what engines have rods longer than 6.625?
Discussion in 'The Hokey Ass Message Board' started by applekrate, Dec 1, 2009.
  1. I was wanting to know which engines came with rods longer than 6 5/8" or 6.625"?
    thanks,
    Steve
    Hosting-
    8th annual Nostalgic Show & Go! Phoenix April 11, 2010
    www.nostalgicshowandgo.org
  2. squirrel
    wild guess: every engine made before 1949
    or do you mean "modern" engines?
  3. 12packo94s
    12packo94s
    65-67 olds 400 6.996
    68-69 olds 400 6.736
    65+67 olds 425 6.996
    68-76 olds 455 6.735
    413 chrysler 6.760
    440 chrysler 6.760
  4. 53sled
    53sled
    from KCMO
  5. krooser
    krooser
    Flathead Ford... And the ones that fit this crank...
  6. Ramblur
    Ramblur
  7. LAROKE
    LAROKE
    7" in GMC 302
  8. 73RR
    73RR
    392 Hemi @ 6.95"
    Several 'long' rods for the NASCAR 426.
  9. Thanks for the replies everyone.
    With that said,
    would you guys also know the other dimensions of the 65-67 Olds and the 392 rods?
    pin dia?
    rod journal size?
    big end width?
    Also, I think all these rods are forgings too?
    I'm designing a very small de stroked Pontiac and would like to use an exisiting rod or piston so I do not have to to buy both as custom items to keep costs under control. By using a longer rod than the stock Pontiac ( 6.625" ) with the short stroke, I will be able to keep the piston pin height shorter for a lighter reciprocating weight.
    Steve
    Hosting-
    8th annual Nostalgic Show & Go! April 11, 2010 Speedworld
  10. oldspert
    oldspert
    from Texas
    Google 442.com and go the the Olds FAQ. The info you need is there.
  11. plym49
    plym49
    from Earth
    Also less rod angularity - what a great idea.
  12. enginebloch
    enginebloch
    from norfolk va
    Useless for what you're doing but an early jeep flatty has a 9.25" rod.
  13. krooser
    krooser
    I told my wife I had the longest connecting rod...
  14. krooser
    krooser
  15. Ron In the SHOP
    Ron In the SHOP
    from california
    within post number 10,
    you have said that you want the longest rod because it will also make the overall recriprocating weight less in the overall computation.
    well,
    not really,
    because in normal rod/piston/BOBWEIGHT computations,
    unless this is an odd cylinder engine ,
    when you do the computation on bob weight,
    the weight of the " small end " of conn rod is considered "recriprocating" ,
    which would also be then added to the combined weight of the complete piston/rings /wrist pin...
    the large end is considered "rotating" which is not recriprocating....
    what weighs LESS...?
    the added aluminum material in a longer piston......?
    or
    the weight of the extra length within longer rod.....?
    your thoughts are correct,...but a bit mis-led...or you have a mis-understanding about how an engine/crank assy is balanced.
    but there is a gain at some point in being able to have piston dwell at tdc and bdc with the longer rod/short piston...
    but there is also a gain with a faster accelerating short rod/ long piston assy....
    .....(but this is a consideration within a race engine) ......
    you just have to decide which one that you want.
    oh by the way,
    the longest rod that I know of that comes out of a kinda popular/well known engine is out of a G M C straight six cylinder OHV......
  16. Stone
    Stone
    Can you give out any specs on the destroke poncho?
  17. 5window
    5window
    Yeah, and she probably said length doesn't matter.
    Seriously, I am always impressed by the breadth of knowledge available here on the HAMB. The actual tech answers and the links are amazing.
  18. Ruiner
    Ruiner
    I'm gonna take a shot in the dark here and say you're going to destroke a 326 down to a 295ci alky injected roundy round motor? Or will it be a 389 down to 350ci? I have no clue, I just like guessing :D
  19. RAY With
    RAY With
    Ford 6 cyl has 6.800
  20. aerorocket
    aerorocket
    from N.E. P.A.
    394 Olds 7.050 rod length, 2.499 rod journal, 2.990 main. this is from memory which sometimes is not to good.
  21. Beef Stew
    Beef Stew
    from So Cal
    Model A/B Ford: 7.5"
    You can get custom BBC rods that are 7"+ long.
  22. Captain Chaos
    Captain Chaos
    from Missery
    Pontiac and Olds have same wrist pin if your wanting to use a shelf piston ,
    the 7" olds rods can be had used for $40 -50 a set . crank is 2.5
    a 7.1 BBC H beam style can be had cheap too , you go to a little smaller pin .990 , crank is 2.2 .
  23. I have a 1960 389 SD forging that I bought on ebay. It has been modifed considerably. What it was modified for, I do not know. the crank snout was tapered down to a point, the mains were grooved and it was detroked 1/2", plus the rods are larger than Pontiac size ( forgot the measurement on rod jounal and the crank is in the crank shop ).
    What I am building is a very small 4cylinder engine of around 145 cu in. It has potential to be used in a number of things but, initially would be used for a street/mileage combo and probably be turbocharged.
    Because the rod journals are oversize I have the option of making a final decision on stroke and the option on rod journal size too.
    As I mentioned earlier, if I can find a production rod then I would just need to order custom pistons to finish the shortblock.
    Since yesterday, I've learned the '65-'67 Olds rod is 7" long and has a .980 pin ( same as Pontiac ). I still do not know if these rods are forgings and still do not know the big end width or journal size. I was unable to find this info on the 442 site.
    Steve
    Hosting- 8th annual Nostalgic Show & Go! Phoenix
  24. Good point. I do understand reciprocating weights but, did not word my post properly. Thanks for adding.
    Now, after seeing the last few posts, it appears the Olds rod may not work for me with its large rod journal.
    Now, I wonder about the rest of the dimensions of the 392 rod, or see about an inexpensive set of 'h' beams.
    I would only need 5 or 6 rods ( I like to have a spare of 2 of everything I build ). Maybe I can find a partial set from an engine that expired but, first, I need to look at the rest of my options.
  25. as far as rod jounal size, it is yet to be determined as i can weld or machine it to different sizes.
    Do you know the rod journal sizes of those early Olds? 392? or GMC or others?
    Steve
    Hosting-
  26. Ruiner
    Ruiner
    You're chopping up that 389 block for a turbo 4 banger? SWEET! Why the hell is the crank snout tapered that much?
  27. I've made no mention of what block I am using, just the crank. I do not know why the snout was machined that way. I have since had the snoutn welded and machined back to stock specs plus had a second keyway machined incase I ever choose to use a roots blower with it.
    Steve
    Hosting-
    8th annual Nostalgic Show & Go! April 11, 2010 Phoenix
  28. GTS225
    GTS225
    Slant six Dodge has three different lengths. I don't know the 170 inch just offhand, but the 225 uses a rod of about 6.7", and the 198 uses one of about 7". There are aftermarket rods available in the 7" length. You can do a search at slantsix.org and find the dimensions you need.
    Roger
  29. Ruiner
    Ruiner
    Good call, and they're forged too...I believe the cranks to be the same across the board for slant 6's, which means the 170 rods will likely be longer then the 198 ones...
