What is a good 9” gear ratio?
Discussion in 'Off Topic Hot Rods & Customs' started by rusty rocket, May 1, 2025.
  1. rusty rocket
    rusty rocket
    I m building a 46 Chevy pickup for a guy. He has a new blueprint 383 (435hp)with sniper fuel injection and a 700r4. Looking at getting a new 9” from speedway. Rear tires are 29” tall. I would like to choose a gear where a guy could run at 75/80 mph comfortably. We live in South Dakota and the interstate across the state is 80 mph.
  2. 3.50:1 is a good all around ratio. Had that in a 79 f100 with similar sized tires and it accelerated well(despite having a 302 lol) and cruised at a decent rpm.
    Deuces likes this.
  3. Tim
    Tim
    from KCMO
    https://www.project33.com/tiresize.cfm
    That’s the calculator I’ve used for the last 25 years lol. And he’s from Sioux Falls so it’s South Dakota calibrated lol
    Put in your variables and bob’s your uncle you’ve got your info
  4. mkubacak
    mkubacak
    I would probably go a wee lower numerically than 3.50 if 80 mph was my target.
    You can do side by side comparisons with all kinds of variables with this calculator.
    https://www.grimmjeeper.com/gears.html
  5. With your specs and my suggested 3.50 ratio. Too far below 2200 and you'll likely cause a lot of trans fluid heat from the I ***ume higher than stock stall in the converter. I guess if lockup function still works that'd be a non issue though Screenshot_20250501-222939.png
    Deuces likes this.
  6. squirrel
    Tell us about the cam
  7. fastcar1953
    fastcar1953
    This should be the engine specs.
    BluePrint Engines GM 383 C.I.D. 436 HP Base Stroker Long Block Crate Engines
    BluePrint Engines GM 383 c.i.d. 436 hp base stroker long block crate engines will provide you a great foundation to return your vehicle to the performance level you desire. They feature a new one-piece rear main BluePrint engine block with 4-bolt mains and p***enger side dipstick. Inside the block is a cast crankshaft and connecting rod rotating ***embly, with 10.1:1 compression hypereutectic pistons hung on the end. The full roller camshaft provides .544 intake/555 exhaust lift with 230 intake/236 exhaust duration at .050 with a 110 degree lobe separation. The engines also include a new oil pan, a set of valve covers, and a timing cover to finish them off.
  8. twenty8
    twenty8
    To get things moving well from a standing start you should be aiming for an overall driveline ratio of around 10:1.
    700r4 has a first gear ratio of 3.06, so 10 divided by 3.06 = 3.268 rear end ratio.
    Because there is a fairly big jump between 1st and 2nd in a 700r4, you should probably go a bit more.
    As @The Chevy Pope said, 3.5:1 rear end ratio would be ok, but would be at 1640 rpm at 60 mph. A bit low.
    Step up to a 3.7:1 rear and you get 1849 rpm at 60 and 2465 rpm at 80...... and it would be quick off the line.
    If you are building it for the type of guy that is more interested in fuel economy than fun, go with the 3.5's.
    RodStRace and The Chevy Pope like this.
  9. squirrel
    Running in the low-mid 2000s in od at 75-80 should work well.
  10. With an overdrive transmission the minimum ratio would be 3.73 : 1. My off topic daily has 33" tires on it and the factory front and rear ratio is 3.73. It would probably drive better if the front and rear diffs were 4.11 instead, since the factory sized tires are the same diameter as yours. You don't want to bog your engine down, cruising at 2200 - 2500 RPM would be ideal.
    rockable, dogwalkin and twenty8 like this.
  11. mustangsix
    mustangsix
    I'd pick a 4.11 for those tires and the OD.
    You'd still only be turning 2600-2700 at 80 and it would accelerate pretty nicely.
  12. Kerrynzl
    Kerrynzl
    A 3.25:1 rear end will have it cruising at 2100 rpm at 80 mph
    At 60 mph it is 1581 rpm but if you knock it out of Overdrive it will cruise at 2260 rpm
    The 700R4 has a deep 3.06:1 1st gear
    so the 700R4 with a 3.25 rear in 1st is the same overall ratio as a TH350 with a 3.94 rear in 1st
    700R4 3.06 x 3.25 = 9.94:1 [1st]
    TH350 2.52 x 3.94 = 9.92:1 [1st]
    1biggun and ekimneirbo like this.
  13. I've done a pair of 3.5's and one 3.73. All with 29" tall tires. The 3.5 was right at 2 grand at 80mph. I would look at what your cam suggestions are before making a decision. However, the sniper will adapt to that cam without difficulty. A discussion with the owner about how responsive he wants it to be might be in order but with that being said, If the truck was going to p*** another car, wouldn't it kick down a gear or 2 and haul??? :)
    anthony myrick likes this.
  14. blue 49
    blue 49
    from Iowa
    My Henry J has a 327, 700R4, 29"tires and a 8.8 rear. I started with 4.10 gears and 1st gear was pretty much useless to me. I switched to 3.50 or 3.55 (I don't remember which) and I'm much happier.
    Gary
    Tickety Boo likes this.
  15. snoc653
    snoc653
    from Iowa
    The 302 is happy around the 2100-2400 rpm range cruising if you have the right cam. The 3.50 gears would be my choice (correction: is what I have going under my 51 to start with but it is a big block). Give Quick performance a call and see how they compare with Speedway. I have a GM 10 bolt and a 9 inch from them and both are well built and can be tailored to exactly what you want.
  16. deathrowdave
    deathrowdave
    from NKy
    I had similar in a 37 Chebbie Coupe , 3.70 or greater to 4.30 would be it for me .
  17. Rodney Dangercar
    Rodney Dangercar
    A rule of thumb I've used is: 1st gear ratio x rear end ratio = somewhere between 9 and 10.5, while keeping an eye on the speed in the final gear at highway speeds. For example, I have a T5 with 2.95 1st gear and .63 in 5th. With the 3.00 rear ratio my thumb number is 8.95, just under the minimum recommendation and would work fine except for 5th gear would be something to behold.
    A better rear ratio for me would be 3.4 or 3.55 (8 inch Ford), which would give me thumb numbers of 10.03 and 10.47. I opted for 3.55 because of the .63 overdrive. IMO you would like a 3.50 gear and that would work well with your trans 1st gear.
  18. Mike VV
    Mike VV
    from SoCal
    There's "plenty..." of gear ratio charts in the web... pick one or two, experiment with ratios, pick...your own ratio.
    Do your own homework. You'll learn more that way !!
    Mike
    rockable, TrailerTrashToo and verno30 like this.
  19. bobss396
    bobss396
    This is what I use in my Ford. I have no O D. and I'm around 3200 RPMs at 65.
    Transmission is a Muncie M20, it had a 2.56 1st gear, now has a 2.20 after I blew it up a few years back.
    My issue was it lugging around town with the stock 3.56 rear. At 30 on the side streets i ran it in 3rd gear.
    deathrowdave likes this.
  20. poco
    poco
    from oklahoma
    325 is a good all around one
  21. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I think you have the right idea about what will make a nice roadable truck and Kerry has the right solution for your question. And he explained it very well....... 435HP in a light truck like the 46 shouldn't have any problems with lugging .
    Kerrynzl likes this.
  22. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    Rear gear ratios.
    Hey anybody wanna talk about politics or religion?
    3.70 is the number.
    Deuces likes this.
  23. 1biggun
    1biggun
    It's got plenty of torque and HP to pull a higher gear from a stop and the question is for what's best for 80 MPH high way driving .
    I'd run between a 3.08 to 3.40 ish gear.
    The 700r has a plenty low enough first gear and he's got like 400 foot pounds of torque .
    It's going to accelerate just fine.
    If it's for long distance 80 to 85 mph running I'd go with the higher freeway gears .
    Deuces likes this.
  24. Deuces
    Deuces
    The best all round street gear in my opinion would be a 3.50....
    But I understand my opinion doesn't count...
  25. snoc653
    snoc653
    from Iowa
    I went back and forth trying to figure out rear end gear and tire size for my project with the same trans. I'm going with 3.50 and 29 inch tires after all the what ifs. I have enough power and torque to make it work and I really don't want the engine wound up too much going down the highway. You can always use a shorter tire if you need more rpm for an 1/8 mile track. Or throw on another 3rd member if you're running a 9".
    Deuces likes this.
  26. Deuces
    Deuces
