Building a 52 chevy pickup street rod with 400 sbc. My problem is to use a s10 frame or original frame and mII sus. Would appreciate pros and cons of both to those with experience. Thanks
I built a '48 using the stock frame and a MII. I used an aftermarket crossmember and stock everything else except brakes. Worked great, and rode beautifully.
there are other options too as already covered.. you can search for them all.. here are other options. dakota ifs aerostar drop out ifs volare subframe swap hope that helps too
