Technical what engine oil for roots blower motor and other thoughts
Discussion in 'The Hokey Ass Message Board' started by fastcar1953, Dec 25, 2022.
  1. squirrel
    you dont need head studs, if you're going to keep the boost below 10 psi. They're a pain.
    A bit more lift would be good, somewhere between 550 and 600
    Blowers don't use a damper, they just use a steel crank hub. The drive belt takes care of damping the harmonics in the crankshaft. The steel hub p***es NHRA inspections. Two keys aren't really needed for mild boost, you can do it, or not. The big block crank snout is a lot bigger than small blocks.
    Select the drive ratio based on how much boost you get out of your combination. I'd start with close to maybe 6% under and see what happens. The boost charts are not as precise as we'd like them to be.
    Truckdoctor Andy likes this.
  2. fastcar1953
    fastcar1953
    Thanks. I saw the steel hub on BDS website. Good to know on head studs and keyway.
    The cam I looked at is just a little smaller than yours.
    I based this on my truck. I went with one for mid range and should have went a little less.
    So my brother is older than me and always said to use factory parts.
    He used to have the gm high performance parts book.
    I think I will look into that.
    I done a lot of thinking last night. I have time to piece together a good combo.
    I guess stock style engine with forged internals. Keep it simple.
    blower will be bought as can afford.
    Engine I will get a used block then start ordering cam and heads etc.
    I should be able to do this in about 3 years.
    squirrel likes this.
  3. 19Eddy30
    19Eddy30
    from VA
    It can be done with thought blend in / hidden ,add just enough fuel to lube rotors, also if set up loose like a Diesel No fuel needed
    (Im sure ?) but would have to spin harder to get boost psi wanting .
    Also I think you mentioned E85 so your rotors end plates on inside & case would need to be anodized . Usually if running a Alky /methanol base fuel @ end of day run on gas to lube fuel system form corrosion .
    mad mikey and ekimneirbo like this.
  4. squirrel
    Why do the rotors need lube? They don't touch anything.
    Could be that the fuel helps keep them cool so they expand less, and can operate with a bit less clearance?
    ekimneirbo likes this.
  5. swade41
    swade41
    from Buffalo,NY
    The reason an 8-71 is cooler is because it doesn't have to work as hard for the same horsepower versus the 6-71 which would need to spin faster, making more heat.
    A blower makes variable rate compression, the more boost the higher compression, gasoline octane will determine the amount of boost (compression) you can run. If you start at a lower rate static compression you can cram more boost in to reach your compression goal, more boost equals more heat, so it's a balance of things to not build to much heat but still make power.
    Say if your compression goal is 11-1 and you start with 10.5-1 you'll make less overall horsepower with the blower to reach your 11-1 due to the parasitic drag loss of the blower itself, some say it takes 100 horsepower to spin the blower.
    One other thing to think about is if you can fit a conventional distributor in a sbc using an 8-71, if you use a front offset intake or blower to clear the distributor does that push everything forward into the radiator ???
    These guys
    https://nyesracingengines.com/blower-engines/
    build great engines with matched parts that work, comparison shopping of individual parts and machining vs a complete engine might be very surprising.
  6. 19Eddy30
    19Eddy30
    from VA
    fuel dose cool lobes / blower when converted to use on fuel tighter Clarences & type of strip used ,
    & to much fuel can hydraulic case, high hp usually 25% fuel on top and 75 % below
    On street I run a loose set up
  7. 19Eddy30
    19Eddy30
    from VA
    With all 71 blower sizes you need to be knowledgeable of size ,stage , rotor & case design,.
    There are so many , let just talk about the 8-71 3 lobe ,yes more air less drive , But if not spun fast enough it can heat up air/charge @ low RPMS ,& the more invaded efficient Rotor , Case designs more speed required
  8. Blues4U
    Blues4U
    from So Cal
    A blown big block in a model A closed cab pickup?!?! Hahaha! OK, that'll be a hoot.
  9. gimpyshotrods
    gimpyshotrods
    I have one.
  10. mad mikey
    mad mikey
    I like your plan and that little truck. When you are ready, start a build thread. Good luck and Happy New Year .:) Boost is addictive!;)
  11. fastcar1953
    fastcar1953
    My final questions are : forged rods? Flat top or domed pistons or dished?
    Built vs bought is really close. Built I can buy as I have the money. If I bought one finished that would be payments. I won't finance car parts. Cash or wait.
    If I understand right the long block will be built like a 11.1 compression engine.
    Mine will just be 8.1 with blower. Same rules should apply for parts needed to survive on the street.
    I will post pics when the motor is close to done. I'm already wanting to order some things.
    @mad mikey @squirrel @swade41
  12. fastcar1953
    fastcar1953
    Any pics? How much clearance on firewall? I ***ume the firewall is set back.
  13. gimpyshotrods
    gimpyshotrods
    Much of the build is not acceptable for this site.
    That said, my firewall has been relocated forward 6-inches. That was made possible by not putting the engine in front of it.
  14. fastcar1953
    fastcar1953
    Well that sounds interesting. :D
    swade41 and Budget36 like this.
  15. squirrel
    BBCs have forged rods, the Chevy ones will work, I have 7/16 bolt old design Chevy rods in mine, with good bolts. Piston dome depends on the heads, I run a slight dome with open chamber heads on my 427, but I had dished pistons on my 454. If I were building the 454 today it would probably have flat tops. also you don't need to get special blower pistons, with lowered ring lands, etc for under 10 psi boost. Stock replacement forged pistons that give you the desired compression ratio with the heads you decide on, will work, if there are some available.
    Truckdoctor Andy and 19Eddy30 like this.
  16. fastcar1953
    fastcar1953
    Thanks time to make a list and start ordering.
  17. 19Eddy30
    19Eddy30
    from VA
    Just for extra Insurance look into a gm steel crank or **** , when I Tour down the one engine with cast crank on 10 psi cracks ever where.
  18. squirrel
  19. fastcar1953
    fastcar1953
    Thanks I will purchase the books. I know what heads I'm using. Pistons will be machine shop choice along with rings and bearings. First thing is to find a good block.
  20. Blues4U
    Blues4U
    from So Cal
    Your's doesn't count. ;)
    gimpyshotrods likes this.
  21. Blues4U
    Blues4U
    from So Cal
    BTW, I'm not saying it can't or shouldn't be done, just that it'll be a hoot, and of that I am sure. Good luck. And get a big shoe horn.... ;)
  22. fastcar1953
    fastcar1953
    I know it will be a tight fit. I can cut the firewall out and install a modified original. I've been measuring front to back and top to bottom.
    Checking summit racing for rotating ***emblies. price isn't terrible.
    Blues4U likes this.
  23. rlsteel
    rlsteel
  24. rlsteel
    rlsteel
    Here is my 1930 A.I am putting a sbc with a 6.71 350 turbo and s-10 3.42 gears. It is now gloss-black with a red interior. Just turned 67 so I am a little slower than I was.RLS
  25. fastcar1953
    fastcar1953
    @rlsteel That's a good start. Funny I have a 350,th350 and a 3.42 s10 rear end I'm not using.
    I will go bbc with 8-71 th400 and 3.00 to 1 9 inch ford rear.
    My current combo in truck is 355 th200r4 and 4.10 posi s10 rear.
  26. fastcar1953
    fastcar1953
  27. fastcar1953
    fastcar1953
    I saw parts of it. I need to watch it all sometime. Thanks.
  28. mad mikey
    mad mikey
    Engine Masters show with David F. also has some episodes, dyno with various combinations.;)
    fastcar1953 likes this.
