what frame are you using for your coe's?
Discussion in 'The Hokey Ass Message Board' started by davidh73750, Dec 22, 2012.
  1. davidh73750
    davidh73750
    what frames are you running under your coe cab? pickup? van? original I don't have one but just curious.
    I do have a suburban and a 95 van and I'm in wheat truck country so maybe I should keep one of them around.
  2. sqhd
    sqhd
  3. davidh73750
    davidh73750
    I've seen a few done on fwd frames, also mtr/trans mounted behind the cab
  4. 38Chevy454
    38Chevy454
    I used a 74 GM 1-ton frame. The GM is popular for COE swaps. You can use almost anything, step vans and motorhomes have been used a lot. Steering is the biggest PITA, some go with a van style box that is pointing more upward. Just look around and see what you find cheap. The engine and trans you want to run may also help lead to your ch***is choice.
    Here is my COE, 49 Ford on the GM 1-ton ch***is, you can see the fuel tanks on the side, dead giveaway that it is GM:
    Engine behind the cab is better for working on then engine under. I have mine under the cab and it is not fun. Behind also allows more legroom inside cab instead of the large engine cover like full size vans have.
    400orbust and Kris C Blake like this.
  5. 53 COE
    53 COE
    from PNW
    http://www.jalopyjournal.com/forum/group.php?do=discuss&group=&discussionid=1633
    The suspension on my COE is a '73 heavy half rear section grafted to the COE frame. And the '73 front suspension crossmember unbolted from the '73 frame and bolted/welded to the COE frame. Used a '79 Chevy van steering box and '67 Chrysler tilt/tel column. This kept all the cab mount super structure in place. Got the idea from a '40 COE done exactly the same in a Street Rodder magazine back then.
    Today I would seriously consider making a low car hauler with the same ch***is the Decoliner used...
    http://www.randygrubb.com/the-decoliner/
    :cool:
  6. The37Kid
    The37Kid
    Has anyone used an E-350 Ford van as a doner? Add a dual rear and I would think you would have a nice setup. Bob
  7. davidh73750
    davidh73750
    Cool I got the burban with 454 use thatframe and can rob the steering box from the van. Great ideas
  8. CH3NO2
    CH3NO2
    Any more in-depth info on this. I've been kicking around the idea of building one of these for my shop, and have my eye on a late 50's GMC currently.
