Technical What Ford 9 do i have
Discussion in 'The Hokey Ass Message Board' started by naparra, Jan 31, 2019.
  1. naparra
    naparra
    Hey guys. Did some research and couldnt find specifics. What vehicle did this 9 come off of? Any help is appreciated
  2. fastcar1953
    fastcar1953
  3. naparra
    naparra
    wdm gn 2g30
    3 50 9 S3188 as far as I can tell.
    gimpyshotrods likes this.
  4. Boneyard51
    Boneyard51
    An open 3.50 gear 9 inch... there is some other info there, but that’s the main info.
    Bones
  5. RmK57
    RmK57
    2g30 might be the date code. 1972 July 30th. 3.50 ratio
  6. naparra
    naparra
    72 is the year I'm looking for. Well 70s, ideal would be a versallies. Im needing to see what vehicle it was. An f series truck wont work.
  7. squirrel
    probably a 1972 truck rear.
    If you tell us more about the rest of the rear end, or a picture of it, we could probably confirm what it's out of. Like what it has for spring perches, wheel bolt pattern, etc.
  8. warhorseracing
    warhorseracing
    from cameron wv
    A Versailles rear would have disc brake rotors and four link factory suspension with coil spring mounts. F150 truck will have drum brakes with leaf spring mounting pads.
  9. PONTNAK123
    PONTNAK123
    5 on 4/1/2 or 5 on 5 1/2 bolt pattern ??
  10. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    69178069-207D-4245-AC38-0D80F17C01AD.jpeg 007D694F-8244-4F11-80BF-0BC4C62D832D.jpeg E24583F6-2AEB-49E6-9B14-FC768463339C.jpeg 8A176E08-B82A-47CB-B1DC-28B462C9BCF1.jpeg Give me the outside measurement——brake drum to brake drum—-use a rt angle square at each end for a VERY accurate reading. I have a listing of 22 Ford 9 inch rears and their dimensions varying from a low of 57.25 in 57-59 Ford to 69.25 which is 77-80 ford E150 van. Accuracy is very important; you can tell a lot just by the bolt pattern. Ford used 5 on 4.5,5 on 5,and 5 on 5.5. Remember bolt pattern is outside to center, not center to center. Trucks also used the spring pad on top of the axle,cars mounted on the bottom of the axle. Flatheads Forever!
    warhorseracing likes this.
  11. 61cad
    61cad
    Your deer needs watering
  12. V8 Bob
    V8 Bob
    The Granada/Monarch/Versailles all had parallel rear leaf springs. :)
    Hnstray likes this.
  13. warhorseracing
    warhorseracing
    from cameron wv
    Thank you Sir for not calling me old.:D I do forget!:oops:
    naparra likes this.
  14. naparra
    naparra
    Here are pics of the whole thing.
  15. squirrel
    That is what a 72 truck rear looks like.
    Sent from my Trimline
    naparra likes this.
  16. The 72 truck has the pinion offset around 2".
  17. naparra
    naparra
    Aww bummer. Thank you guys for the info. Well I guess ill keep looking. Thanks again guys.
  18. warhorseracing
    warhorseracing
    from cameron wv
    You can still use the housing, get it narrowed and change the center section.
  19. naparra
    naparra
    I thought about doing that. Just seemed easier to find the right size 9. I need one to be the width of a Versallies which is about 58" correct, also with disc brakes. The disc brakes I can always get a conversion kit. But if all else fails ill get this one shortened and change the ratio. Its going in a 64 impala convertible with an LS1 with a 4L60E.
  20. Rocky
    Rocky
    Classified Editor
    With a [sputter, cough] WHAT???? You could have gone all day without saying that. Sure it doesn't have a 327/powerglide?
    Anyway, if you plan to replace axles to match your front bolt pattern [5 on 4.75"] it doesn't matter what bolt pattern the Ford axle is now. And if you plan to alter the length of the housing for your width and add your bracketry to mount the thing in your car, it doesn't really matter what housing you use. Pretty soon you've got lotsa money wrapped up in the rear end. I've done the very same thing building a 9 inch before. I ended up with 1400 bucks in the axle before I even got to the brakes!
    I found out I'd been time and money ahead [really!] if I'd just bought one of those complete rear axle ***emblies from the vendors who sell them...especially if you plan to keep your coil spring suspension. You can buy a complete bolt-in unit with any ratio you want and it'll have the brakes you want and the correct bolt pattern for your wheels for less $$$ than buying all the parts separately....jus sayin.
  21. 1946caddy
    1946caddy
    from washington
    naparra likes this.
  22. squirrel
    Rear disc brakes are needed? Huh...
  23. naparra
    naparra
    Haha. No the original was a 327 with the powerglide but im putting in a LS and 6l60e. I guess youre on I can shorten it and youre also right on just buying one already set up. They sell these 9s set up for Impalas but they end up running up there in price but beats running around shortening this and doing that. Besides after chrome I'm gonna be in it deep anyway.
  24. naparra
    naparra
    Not need but being that it will have a rack and pinion, a modern engine and ****** why not go broke and get disc brakes all the way around. I already have the kit for the front brakes.
  25. gimpyshotrods
    gimpyshotrods
    Versailles disc brake parts are out-of-production, and ****ed, even when new.
    saltflats likes this.
  26. gimpyshotrods
    gimpyshotrods
    And people wonder why threads get deleted, and they get banned.
    I cannot even get away with posting actual custom automotive history that offends the sensibilities of the sensitive folks here.
  27. naparra
    naparra
    Sir, if I broke some kind of rule please report my thread and get it deleted. I was unaware I was breaking a rule. Have a good day.
  28. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    late Model engines etc. are not HAMB ERA.
    gimpyshotrods and naparra like this.
