what else can you do with an automobile engine?
Discussion in 'The Hokey Ass Message Board' started by atch, Dec 19, 2005.
  1. atch
    atch
  2. 4woody
    4woody
    My friend used to work for an oceanographic survey company. They used engine blocks for sea anchors.
  3. 57JoeFoMoPar
    57JoeFoMoPar
    272 Y block. Most of the cam is still stuck in there. It does better in the garden than it did in the car
  4. The original Irwindale Dragstrip in Cali had a 392 Hemi block welded to a pole,& cemented into the ground.
    It was right in front of one of the concession stands,& all the condiments were in stainless buckets,in all 8 cyls.
    Wished I had taken a picture of that.:rolleyes:
  5. breeder
    breeder
    i think it was the folks the owned the strip in keokuk iowa , had a hemi motor for a mailbox.. it was just across the road from the strip anyway.. always wanted to have it when i was a kid...
  6. Brad54
    Brad54
    from Atl Ga
    If I ever get rich (which means I'll have more time than I do now, and the $$ to do stupid **** like this) I'm gonna take the perfectly good but underpowered and undersized 264-inch Nailhead I have and build an electric generator with it.
    Frame with a radiator and early grille shell, I-beam axle and cool early style wheels will make up the trailer (grille pointed backwards when the thing is being towed). Dress up the Nailhead with a 3x2 intake and some nice valve covers, generator, the whole works. Behind the engine will be a vintage cowl, mounting the gauges and controls. A moon tank below that. Then, at the end of the bellhousing will be an agricultural PTO electric generator.
    I don't know what I'll use it for, but it'll be the coolest generator in the neighborhood.
    -Brad
  7. Bugman
    Bugman
    how about a table?
  8. 55olds88
    55olds88
    Those tables are very cool, I hear some make great boat anchors.....
  9. O.K. it's not an engine, but it put a junk 904 case to good use.
  10. fatassbuick
    fatassbuick
    from Kentucky
    About 4 old farts in NC told me about a Straight 8 Buick running a sawmill.
  11. Comet
    Comet
    I've seen irrigation pumps made from car engines. I've used my Jeep and a strap around the rear tire as a rope tow/ski lift.
  12. Mule Farmer
    Mule Farmer
    from Holland MI
  13. bluebrian
    bluebrian
    from dallas
    that chainsaw is bad***. impractical, unsafe, but just too cool.
  14. Automotive Stud
    Automotive Stud
    That's ****in' awsome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  15. Derek Mitchell
    Derek Mitchell
    Thats the first thing I thought of when I saw this post.
    Very nice, Like a samurai sword thru ****er.
  16. ENGINENUT
    ENGINENUT
    Air compressor of course.Do a search for Gordon Smith of Bowling Green, Ky. They made a practical kit to convert your Ford model A, which was inexpensive and reliable to a portable self powered air compressor.Special head and add a unloader and receiver-- used rad/grille/hood and fuel tank as original.Thousands were made and the company I think is still in buisness but now more sophisticated.
    Schramm of Pennsylvania used a variety of engines for the same purpose but by the late 40's they had a beauty made from a Ford 85 HP v8--later engines were I-H 6 cyl gas,6 cyl diesel, and v8 Cat like the 3208.
    I have seen flathead Chrysler 8, Leroi v8,Hercules flathead 6, and Ford 351W used for this.
    The 351W conversion was by Grimmersmitt and was used a lot on tire service trucks.
    You have to witness the running of these "half engines" to believe how smooth they run.
    I always wanted to build one from a VW opposed 4.Light, portable, compact, and reliable but wouldn't a Corvair be cl***y or maybe a run out Lycoming aircraft or it's military stationary brother.
    Just dreamin'
  17. 53sled
    53sled
    from KCMO
  18. moose
    moose
    I went to school at Parks College in Cahokia, IL. In the engine run area there was a 28V GPU trailer that used a Chrysler Industrial 354 hemi for power.
    I always wanted to back a truck up to it and pull it away. How cool would it be to have Chrysler Industrial script valve covers?
