Hot Rods What headlight mounts and headlights are these? Model A / Model B Ford
Discussion in 'The Hokey Ass Message Board' started by Chaduro, Oct 19, 2022.
  1. Chaduro
    Chaduro
    from Peoria, AZ
    Hi everyone. I’m trying to replicate this look but I’m not sure what headlight mounts and headlights I need.
  2. X38
    X38
    Any of those. It depends how you cut and bend them to the shape and location you like. And you will have to cut and bend them.
    edit: you can also use Model 18. ;)
    Happydaze likes this.
  3. rusty valley
    rusty valley
    The lights are 32-34 truck, convex lenses, the mounts are cut off model A shaped how you like as stated by mr X38
  4. X38
    X38
    Thanks, I forgot about that part of the question!
  5. dlw1932
    dlw1932
    from Nebraska
    The headlights look like 32 p***enger car to me (32 commercial are same just had painted buckets). The 33-34 commercial headlights are by themselves.
    alchemy likes this.
  6. Mr48chev
    Similar to the ones that SoCal sells but the ones on the brown 32 are turned 90 degrees at the base so they go straight forward rather than to the side.
    I've got a ragged ***ed bent too much in the middle Model A headlight bar that I am planning on cutting the middle out of to make headlight stands out of but they will probably go out to the side for the look I want. Screenshot (560).png
  7. Chaduro
    Chaduro
    from Peoria, AZ
    What do you mean Model 18? Is there an attachment to your post that I’m not seeing?
  8. Mr48chev
    Model 18 is the model name for a 32 Ford with a V8 A 4 cylinder 32 was a Model B and a V8 was a Model 18. A bit more high falutin than saying 32 V8.
    X38 likes this.
