dual unit for NZ$200:(. JW
  12. Tim
    Tim
    from KCMO
    They still sell them at auto parts stores here like Napa, orielys etc. you might want to check your stores for the equivalent?
  13. Hnstray
    Hnstray
    from Quincy, IL
    '67 Mustangs could be either all drum or disc/drum, depending on model and equipment.
    The main difference between drum/drum vs disc/drum is the drum/drum has a residual valve in the MC for both frt & rr and the the disc/drum MC has only for rear. The addition of an inline residual pressure valve for the frt can correct that.
    I used such a system on a '47 Ford I built several years ago.
    Ray
  14. 26 T Ford RPU
    26 T Ford RPU
    I went to our parts store yesterday to see about a 64-66 cylinder and no listing, that's before I found out they are a single system unit. will try tomorrow for a 67.
    I was a mechanic up to 30 years ago so adaption wont be an issue, but I would like the cylinder to have both valves in it.
    Cheers, JW
  15. sharpmark
    sharpmark
    this is what you need.67 mustang as others have said.
    Bought off t/m brand new and loaned to another mate to use in his model a with 48 brakes alround. Worked well so he bought his own new. Can find out where he bought it if you have trouble finding one
  16. 51box
    51box
    from MA
    A 70ish AMC is pretty much identical to the early mustang but the lines come out the opposite side. I'm gonna use one on my coupe so the lines point towards the frame rail instead of the center of the car.
    Dan Hay and 26 T Ford RPU like this.
  17. I'm using a jeep/amc master on my '28 (early/mid 70's opposite side ports), I've used drum/drum mustang masters ('67 and up) and I used a late 60's Chrysler master on my '47 (short for under floor space). All I made my own adapters.
  18. 51box
    51box
    from MA
    Nice job, good look on the adapter also
  19. Kerrynzl
    Kerrynzl
    Late Mark 2 Cortina's have the adaptor as OEM made from stamped steel
    Early Cortinas all had Single master cylinder vertical bolt pattern and Dual M/C's were horizontal
  20. 26 T Ford RPU
    26 T Ford RPU
    Thanks again for your help guys. Mark, that is what I will go with. I see it has two different line sizes.
    Kerry, I think it would be a hard job finding a late MKII Cortina now days. I made the mount for the 39-48 cylinder that's there now so I will just modify/adapt that.
    There are a lot of Mustangs in NZ now so that would be the easiest to find.
    Im going to the States in August so I may get one then, Mrs W is also buying a Mustang for herself while there, isn't that ironic:rolleyes::cool::D JW
  21. tub1
    tub1
    from tasmania
    you NZ people must of been not trusted with drum brakes ,in Australia lots of hq holdens had drum brakes ,I only suggested this idea because my 35 has been running this set up for twenty years up till that time it still had rod brakes
  22. 26 T Ford RPU
    26 T Ford RPU
    My bet is its because of our hilly terrain. I have never seen a HQ Holden with drums up front. These are Australian made cars for our State side friends. JW
  23. Kiwi 4d
    Kiwi 4d
    We have used Mitsubishi L300 hi top van master cylinders a couple of times in builds feeding f100 drums. I think these are only 15/16 bore. They work real well, also the reservoir can be mounted remotely , what we have done in the past is put the reservoir under the seat just poking through the floor to gain a little height over the master.
  24. 26 T Ford RPU
    26 T Ford RPU
    Thanks Brian, I have just ordered a 67 drum-drum dual circuit master with two residual line valves..........was told it was the only one they could find in NZ!! NZ$251 including our 15% tax.
    I wanted to have an imperial cylinder as the only thing that is metric on the car is the alternator, and that bugs me a bit.o_O
    Thanks for all the help guys. :cool::D:D JW
  25. Kiwi 4d
    Kiwi 4d
    Yup I know what you are saying. I have a small metric container in the far corner of the shed, some things still seem to get in to pollute the imperial purity. Dang off shore junk.
    How come you need ( I presume 10lb) residual valves with a drum drum master. Not that I know fully understand the system other than drums need a 10lb residual and discs a 2lb.
  26. 26 T Ford RPU
    26 T Ford RPU
    It keeps tension on the wheel cylinder cups, if you have the same on discs they will drag. JW
  27. Hnstray
    Hnstray
    from Quincy, IL
    Your Mustang drum/drum MC may very well have residual pressure valves already in place internally. Aside from bore size, the main difference in disc or drum MC's is the inclusion, or absence of, RPV's.
    On old style single circuit MC's, the RPV was incorporated in the MC piston and cup ***embly. Some units use an small spring and check ball type in the MC outlet ports.
    Ray
  28. 26 T Ford RPU
    26 T Ford RPU
  29. sharpmark
    sharpmark
    Make sure you bench bleed it properly . that was the only problem my mate had - he didn't do it the first time and the second time he didn't do it properly so had a lot of issues !
  30. 26 T Ford RPU
    26 T Ford RPU
    A good reminder, cheers.:)
    If anyone else has had good results with another dual master cylinder with 39-48 Ford brakes please post up your comb as it my help others. JW
