What fluid to use in a vintage sprintcar steering box
Discussion in 'The Hokey Ass Message Board' started by hemisteve, Oct 25, 2007.
  1. Do these old girls require anything special for lubricant?
    Thanks,
    Steve
  2. hotrodA
    hotrodA
    How old? My converted Franklin had light grease in it.
  3. 62_Galaxie_500
    62_Galaxie_500
    I would think gear lube would be used in most of 'em.
  4. I ran 90 weight gear lube in my Norden gear. It was the same Lubrication Engineers (red stuff) that I used in the quick-change.
  5. Bluto
    Bluto
    I use Delco Penn heavy if the box is loose
    And Army surplus grease on the good ones........ I have several cans.
    Even when full you can see the bottom of the can.
    I'll try to get the spec# if you wish, but have to find the can in this mess
