Projects What exactly have I gotten myself into?
Discussion in 'The Hokey Ass Message Board' started by Shaun Goeckner, Aug 7, 2023.
  1. oliver westlund
    oliver westlund
    I stuck one in a 53 shoebox and had no issues, thats the only one Ive done so far, may stick a 312 dual quad y into one of my rods, undecided yet
    anthony myrick likes this.
  2. flynbrian48
    flynbrian48
    I missed them. :confused:
  3. recore that radiator with a 4 core and put it back in.
  4. Blues4U
    Blues4U
    from So Cal
    And I could easily post half a dozen photos of 33's (or what are claimed to be 33's) with the tall rib on the back panel. I'm not convinced you guys have got it figured out. Maybe, maybe not.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    I’ve never heard about the extra rib on a 34 only.
    Would someone post an “original” 33 without the rib and with the extended firewall???
    I believe we lost the OP.
    Blues4U likes this.
  6. 73RR
    73RR
    ...well, not really, but we can start that discussion later.....
  7. other than basically any pontiac, buick, oldsmobile, cadillac, lincoln, mercury, high model ford, chrysler, dodge...
    it made the most horsepower if you count those ones out :D
    73RR and Petejoe like this.
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    The OP hasn’t been on since Monday.
  9. 1946caddy
    1946caddy
    from washington
    This article should answer a lot of your questions.
    You have a lot of catching up to do if your 58 years old and not been involved in this hobby. Most of us have had the hot rod bug before we were old enough to drive a car.
  10. Dan Hay
    Dan Hay
    Little known fact: Zora.jpg
    Toms Dogs, saltracer219, Tman and 5 others like this.
  11. SBC in a ford? The reason is that with that setup all you need is cool tail lights.
    Sorry I just could not resist.
    Just for grins and to make you chuckle (@chryslerfan55 ) I was working for a large engineering firm back around 2009. Someone had a 34 chevy truck with an SBF in it that he was advertising. I asked the guy about his engine choice and he said that to be a hot rod it had to have a different engine from the original manufacturer to be a hot rod. Odd reasoning but it worked for me.
    I am working on an OT parts hauler. It is an SBF truck. I got nothing against fords but they can be a pain in the ****. several different windsors, different firing orders different head bolts etc. 3 different Clevelands (I think), two bolt to big block ******s and one bolts to small block ******s. The Cleveland lands on different mounts than the Windsor and used different front drive components. The 302 used different front drive components than the 351. Tall decks low decks.
    That's just small blocks and not considering the differences between the 260 and the later small blocks.
    Between '58 and '66 they used 4 different automatics.
    I really don't mind because I got nuthing against Fords but playing with them is like being a one armed man at a circle jerk. :D
  12. chickenridgerods
    chickenridgerods
    from DSM, IA
    All '34s have the rib. Some later '33s purportedly have the extra rib; the majority do not, however. If the cab does not have the 3rd rib it is not a '34.
    The OP's cab does not have the rib. Therefore it is not a '34.
    All '33 and '34 cabs have the "outie" style firewall. Therefore it is not a '32.
    That leaves the only option of it being a '33.
    bchctybob, Blues4U and Hotrodmyk like this.
  13. In my experience it is whatever the ***le says. LOL
    when vehicles are close from one year to the next it gets confusing even for the experts.
  14. verde742
    verde742
    '32 firewalls unbolt, 33-34 don't
    '32 radiator mount above cross member,
    '33-34 mount ahead of cross member and angle back
    wheelbase on '33-'34 is longer than a '32.
  15. FlatJan
    FlatJan
    well I think this is not good for you. you should gift that "****" to me
    a chev in a ford unbelievable..i have a french flathead waiting for a car
  16. Stan Back
    Stan Back
    I think you need more wires . . .
    JalopyJimbo likes this.
  17. X38
    X38
    Just to follow up, he may have posted 5 times, but as the stats now show, that was the day he joined and asked questions. He has not been back to the site or participated since then. And that was last Tuesday. :rolleyes:
    I'm afraid he is becoming another one of 'them.':mad:
  18. Toms Dogs
    Toms Dogs
    from NJ
  19. Roothawg
    Roothawg
    I spoke with the guys at Alan Grove brackets when I was building the 302 for the wife's 55 Ford. I asked if they had a standard bracket set for the 302 and he laughed. He told me that in Ford's wisdom they had 21 different water pump configurations for the 302.
    Dan Hay likes this.
  20. JalopyJimbo
    JalopyJimbo
    from NE Alabama
    I couldn't make a carb run right so...I spent near 1500 to add even more wires and trouble hehe
