What glue or adhesive do you use to glue side gl*** to regulator channel, I used silicone last time and they cracked?
Yes, you gotta use the tape. It's kinda a rubberized cloth that is about 2" wide. It goes between the gl*** and the channel. You might be able to get it at some local gl*** shops, but alot of them don't use it anymore. I also use som 3M black window sealer with the tape as added security.
If you want to glue gl*** permanently use windshield urethane. It comes in a cauking tube; it's what newer cars use to glue in the windshields. Once you open it, it usually dries up in the tube so get all your projects lined up & glue/seal every window in sight while you're at it. ~ Paul aka "Tha Driver" News Flash: APATHY RUNS RAMPANT - Nobody cares.
I used Liquid Nails (what I had available) on the p***enger door window in my F1 about 5 years ago. It's still holding.
