Technical What dual MC will fit my 1964 Chevy
Discussion in 'The Hokey Ass Message Board' started by slim tempo, Jul 12, 2020.
  1. slim tempo
    slim tempo
    Original drums. Stopped well until last week.
  2. slim tempo
    slim tempo
    This MC is 1969 Chevy drum brake model.
  3. It seems you need to determine which port is which.
    And it's possible that that m/c isn't a good choice for your existing system.
  4. 1934coupe
    1934coupe
    I may be wrong but I don't think so. I have a Bendix book I'll look it up.
    Pat
    427 sleeper and slim tempo like this.
  5. slim tempo likes this.
  6. Impala Bob's shows 1" bore for 69 Impaler:
  7. 1934coupe
    1934coupe
    I looked it up that MC is for disc brakes. A drum brake MC is 1" the bend # is 11329 The original MC was a 7/8" bore except for HD with is listed as metallic brakes. Get the right MC. The master cylender does not know it is in a 64 chevy or a 67 chevy so you are not miss matching parts like was suggested. I have been driving my 65 Olds 88 with the same MC as a 67 Olds (1" bore) for over 25 years after a brake line rusted out I changed to a tandem MC.
    Pat
  8. saltflats
    saltflats
    from Missouri
    Make sure you hooked up the push rod to the correct hole in the pedal.
  9. 57 Fargo
    57 Fargo
    I’m going to catch hell for this but I bet the factory master would work great for your car...if memory serves squirrel’s Chevy has been in the nines with a single reservoir master....
    Moriarity and 1934coupe like this.
  10. 1934coupe
    1934coupe
    It certainly would but some times we up grade things for various reasons. I personally like the safety aspect of a tandem up grade.
    Pat
  11. 57 Fargo
    57 Fargo
    I guess I’m on borrowed time but that’s ok, I’ll keep maintaining my stuff and take my chances.
    427 sleeper, Moriarity and slim tempo like this.
  12. slim tempo
    slim tempo
    Thanks Pat. I just ordered a 1" bore.
  13. Theoretical question: What effect will an 1/8th-inch bigger/smaller bore have?
  14. 57 Fargo
    57 Fargo
    You will have to push harder to have the same braking as a smaller bore
    1934coupe likes this.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    427 sleeper, slim tempo and 57 Fargo like this.
  16. Cosmo49
    Cosmo49
    Anyone ask if you bench bled the master cylinder?
  17. He said it wasn't stopping worth a **** when standing on the brakes. The bore size doesn't seem to be the main problem.
  18. updated the MS on my 63 f100, used the first year f100 that had a dual MS.
    split the system and set it up just like a 67.
    the difference was noticeable. I like the dual much better.
    1 1/8 bore sounds big, thats the size my c40 came with.
    that joker got a hydroboost now.
    now thats a nice set up.
    you guys can enjoy the old brake all ya want, unless its fendrless, Im updating em.
  19. 1934coupe
    1934coupe
    A smaller bore equates to easier pedal pressure. With all other things being the same.
    Pat
    slim tempo and saltflats like this.
  20. 57 Fargo
    57 Fargo
    I never said it was, you asked what would change with a bigger bore, I answered.
  21. jimmy six
    jimmy six
    A 7/8” with no power or all drum what was recommended to me by a manufacturer and a conversion person and worked. Remember it’s a dual not a single.
    I have back brakes only on one of my race cars with a 20-1 hand brake handle and it has a 7/8” and I wish it was a 3/4”.
  22. Yep. I continued the thread discussion while replying to you.
  23. 1934coupe
    1934coupe
    The 1" bore "DRUM BRAKE" MC does not have a residual check valve it is only on Disk Brake MC to keep the fluid returning from the caliper to the MC.
    Pat
  24. slim tempo
    slim tempo
    I did bench bleed it first.
  25. 57 Fargo
    57 Fargo
    Yea ok....only if the master is lower than the caliper and drums need a residual valve if they don’t have cup expanders to keep from pulling air past the cups.
    Funny how this “upgrade” has resulted in unsafe brakes.
    Moriarity and 427 sleeper like this.
  26. how are the rest of the brake lines?
    original or new?
  27. slim tempo
    slim tempo
    New stainless steel brake lines. 0 miles.
    anthony myrick likes this.
