Hot Rods What have I started!!!! 31 Coupe...
Discussion in 'The Hokey Ass Message Board' started by Joe T Creep, Feb 6, 2012.
  1. Awesome you guys are all putting in time to get the car done. That's what it's all about.
  2. Evel
    Evel
    Fogging wheels
  3. Joe T Creep
    Joe T Creep
    Today I started on the wiring before Piero and Lucky got here. Rerouted a bunch of stuff and got it all square. When they got here Lucky did all the setup for my seat which I took and dropped off the frame and wood at the upholstery shop. Should have that weds. Lucky started laying out the subframe for the trunk and he remounted the fuel tank and made room for the battery. Now I will have a lot more trunk space for things. Piero painted the 16 inch rear wheels we decided to go with and he fogged all four. It looks great especially in the sun. He then tweaked out on the front end and painted inside the dropped axle and the brake backing plates. Now Im going back out to put the dash and cluster in for the final time.
  4. sko_ford
    sko_ford
    Man that looks way better
  5. BOP-Nut
    BOP-Nut
    Awesome. Stance looks killer.
  6. Evel
    Evel
    What a difference!!!
  7. Lucky Burton
    Lucky Burton
  8. Evel
    Evel
    your hair still looks good.
  9. Joe T Creep
    Joe T Creep
    2:00 am. Still working on the car. Door latches are in. They were f¥£€>%g with me but I kicked their ***.
  10. Joe T Creep
    Joe T Creep
    Hells yes it is!!!!! Bad*** car with all the comfy features.
  11. big creep
    big creep
    you're up early!^ the car is looking great joe!
  12. Joe T Creep
    Joe T Creep
    Up early nothing! Im just going to bed now!
  13. Motor_Psycho
    Motor_Psycho
    nailed it, that looks killer man nice job
  14. Ian Berky
    Ian Berky
    Looks so killer guys!!!!! Great job !!!! Waaaaaay better than .........ya know?!?!?!?!?! :)
    you got good friends joe!!!!!:)
  15. This coupe looks Great! Keep up the good work!
    What's going on in South Carolina that you guys are talking about? Thats where I am and would love to meet up with some fellow hambers.
  16. Evel
    Evel
    Lucky and I were gonna drop off his clients car after the show... but now its not gonna happen due to timing...
  17. TFoch
    TFoch
    Great job on the car guys. What an improvement over what you started with. Drive the wheels off it!
  18. Joe T Creep
    Joe T Creep
    Ok. After very little sleep I got up and started tinkering. Lucky came over and started fabbing the radiator mounts. It was so high above the cowl before that now we had to move it forward and down to get it to a decent height. The way we are doing it isnt exactly how we'd like, but it'll do fine. Lucky took off and I have been working every moment I havent been helping my lady with her time sensitive project. Big Creep came over to gimme a hand and ******* did I need it. Just tired and a bit stressed so a second pair of eyes really helped. The front windshield is in, the side gl*** is in, coil mounted, doors lined up as best as we could, installed the cluster, wired it, installed the steering column and other ****. Found I am having some issues with the Lokar shifter so I am going back to adjust it now.
    Its looking like more of a car.
    Lucky is coming back tonight to finish the last big things up. ******* Im tired.
    Im happy with how its turning out. There are some things I wont have time to do before I go, but thats always the case. The car looks great in pics but up close you can really see the areas that could use some love still. The body guys werent great, some of the metal was so thin before that its just not great. Probably could have used some more patch panels but thats not a suprise to me. I didnt expect it to be perfect. I know that putting yourself up against a time deadline is not the best way to do everything 100% but honestly I never planned to go 100%. It will be a fun driver that is much better than it was before.
  19. pinkynoegg
    pinkynoegg
    That dash is amazing!
  20. Evel
    Evel
    Picture with the grille on please...
  21. Dreddybear
    Dreddybear
    Hot rods are fun, this is what it's all about. Thrashin like hell then basking in the GLORY and WOMEN!
  22. big creep
    big creep
    its was fun! ill stop by after work tomorrow!
  23. Joe T Creep
    Joe T Creep
  24. Joe T Creep
    Joe T Creep
    And now Lucky is talking to himself.....
  25. Joe T Creep
    Joe T Creep
    Figured out the shifter issue. ******* cable is bending itself up in the shift lever instead of pushing the detent. Tomorrow after the morning whatever I have to find another Lokar shifter hopefully somewhere closer to me than Mooneyes or Reids. Damnit.
  26. Evel
    Evel
    3/4 shot please...hahahhaah just kidding... looks good... damn that grille is low.. hahaha
  27. Joe T Creep
    Joe T Creep
    Lucky just left and I think we are doing pretty well. The trunk floor supports are all done, windows, latches, handles, weather stripping, radiator mounts, deck lid, trans cooler lines are all done. Tomorrow I need to get and install a shifter, Bolt in the fuel tank, pickup the seat, put in the quarter windows, get radiator hoses, install an electric fan(The radiator sits so low that the hoses would have to go up and over the fan. Even if I cut the fan down itd still be odd. Im going to remove the fan and unfortunately there will be a lot of space between the radiator and the water pump but so be it) Install the headlights and mounts and hopefully drive it over to Ians to have the floors done.I think it should come together. I was doubting it a bit earlier but the lack of sleep was making me negative.
    Jack was trying to ***ist Lucky but then he went for the pizza grab. Sneaky *******.
  28. Ian Berky
    Ian Berky
    Looking great guys!!!!!
  29. Car's looking really good!!!
    I haven't known of too many cars built that were not up against a time deadline.
    That kicks us into overdrive.
  30. Evel
    Evel
    Look at it like this.. If you run out of space in the trunk you can store stuff behind the grille :)
