Technical What exhaust size diameter ?
Discussion in 'The Hokey Ass Message Board' started by draggin49, May 11, 2023.
  1. draggin49
    draggin49
    Was going to put a set of headers I had on a 21 stud motor (1936) and run dual exhaust. What would be best size exhaust diameter for this application ? Not sure if I’m gonna run straight pipes to rear or maybe gl*** packs
  2. Deuces
    Deuces
    No more than 2" diameter...
    427 sleeper, Paul, Tman and 1 other person like this.
  3. draggin49
    draggin49
    my original guess was 1.75” to -2” .
    figured anything too big will just make it run worse
    Deuces likes this.
  4. saltflats
    saltflats
    from Missouri
    What size is the exit on the headers?
    Deuces likes this.
  5. FrozenMerc
    FrozenMerc
    Flatheads are much less sensitive to down stream exhaust pipe size than other engines because the primary restriction is the exhaust ports as they take a very tight and convoluted route around the cylinder walls to exit the block. That restriction dictates your in-cylinder back pressure and there is very little effect from down stream exhaust componentry, no matter what it looks like.
    2Blue2, draggin49 and Deuces like this.
  6. ronnieroadster
    ronnieroadster
    Agree what FrozenMerc said so just run the size you want from 1-1/2 all the way to 2 -1/4 inch will work perfectly for what your doing.
    Ronnieroadster
    ottoman and Los_Control like this.
  7. alchemy
    alchemy
    Just talked with a flathead engine builder last week and he said no reason to use tube bigger than the hole in the valve seat. So, 1-3/8”. Maybe 1-1/2” on the center port. Whatta you guys think about that?
    chevyfordman and Deuces like this.
  8. draggin49
    draggin49
    I need to go by my storage unit and measure I don’t recall off top of my head, they were a custom set someone made . I will post that info once I can get over there and measure
  9. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    My normal go to on a v8 flatty is 1.75"
    RMR&C, Just Gary and Deuces like this.
  10. Pete1
    Pete1
    from Wa.
    Any size up to 2 inch is practical.
    "W" style will give you exactly .9 more hp over swept style.
    Deuces likes this.
  11. I had dual 2 1/4" with gl*** packs on mine...didn't care for the sound...the signature burble of the flathead got too washed out. If I did it again, I would use less that 2" (probably 1.5" or 1.75").
    Deuces likes this.
  12. GordonC
    GordonC
    Running 1 3/4" through cherry bombs. Nice sound not too obnoxious.
    Deuces likes this.
  13. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Deuces likes this.
  14. Dan Hay
    Dan Hay
    Go small, 1-1/2"-1 3/4' no mufflers, it will have a good rap to it. I just had a SBC with 1 3/4" and it sounded so good.
  15. Model A Gomez
    Model A Gomez
    My headers were 1 1/2' so that's what I ran back to the mufflers and they were 2' so I ran 2" the rest of the way rather than adding adapters at the back of the muffler.
  16. Mike VV
    Mike VV
    from SoCal
    You want large sound...large tail pipes.
    My neighbor had a 3" exhaust pipe installed on is little...Dodge Valiant, "stock" slant 6.
    The thing ended up sounding like a "good" running V-8. He claimed, he felt no loss in power or mileage!
    Mike
