Technical What Gauges would you chose
Discussion in 'The Hokey Ass Message Board' started by DragonMotorSports, Feb 23, 2024.
  1. I have a 31 Ford Model A Street Rod with a basic 350 Small Block and a TH400 transmission. I have 5 spots that can accommodate gauges, (2.3125 size) which would you chose? Not what brand, what type, example: Oil pressure, Water temperature, Volts ...ect
  2. fastcar1953
    fastcar1953
    fuel, oil pressure ,temp, volts, boost. a/f ratio maybe
    abe lugo and mad mikey like this.
  3. 57 HEAP
    57 HEAP
    Same as above except transmission oil temperature.
    osage orange likes this.
  4. 38Chevy454
    38Chevy454
    Oil pressure, water temperature, volts, fuel level, and a small tach if you don't have one somewhere else.
    lostone and Just Gary like this.
  5. pprather
    pprather
    continentaljohn and chevyfordman like this.
  6. ekimneirbo
    ekimneirbo
    Depending on your tastes, you could put one of those "combo" guages in the center and then add individual guages for other things on each side if you actually wanted to monitor some other things.
    As for brands, I'd say you need to look at several brands PRICES. I was shocked at what one well known company wanted for their guages. I'm not talking Stewart Warner, but a popular brand. Basically that brand was about double to triple what I paid for SW's. Some brands don't have all guages available in all styles......so be sure you can get what you want in that style before ordering anything. Also consider if you may want to add or change a guage later ......does that manufacturer make the guage for that need....in that style. To try to make this clearer.....If you are building an engine with the idea of possibly adding a supercharger at some future date..........is there a vacuum/pressure guage available in that style or would you have to use a non-matching style? Same with things like trans temp or even an O2 sensor. I did a lot of comparing because many styles didn't offer all the guages I wanted.
    If you are just going with the 5 common basic guages, then its not an issue.:)
  7. Speed~On
    Speed~On
    Water Temp, Oil Pressure, Fuel level, Volts, Vacuum
    That's ***uming you already have a place for the speedo and tach
  8. If you have a speedo and tach already. Fuel level, water temp, oil pressure, hide a charge light and fill the rest..........it's a Hot Rod :).
  9. 65standard
    65standard
    Only basics
    speedometer
    tachometer
    oil pressure
    Water temperature
    Fuel level
    these are the only gauges you need to check on regularly.
  10. tim troutman
    tim troutman
    I always like a vacuum gauge & tach they move a lot .always a fuel gauge running out of gas ****s
    mad mikey, -Brent- and Just Gary like this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I just don’t know! It all looks so wrong no matter what gauges I pick then place them. upload_2024-2-23_14-10-55.gif
  12. mad mikey
    mad mikey
    I will just submit this. I have Tach, Oil psi, Water temp, Volts, Vacuum, Boost, Fuel level, Fuel Psi, AFR, and Trans temp.:) And a horn.:D
    loudbang, rod1 and Tow Truck Tom like this.
  13. Rickybop
    Rickybop
    P***enger catapult/ejection seat
    pressure gauge.
    And don't forget the "roof down" safety switch.
    X38 and Tow Truck Tom like this.
  14. What's necessary? Fuel level, oil pressure, water temperature, voltage. Wanna speedometer? It's on your cell phone. Wanna tachometer? Clean the wax out of your ears. If its putting a lot of heat into the transmission, a transmission temperature gauge, too.
    If you want the vacuum gauge, put it in the engine bay where you'll use it the most.
  15. X38
    X38
    Speedo, water temp, fuel. The rest, idiot lights. I like to look where I'm going. Too many gauges induces stress.
    I guess some people like the busy/cluttered look like Victorian interior decorating...which is fine, each to their own.
    And I know you're asking about a street rod, but please, nothing with a fish on them. (Although technically, dolphins aren't fish)
    Just Gary and twenty8 like this.
