What gear ratio would you run?
Discussion in 'The Hokey Ass Message Board' started by AJNapierski, Aug 27, 2013.
  1. AJNapierski
    AJNapierski
    from G.V. CA
    checked it and got 3 1/8 turns, also when I said more p***ing power I meant just that with no kick down at wot on the freeway it will p*** any car going the speed limit but I just want a little more top end speed and I think a kick down and a slightly lower ratio will work just fine. Thank you to all who contributed.
  2. Mart
    Mart
    So your ratio is about 3.125?? What ratio is available for your axle in that area?? You can normally say which one it is when you know what was possible.
    When you say slightly lower you thinking in the high 2's??
    Fixing the kickdown so you get a lower gear for p***ing will make a m***ive difference to the performance feel.
    A low 3 ratio should be a pretty good all round ratio with that size of motor and a relatively light truck. What size tires are you running??
    Really and truly in this day and age you should be looking at a box that features an overdriven top gear. Then you get all the performance you want and relaxed cruising and better economy on the highway. You don't normally use the words "economy" and "455" in the same sentence though.
    Mart.
  3. I am with Brickster, keep it driveable and 3:23 wont be too sluggy at all
  4. Id Try a temp wire and toggle for the kickdown before I spent any money on gears.
  5. hoop98
    hoop98
    from Texas
    So you have the common V8 gear of 1980, 3.08.
    Dropping to a 2.73 might be worth 1/2 MPG or less.
    Here is what it does yo your 65 MPH kickdown scenario.
    I'd keep the 3.08 and work on the tune.
  6. gimpyshotrods
    gimpyshotrods
    I'd run a 3.08:1, and fix the other issues.
