What Ford rear axle is this?
Discussion in 'The Hokey Ass Message Board' started by Schmidy, Mar 25, 2012.
  1. Schmidy
    Schmidy
    from Minnesota
    I got this out of what I believe was a 55 Ford but I know it is not a Ford 9.
    I know this one is a Ford 9, I got this out of a 57 Ford.
    Any information on the first one would be greatly appreciated.
    Thanks
    Josh
  2. squirrel
    first one looks like a 55 ford rear. Used from 49-56, it's a Ford car rear, it doesn't have a "number" name like the 9" and 8" etc.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Second diff you show [the leaf springs still attached] I believe is an 8" ,judging by the multiple ribs. dave
  4. Schmidy
    Schmidy
    from Minnesota
    Are they any good or should I just s**** it?
  5. squirrel
    They're ok if you have a stock 55 ford.
    The other rear is a 9", the early ones had more ribs than the later ones. You can see the shape is the more oval 9" center, look at some pics of the 8" and you'll see it's more square, and the pinion support does not hang down so low (you need an end wrench to get the two bottom nuts off a 9" but a ratchet will work on an 8")
  6. Schmidy
    Schmidy
    from Minnesota
    Thanks for the inforamation.
  7. Oldiron01
    Oldiron01
    The second rearend is the same as the one I have under my 59 f100. The parts I have to buy are for an 8.8. It is a 9 inch rear end in my opinion. I do not know what the first one is.
  8. Mike Miller
    Mike Miller
    On the second one, if you can put a socket on the bottom nut where the pumpkin bolts on it's an eight inch. If you have to use a wrench to get it off it's a nine.
  9. squirrel
    Or you can just look at it and see that it's a 9" rear. If you've looked at enough of them.
  10. Drive Em
    Drive Em
    The second rear end is a 9" for sure.
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    If it came from a Ford-O-Matic car there are guys that would like to have it because the gears are more highway friendly.If it is complete with the drums you could probably post it in the cl***ifieds for $100.
  12. silversink
    silversink
    or more----I'd put 175 or 200 on either one of those after a little cleanup and 6 bucks worth of rattle cans if they weren't all seized up. The more you do to make them usable the more they are worth.
  13. Ole don
    Ole don
    They both still have a tag on them. That may be worth something by itself. The ratio first number may be under the flange of the nut, but the other two numbers should be visible.
  14. Schmidy
    Schmidy
    from Minnesota
    The 9" says it has 3.10. The first one says 3.89.
  15. Schmidy
    Schmidy
    from Minnesota
    The second one is a 9 for sure, it going to be used on my 29 Model A sedan. I also took the other one because it is narrow as well but I do not know much about them or if you can even get parts for it? Is it strong? The place that I was at had alot of the first one and the Chevy rear that also has the front drop out center. I even saw an early Mopar one in a Coronet as well that dropped out the front but it was not a 8 3/4.
  16. ffr1222k
    ffr1222k
    The 9" is a 57 model. A lot of people like that year because the housing is round. The later years had a bump out for the ring gear. I may be wrong but I think 57 was the only year like that.
  17. squirrel
    The 57 housing is smooth, slightly later ones had dimples, then they made the bump in it eventually.
