Technical What Input shaft am I going to need for a T5/283?
Discussion in 'Traditional Hot Rods' started by Cambusta, Mar 2, 2019.
  1. Cambusta
    Cambusta
    I remember a buddy telling me about you needing world cl*** jeep input shaft, is that true?
  2. sdluck
    sdluck
  3. sdluck
    sdluck
    Give us some info if you ask these question
    Cambusta likes this.
  4. Cambusta
    Cambusta
    Just a simple T5 out of an S10 with the mechanical speedo being mated to a 283 Chevy in a Model A Coupe. I’ve been told the regular s10 shaft is too long but a certain jeep input shaft would work.
  5. big duece
    big duece
    from kansas
    All depends on which T5 you have. There are the s10, mustang, and camaro units.
  6. sdluck
    sdluck
    They make a spacer if needed.
  7. big duece
    big duece
    from kansas
    S10 will be non world cl*** unless its 1993, may not hold up well behind a V8.
  8. big duece
    big duece
    from kansas
    Or, shorten the pilot shaft and shorten the bearing retainer.
    Chucky likes this.
  9. 2deuces64
    2deuces64
    I'm doing the same thing and Big Deuce has the knowledge to lead you in the right direction.
  10. brokenspoke
    brokenspoke
  11. oldcootnco
    oldcootnco
    I used the input shaft from a Jeep. The reason was clutch parts would be more readily available. I used a Chevrolet clutch, pressure plate from a mid 60's nova. I had to shorten the input shaft.
    I hope this works try this www. lugnutz65chevystepside.weebly.com
  12. big duece
    big duece
    from kansas
    What input shaft do you have now with the s10, the 14 spline? The tip of the pilot would need to be shorter, and speedway has a 10" clutch disk for 14 spline. I would urge against a S10 unit behind a v8 in a hot rod. They were rated at 240ftlbs is all, the gear set is very low and the weakest of all t5's.
  13. sdluck
    sdluck
    Look at gear ratio esp 1 gear
  14. junkyardgenius
    junkyardgenius
    from Kernow
    I shortened the input shaft on mine.
